What I learned while 4-linking - Page 2 - JeepForum.com
post #16 of 58 Old 01-05-2012, 05:05 PM Thread Starter
dmgiff
Here are a couple more. I need to redo the brake line on the passenger side. Not happy with it right now. I also need to take one of the rear tires off and get a shot at ride height so the control arm angle can be seen.
dmgiff is offline
post #17 of 58 Old 01-05-2012, 05:51 PM
wushaw
Rockin jeep
wushaw's Avatar
Very nice work , good welds...etc. Got one question though.
Why grease fittings facing down?
wushaw is offline
post #18 of 58 Old 01-05-2012, 06:28 PM
Sgt.Fuzz
Just to clarify, you used the 10 degree LCA axle brackets?
My build:
Sgt.Fuzz is offline
post #19 of 58 Old 01-05-2012, 07:36 PM Thread Starter
dmgiff
Yup. Axle side lowers are 10 degree brackets.
dmgiff is offline
post #20 of 58 Old 01-05-2012, 07:37 PM Thread Starter
dmgiff
Mainly because I couldn't get my grease gun in there with them up, so figured I'd mock them up this way and still haven't gotten around to changing them.
dmgiff is offline
post #21 of 58 Old 01-05-2012, 07:44 PM
Sgt.Fuzz
Have you had it out on the trails yet? Just wondering how the setup is performing for you.
My build:
Sgt.Fuzz is offline
post #22 of 58 Old 01-05-2012, 07:50 PM
RaggedOleMan
Very nice work. Inspired me...
RaggedOleMan is offline
post #23 of 58 Old 01-05-2012, 08:03 PM Thread Starter
dmgiff
Nope, not yet. Hoping for some time in the next couple weeks. Work is all I can think about the last few weeks. Very little room left for fun stuff.
It is my daily driver and it rides far better than it did before. Much more compliance from the rear. Especially with the new Fox shocks. Worlds better than anything I've had in the past. The only down side right now is the front and rear are horribly imbalanced. I'm getting ready to start on the front though. Already have the Currie/Savvy progressive springs to go in and a new Currie Track Bar. I haven't decided if I'm going to leave the arms stock length or go a little longer.
dmgiff is offline
post #24 of 58 Old 01-05-2012, 08:04 PM Thread Starter
dmgiff
Good, I'm glad. That's kind of what it took me to get going on it also.
dmgiff is offline
post #25 of 58 Old 01-05-2012, 08:07 PM
BamaJeepman21
That looks so good. Factory even.
I still don't fully understand what a 4-link is but this has got me wanting to build one.
-Jack
BamaJeepman21 is offline
post #26 of 58 Old 01-05-2012, 08:13 PM
Sgt.Fuzz
Can you elaborate or are you meaning that the front suspension is still the stock SA setup?
My build:
Sgt.Fuzz is offline
post #27 of 58 Old 01-05-2012, 08:56 PM
cfmiller58
great work man. i've been wanting to do this for a long time now.....will get there some day.
Black Jeep Society
cfmiller58 is offline
post #28 of 58 Old 01-05-2012, 09:46 PM Thread Starter
dmgiff
Thanks a lot. I was trying to make it look like it was supposed to be there and not like someone cobbled it together in their barn.
A four link is just the term for how the axle is connected to the frame. There are four links all in a relatively straight line. There is actually a fifth link, the track bar, which locates the axle from side to side. There is some argument as to whether it is actually a 4-Link or 5-Link in stock form. I can't remember the general answer.
However, usually, nowadays when someone says "4-Link," he or she is usually describing the removal of the track bar from the system. This necessitates some way to locate the axle laterally. This is where the triangulation comes in. Take either the two upper arms or the two lower arms and triangulate them so they either meet over top or beneath the differential housing or on the other side. A little more to it, but that's it in a nutshell. Getting rid of the track bar results ina smoother ride and less binding. Generally speaking.
dmgiff is offline
post #29 of 58 Old 01-05-2012, 10:08 PM Thread Starter
dmgiff
Well, it is stock as far as length, but I have Currie lowers, Rough Country springs, track bar and uppers. I also have ACOS spacers on springs due to my heavy Warn 8274. I plan to put my new Currie front springs and track bar on and then see where I'm at. I am going to take off the ACOS stuff and hopefully it will ride much better. I am going to shoot for 9-10" of travel in the front. As soon as I tear it apart and cycle it, I will decide on shocks. I am okay with modifying the mounts to get a longer travel shock in there.
I would like to lessen the front control arm angle either by moving the axle mounts up or by lengthening the arms or both. But I don't want my Jeep down for that long again, so might put it off for awhile.
dmgiff is offline
post #30 of 58 Old 01-06-2012, 05:55 AM
Imped
Imped's Avatar
Triangulated lowers will converge at the frame end and will always be wide at the axle. Triangulated uppers will always converge at the axle. I've never seen it done another way, likely due to some funky numbers that would cause.....especially with converging lowers below the diff, where you'd also experience a huge loss of clearance.
OlllllllO
IndyORV
Imped is offline
4 link
I just learned something noone ever told me! YJsahara YJ Wrangler Technical Forum 12 07-06-2007 06:40 AM
Learned the hard way! soxlover TJ Wrangler Technical Forum 9 05-29-2007 09:44 PM
What I've Learned about a YJ DanaT YJ Wrangler Technical Forum 0 07-03-2004 04:43 PM
Lesson learned.... Level_1 TJ Wrangler Technical Forum 0 11-19-2003 03:12 PM
One more lesson learned mattelderbaum TJ Wrangler Technical Forum 0 04-13-2003 03:26 PM
