Quantcast what gearing for 3 speed auto, 4.0L and 35's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > what gearing for 3 speed auto, 4.0L and 35's?
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 06-16-2008, 08:55 PM   #1
redjeepjunkie
Should I go with 4.10's or 4.56 gears?? Thanks in advance!
97 jeep TJ, 4"lift, 31"tires OllllllO
redjeepjunkie is offline   Reply With Quote
Old 06-16-2008, 09:21 PM   #2
redjeepjunkie
anyone?? sorry i know this has probably been answered before
Old 06-16-2008, 09:28 PM   #3
Maxxram
Gotta Lift It
Maxxram's Avatar
you are going to get some people who like the 4.10's and some who will like the 4.56. I just had 4.10's put in my 97 tj with the 4.0 and 3sp auto. I personally am glad I went with the 4.10 gears. if i went with the 4.56 gears the engine would have been screaming on the highway. Just as an FYI with my 35's and 4.10's im right at 2750rpm at 65mph. Now to be honest their are times when i feel the low end should have a little more power which would be where the 4.56's would be better. But ill give up a little low end for better highway manners. It will all come down to your driving habits and what exactly your looking to get out of it.
Maxxram is offline   Reply With Quote
Old 06-16-2008, 09:36 PM   #4
Rub1c0nLJ
Like Maxxram said, there is no exact match. I'm guessing you currently have 3:73's and the stock tires were 29's. 4:56's would be the closest but your RPM's will be up a little higher. If you are running mainly on the street, 4:10's will probably be better for gas milage. 4:56's will be better offroad. It's just one of those head bangers........
This link will give you a general idea.
http://www.ramblerman.com/blazer/geartabl.htm
Rub1c0nLJ is offline   Reply With Quote
Old 06-16-2008, 09:37 PM   #5
redjeepjunkie
thanks alot. I dont drive the highway very often so i'll probably go with the 4.56s. does alloy usa make good gears? strong long lasting?
Old 06-16-2008, 09:44 PM   #6
Rub1c0nLJ
That is what I am going with...........I've never heard anything bad...
Old 06-16-2008, 09:47 PM   #7
robncar
4.56 is the right choice with 35's, 6-cylinder, and 3-speed auto. AlloyUSA gears should be fine. I run AlloyUSA axles but Superior gears (4.88's), just worked out that way, nothing against AlloyUSA. I've had no issues with the Superior gears.
DON'T FEAR THE RE-GEAR!!!
______
|_____|
(O|||||||O)
|______|
[]===o==[]
RED JEEP CLUB MEMBER #430
robncar is offline   Reply With Quote
Old 06-16-2008, 10:19 PM   #8
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Go with 4.56.
I run that combo and I like it.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 06-17-2008, 12:09 AM   #9
RYANSTULC
If you're not driving on the highway often, 4.56's or 4.88's would be ideal.
What kind of wheel'n do you do in Ohio? Rocks? Mud?
I primarily run rocks, and so my 4.88's matched to 35's and a 3-speed Auto work like a charm.
So to answer your question,,,,if the only choices are 4.10's or 4.56's,,,I would say the latter.
RYANSTULC is offline   Reply With Quote
Old 06-17-2008, 02:08 AM   #10
Greg_Volkman
4.56 is way too tall if you will drive on the freeway. I did this for about 6 years...drove me friggin nuts. I only put about 25K on the jeep in that 6 years because it sucked on the highway so bad running 3K rpm and 60mph. I went back down to 4.10 and am VERY VERY happy with it.
you don't really need super low gears in the diffs for offroad, your auto will make up for that.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote
Old 06-17-2008, 02:46 AM   #11
BoKnows
I think you will be happy with 4.10s if you run hwy more. I run a 3spd auto, 33's, and 4.10s and the RPMs are a little high. I do a lot of hwy driving and look fwd to putting 35s and getting some lower rpms. I agree with Volkman for offroad, an auto and torque converter will give you back a lot of low end power. plus you could have the best of both worlds if you added a 4:1 kit to you TC. Let us know what you go with and how you like it
1997 TJ White
3speed auto, RE Long Arm with ACOS...5" of lift, 35x12.50 PC XAT on 15x8 wheels, Bilstein 5100 shocks, rubicon D44 with front and rear ARBs, AA SYE, Coast CV Driveshaft, 4.10 gearing, ORO Swayloc, ARB Snorkel and K&N filter, magnaflow exhaust, Fabtech front bumper, LoD Xpedition Rear bumper, LoD Rocker Guards, hella lights, 6" Xenon flares, HULA GIRL on dash...........she makes me smile
WWW.MILITARYJEEPERS.COM
WWW.WHEELERSFORTHEWOUNDED.ORG
BoKnows is offline   Reply With Quote
Old 06-17-2008, 03:07 AM   #12
BoKnows
I just re-read the thread and see that you don't drive on highway often....4.56s
Hijack
VOLKMAN, what kind of Mileage you getting with that combo, you think you could pull a 1000lb trailer?
Hijack off
1997 TJ White
Old 06-17-2008, 06:35 AM   #13
jeepgeek2k
Not to hijack, but how big of a difference is it going from 3.07's to 3.73's, and 3.73's, and 4.10's?
You guys have said 4.56's which on a 35" tire, sound right. But I also assume it depends on the tranny too..
I wave.. do you??
No Jeep No Trail!!
There's just something about a Jeep that puts a smile on my face, and my passengers!!
jeepgeek2k is offline   Reply With Quote
Old 06-17-2008, 07:01 AM   #14
BillR
BillR's Avatar
4.10s are the choice! I have that combo, and it's truly ideal for that tranny and tire size. I DO however have a 4:1 for off-road, so that makes a difference. My RPMs are about 3000 at 70, which is just about perfect for the 4.0 engine.
'05 LJ Sport, 6-speed, SwayLoc, LoD bumpers...the build begins!
'11 JK Unlimited Sport S, stock for now...
BillR is offline   Reply With Quote
Old 06-17-2008, 07:30 AM   #15
Wheelin98TJ
JEEP FREAK
4.56 is not to deep for the highway.
3,200 rpm at 70 mph is fine.
The extra low end you get with 4.56 vs. 4.10 is well worth the slight gain in rpm at highway speeds.
98 TJ
Glock Forum
