What I learned while 4-linking - Page 4 - JeepForum.com
post #46 of 58 Old 01-07-2012, 12:59 PM
Yams
Originally Posted by dmgiff View Post
I only wanted to quote the part ...But I don't know how.
After you click on quote, you can place your curser in the text and highlight the text you don't want, or the picture, and hit the delete key.
After going to their web site, I see where the mount is one piece, nice setup.
Yams is offline
post #47 of 58 Old 01-07-2012, 01:03 PM
TJRHD
wow, everything looks so nice...again Nice job man!
NOT A HATER
TJRHD is offline
post #48 of 58 Old 01-08-2012, 01:44 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Great write up, have you been offroad yet? I ask because my attempt at my "double" Tri 4 link resulted in a harsh ride both on and off road.
Plan is to redo the link angles and separation soon with some added weight to the back she should ride well again.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #49 of 58 Old 01-10-2012, 07:30 PM
04ovrland
2004 Overland WJ 4.7ho/545rfe/247/d44a
04ovrland is offline
post #50 of 58 Old 01-10-2012, 07:41 PM
MO2500
Originally Posted by 04ovrland View Post
The other problem when converting to 4 link and getting rid of the rear sway bar is that the 4 link IS so flexy,the jeep will lean until something stops it. I've never experienced a 4 link with no sway bar but i have heard it makes for a pretty hairy ride with some major body roll.
That behavior is based on the geometry of your 4 link and the height of your roll center. It is not a characteristic of all 4 links. However, I'd still recommend a sway bar no matter the suspension design.
Instagram: @omsmike
MO2500 is offline
post #51 of 58 Old 01-11-2012, 08:54 AM
geiman
Great thread, don't know how I missed it. I'm looking at doing something very similar in the next year or so, it's always good to see the mistakes others make so that we don't.
geiman is offline
post #52 of 58 Old 01-11-2012, 09:10 AM
Imped
Imped's Avatar
That's actually not accurate at all. The handling and cornering on the road has only improved since getting rid of the stock mounts. As for getting rid of the rear sway bar.....perhaps you meant the track bar. All smart people will keep a sway bar in the back.
FYI, I've been without a rear sway bar for the past couple weeks (ordering rear AR) and if it wasn't for how I've got the suspension setup back there, it wouldn't handle nearly as well as it does with ONLY a front AR. I'm strictly a supporter of sway bars, but you'd be hard pressed to notice the lack of a rear sway bar when on the road unless I told you. So, that pretty much defeats your statement of "the 4 link is so flexy, the jeep will lean until something stops it." The ability to articulate and the ability to prevent roll are not mutually exclusive.
OlllllllO
IndyORV
Imped is offline
post #53 of 58 Old 01-11-2012, 09:56 AM
loaderopp
Very nice work. you will love it when it's all done. I built mine over a year ago. and it handles great both on and off road. I tossed the rear track bar while building mine. and have never missed it at all.
Built not bought!!!
2005 Rubicon Unlimited, 5.5 inch custom long arm, 1 inch daystar body lift, River Raider Snorkel, Custom bumper/winch mount, sliders, tire carrier. 37x13.50 R17 Nitto Mudgraplers, Bushwacker flat fender. Custom 1/2 cab. Hyline hood vents. Custom tonnue cover and tool box. HID-X off road lights, LED driving lights custom rear bumper/m6000 rear monted winch.
loaderopp is offline
post #54 of 58 Old 01-11-2012, 02:14 PM Thread Starter
dmgiff
What he said. And since I modeled mine almost exactly after Imped's build except for the longer arms, I would guess mine handles similarly as well. It handles better now on road cornering than it did before. Not that it is all that important to me, but I like that it turned out that way.
dmgiff is offline
post #55 of 58 Old 01-11-2012, 06:30 PM
04ovrland
sorry, i will erase what i said, i guess i had a misunderstanding.
Sorry about that.
post #56 of 58 Old 01-12-2012, 02:08 PM
2000GrayTJ
Great work, definitely going to reference this when it comes to do mine...
not sure if you have a picture of this up or not, but did you butt your brackets up pretty much right to the t-case skid and then go from there?
EDIT: nvm found a pic, did you keep them slightly rearward to maintain a more "mid-arm" setup? Or were that just where they ended up after crunching the #'s?
good from far, far from good.
'99 TJ frame-off rebuild: http://jeepforum.com/forum/f22/99-tj-frame-off-rolled-bold-1199954/
2000GrayTJ is offline
post #57 of 58 Old 10-30-2012, 06:56 AM
yellow_snocone
Great build, lots of great do's and dont's here. I'm going to re-read over this before I officially get started with my 4 link.
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #58 of 58 Old 10-30-2012, 11:46 AM Thread Starter
dmgiff
Cool, my thread got resurrected. In answer to the a I've post even though it was months and months ago, I did not want a long arm setup as I did not want all that hanging down. I wanted to keep the arms as short as possible but they needed to be longer than stock due to my design. (And Imped's suggestion) I have had it for over a year now, have completed my front, and swapped in a different engine. I still am very happy with the rear and would not change a thing.
dmgiff is offline
4 link
I just learned something noone ever told me! YJsahara YJ Wrangler Technical Forum 12 07-06-2007 06:40 AM
Learned the hard way! soxlover TJ Wrangler Technical Forum 9 05-29-2007 09:44 PM
What I've Learned about a YJ DanaT YJ Wrangler Technical Forum 0 07-03-2004 04:43 PM
Lesson learned.... Level_1 TJ Wrangler Technical Forum 0 11-19-2003 03:12 PM
One more lesson learned mattelderbaum TJ Wrangler Technical Forum 0 04-13-2003 03:26 PM
