What is an exciter ring? - JeepForum.com
post #1 of 5 Old 07-21-2010, 10:40 AM Thread Starter
richla
Hi gang:
I have my '95 TJ in the shop to get the front axle u-joints replaced. Mechanic called my wife at home and said "his fault, he broke the exciter ring, and he will fix it, but it will take a bit longer"
O.K., what the heck is an exciter ring?? ( I searched, found very little)
richla is offline
post #2 of 5 Old 07-21-2010, 10:49 AM
mdm
Farm Wheeler
He is no doubt talking about what the FSM calls the "tone wheel" and is also called a "tone ring" by some. It is the notched ring (looks kind of like a gear) that is mounted on the axle shaft just inboard of the unit bearing. It is part of the ABS.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 5 Old 07-21-2010, 10:52 AM Thread Starter
richla
O.K., mdm, THAT makes sense, never heard it called that before.
Thanks again
Rich
richla is offline
post #4 of 5 Old 07-21-2010, 11:17 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I think he was hitting on your wife.
TheBoogieman is offline
post #5 of 5 Old 07-21-2010, 11:20 AM Thread Starter
richla
I'm safe. She prefers a man with teeth. (although he is a better mechanic than I am)
richla is offline
axle , u-joint , u joint , exciter ring , tone ring , TJ
(D30) new ring gear bolts won't fit into new ring gear sportcoupe TJ Wrangler Technical Forum 14 08-21-2010 02:10 PM
? about d ring 4.3jeepyj YJ Wrangler Technical Forum 15 07-13-2007 09:39 PM
Lock Ring Pliers/ Snap Ring Pliers for SYE method84 TJ Wrangler Technical Forum 20 12-18-2005 06:36 PM
Snap Ring/Retaining Ring Pliers SYE Install mking7 TJ Wrangler Technical Forum 7 09-29-2004 10:55 AM
D-ring ??? Bucket110 TJ Wrangler Technical Forum 4 08-18-2003 02:15 PM
