What gear are you running 4.0, auto 3 speed, 33's - Page 2 - JeepForum.com
post #16 of 26 Old 08-04-2010, 08:50 PM
chilipepperjeep
My 98 auto ran with 33's and 3.73's for a long time and it was actually pretty good on the street, off-road - well not so much. When I upgraded my axle from a 35 to a 44 I debated for a long time what gears to use. I ended up choosing 4.10's and for me they are the perfect compromise. I can run all day on the freeway and the RPM's are OK. Off road the auto hides a lot of the problems of being geared too high.
I also considered keeping the 3.73's and dropping the gearing in the transfer case for off-road. I can't remember why I didn't do that, but it still seems like an idea.
chilipepperjeep is offline
post #17 of 26 Old 08-04-2010, 08:57 PM
blubaru2002
When I had 33's on my jeep with 4.10 gears, the rpms were a little over 3000 rpms on the highway at 70mph. That sucked. In florida heat and working the motor that hard, the coolant temp was always a tad over 210 (more so than most jeeps). Also the floor boards got rediculously hot.
I'm riding on 35 inch tires now with 4.10 gears and couldnt' be happier. If your jeep is a daily driver w/ 33 inch tires and you see the highway a lot, do not get gearing >4.10 IMO.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #18 of 26 Old 08-04-2010, 09:01 PM
SuperWade2
More Money than Brains
SuperWade2's Avatar
Originally Posted by joules102 View Post
I am running 4.56 with the 32RH and 33 in Duratracs. It spins on the highway but the get up and go is really nice. If It was a DD and I never considered going to 35's I would have done the 4.10's.
I ran 4.56's, 3Spd auto and 33's for about 3 years...RPMs too high for long HWY, but I was going to 35's (at now) and didn't drive much HWY.
4.10's if your staying @ 33's....
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #19 of 26 Old 08-04-2010, 09:32 PM
sduncan
sduncan's Avatar
I have 4.10s and ARBs on the shelf waiting to go in. I drove friends a few years back with 4.10s and 33s. Good overall setup..
'98 TJ, 5.7 HEMI,
sduncan is offline
post #20 of 26 Old 08-06-2010, 09:20 PM
88wagon
what is the optimal cruising rpm for the 4.0 with a 32rh. I have the 3.07's with 31's and i hate it I'm debating on throwing down the cash on one of those bolt in 8.8's but I cant decide on 3.73's or 4.10's my jeep never see's speeds over 60mph and is a spare vehicle. I will eventually upgrade to 33's
09 jetta tdi
97 tj 31's
98 xj ssv package
07 yaris hatchback
88wagon is offline
post #21 of 26 Old 08-06-2010, 09:53 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
4:10's...
Knuckelhead is offline
post #22 of 26 Old 08-06-2010, 10:07 PM
1jack5
I have the d44 and 3.73's (all from factory might i add) and 31's, its just about perfect for me, other than the long highway drives. I will do about 70mph at 3,000rpm which is a bit more than I and the Jeep like, especially since we are doing it in Georgia's low country where our heat index is 110.
I will be moving up to 32's pretty soon and hopefully it will be exactly where I want it. It will be the perfect set up for a DD/trail rider. IMO
1jack5 is offline
post #23 of 26 Old 08-06-2010, 10:23 PM
dbbd1
dbbd1's Avatar
4.56 with 33's and the 42RLE (overdrive)
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #24 of 26 Old 08-06-2010, 10:50 PM
b912
I have 32s on my Sahara 5 speed which had a factory D44 with 3.73s that is currently being repaired. This is my DD and that combo was perfect. Was getting 16.5 mpg on my 76 mile commute. I'm running on a temporary D35 with 3.07s right now and it is downright horrible. From the top of 4th gear on, I can't get out of my own way, now get 12 mpg, and and loose speed on the slightest incline. One thing to consider with regearing is that your auto currently has 3.07s in it. To go to any of these gears, you'll not only need the $180 ring and pinion set and the $120 master install kit, but you'll also need a new carrier which is another $100. That's $400 in parts and anywhere from $250-$500 to set it up if you can't do it yourself. This is per axle! A D35 just isn't worth that much investment. If you found a resonably priced D35/D30 combo with 3.73 or 4.10, then fine, but I wouldn't try to convert one to that.
b912 is offline
post #25 of 26 Old 08-07-2010, 05:53 AM
tw_jeep
I have had 33s, 3spd and 3.73s in mine. It's not too bad but there are times when I wish i had a somewhat lower gear ratio like the 4.10s - esp when towing the jet-ski or loaded for camping...
I'd go with 4.10s
2000 TJ Sport/auto/D44/X8000i & Tomken mount/jeeperman rear bumper and rails/Skidrow steering skid/RE 3.5SF/33x10.5x15ATKOs/JB Conversions SYE/CV shaft/BESTOP tire carrier/AtoZ front bumper/Front Aussie Locker/some aesthetic stuff/
tw_jeep is offline
post #26 of 26 Old 08-07-2010, 06:30 AM
dodgetk81
33's and 4.10 for me. No regrets
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco
dodgetk81 is offline
gear , recommendation , 33 , 4.0 , tj , wrangler , automatic
3.07 gear w/ 33's - auto trans outlanderbz TJ Wrangler Technical Forum 57 06-21-2011 01:36 PM
33's or 35's with an auto DD and what gear ratio? tweba99 JK Wrangler Technical Forum 18 01-07-2009 07:52 PM
auto 3spd, 33's, 4.10's: Top speed? Snuffster TJ Wrangler Technical Forum 7 01-31-2006 10:28 PM
4 speed auto, 33's, what gear do you have? madmax TJ Wrangler Technical Forum 17 10-20-2005 01:18 AM
Running 32's with 3.07 gears and 3 speed auto? zach1288 TJ Wrangler Technical Forum 12 10-08-2005 09:04 AM
