what gear oil should i use after break in? - JeepForum.com
post #1 of 4 Old 04-08-2007, 03:01 PM Thread Starter
magnum629
what gear oil should i use after break in? I have about 750 miles on my gears and i will be changing my gear oil on tuesday. I have dana 30/35 with 4.10s and open rear would mobile1 - 75-90 be ok? I would like to get something that will last thats why I was looking at the mobil1
khaki 2005 TJ 6 speed dana 30/35 4.10 gears 2 inch skyjacker BB lift 1 inch body lift 33 inch kumho mud TAs 15x8 mickey thom classic 2s wheels flowmaster 40 rear tube bumper
magnum629 is offline
post #2 of 4 Old 04-08-2007, 05:27 PM
MoJeeper
2009 JK Wrangler
I will problably put the cheapest 80-90 i can find in mine, thats what what i had before. So it should work now.
09 JKU Sahara
MoJeeper is offline
post #3 of 4 Old 04-08-2007, 05:42 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
As long as it's a GL-5 gear lube, and most are, just about any good brand is fine. Valvoline, Havoline, Mobil, Mobi-1, Chevron, Shell, etc. are all fine. If you tow, use a heavier viscosity like 80W-120 pr 90W-140, otherwise a 70W-80, 75W-90, 80W-90 is fine.
Jerry Bransford is offline
post #4 of 4 Old 04-08-2007, 06:04 PM Thread Starter
magnum629
thanks Jerry!
Break in front gear set? mobyjeep TJ Wrangler Technical Forum 1 07-24-2009 07:38 PM
New Gear Break In..When to Do Initial Gear Lube Change?? Jim93YJ YJ Wrangler Technical Forum 8 10-14-2008 07:59 PM
Spider Gear Missing a Tooth After Re-Gear Break-in Period beertinted TJ Wrangler Technical Forum 2 06-20-2007 01:34 PM
gear break in joe00tj TJ Wrangler Technical Forum 8 03-03-2006 08:39 AM
Gear break-in? TheDuke05 TJ Wrangler Technical Forum 4 08-04-2005 05:09 PM
