What exactly does error code 55 mean? (completion of fault code display on the CEL) - JeepForum.com
post #1 of 4 Old 11-03-2009, 10:22 PM Thread Starter
Tkahne88
I just had my PCM replaced and a day later the jeep is acting up again, like it did before. but this time it actually displayed two codes.
code 12- which means battery disconnect- direct battery input to the pcm was disconnected within the last 50 key on cycles.
and
code 55- N/A- completion of fault code display on the CEL
does 12 basically mean that the battery cable was disconnected from PCM, like when they disconnected the old and installed the new?
and I have no idea what 55 means? there are more issues with vehicle than able to display? i dont know.
but anyways I decided to check the codes because it takes a couple key on's to turn the jeep over. then when it does it doesn't start up strong.
Tkahne88 is offline
post #2 of 4 Old 11-03-2009, 10:29 PM
Sobie
Bolt-on Maniac
Sobie's Avatar
Yes and no.
12 is the cable was disconnected recently.
55 means there are no problems.
USAF
Sobie is offline
post #3 of 4 Old 11-04-2009, 01:39 AM
Jonny Jeep
Jonny Jeep's Avatar
55 means end of codes. No more codes stored. Problem codes, if any, will have been displayed before that.
Jonny Jeep is offline
post #4 of 4 Old 11-04-2009, 08:46 AM Thread Starter
Tkahne88
Ok, thanks. well since the PCM was the issue before and displayed no codes I believe its possible its happening again. just this time I'm catching it before its completely dead
Tkahne88 is offline
Fault Code 51 FrozenRaz TJ Wrangler Technical Forum 5 12-07-2009 05:07 PM
fault code 27 ??? 1stJeepyj YJ Wrangler Technical Forum 5 07-08-2009 05:49 PM
how to display error code in TJ? CptTrips TJ Wrangler Technical Forum 7 03-15-2006 02:52 PM
What is this fault code REVNITUP TJ Wrangler Technical Forum 4 12-06-2005 10:13 PM
Fault code bcmopar TJ Wrangler Technical Forum 1 09-23-2004 09:42 PM
