What I think is my tranny fill plug, says "DONT REMOVE" on it...and its a torx. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What I think is my tranny fill plug, says "DONT REMOVE" on it...and its a torx.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 06-03-2006, 08:14 AM   #1
Achped
So I'm guessing thats not it.
My drain plug is directly underneath the tranny right? Because I see a 15/16 bolt there, but I also see what I think could be a fill plug (same size, 15/16) which is on the passenger side of the tranny and right above my catalytic converter. Now, every manual and internet review I've seen says the fill plug is on the driver's side of the vehicle....but the only bolt I see on the drivers side at all is that "Don't Remove" torx bolt.
Can't I jsut fill it through the shifter or something There is NO where to find this!
I just searched and saw that on a '91 YJ 4cyl at least, the fill plug is the torx bit, but why would it say "Don't Remove"?
See it is I who created the blacksmith who fans the coals into flame and forges a weapon fit for its work. And it is I who created the destroyer to wreak havoc; No weapon forged against you will prevail, and you will refute every tongue that accuses you. This is the heritage of the servants of the Lord and this is their vindication from me." says the Lord.
-Isaiah 54:16-17
Achped is offline   Reply With Quote
Unread 06-03-2006, 08:33 AM   #2
Achped
Nevermind, I found out which one it is. But how the hell do I get to it?!?! It's wayyyyyyyy up there!
-Isaiah 54:16-17
Unread 06-03-2006, 09:17 AM   #3
T.H's TJ
I used a ratchet with a torx socket. Then to get fluid in it i had a pump, but if you don't have one i think the easyest way is to take the top panel off and run a funnel with a tube down to the hole.
T.H's TJ is offline   Reply With Quote
Unread 06-03-2006, 09:18 AM   #4
Achped
Wait, you took the "Do Not Remove" bolt off?
-Isaiah 54:16-17
Unread 06-03-2006, 09:28 AM   #5
T.H's TJ
I don't rember seeing a do not remove bolt?? Lasted a long time if it was.
Unread 06-03-2006, 09:33 AM   #6
Bren Gun
HTH, don't know what tranny you have, but...
http://www.stu-offroad.com/engine/ax-15/ax-15-1.htm
'99 TJ, '03 KJ and a '53 CJ3B sitting in the barn waiting on a restoration... @
http://thisoldjeep.21.forumer.com/vi...er=asc&start=0
Gone, but never forgotten... 1973 DJ5C, 1964 CJ5, 1953 M38A1, 1971 Hurst Special Jeepster
www.this-old-jeep.com
Bren Gun is offline   Reply With Quote
Unread 06-03-2006, 11:50 AM   #7
James04TJ
I have a 1" body lift so it was pretty easy. I used a ratchet extention and was able to run the extention between the tub and frame.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
RedCell Motorsports
http://www.myspace.com/redcellmotorsports
James04TJ is offline   Reply With Quote
Unread 06-03-2006, 03:48 PM   #8
losfreddy
when i changed my gear oil, i had to borrow tools from the neighbor.. Extra long socket wrench that has the swivel head. Hard to loosen with a short, reguar wrench.
ax-15 tranny dosn't have it. he has ax-5. The one on Stu's Site is a ax-15
99 TJ. 5 sp Manual. 4 cylinder. 2.5 liters. airaid intake.
Rock Guards. 32x11.50r15. 4 inch lift. nitro Shocks.
losfreddy is offline   Reply With Quote
Unread 06-03-2006, 04:26 PM   #9
T.H's TJ
I have an ax-5 turd also. But for the life of me can't remeber a do not remove plug. Well what ever plug i found work without a problem.
