What else do I need besides the lift? - JeepForum.com
post #1 of 15 Old 09-08-2013, 08:21 PM Thread Starter
YellowJeepGuy
Ok so I decided im going to pull the trigger on a lift. I got a 04 Jeep wrangler with 31in mud tires. I have decided to go with a 2 inch spacer lift with a 1in budget booster lift. It will give me the look and height I'm looking for without breaking the bank. Now since that is a total of 3 in lift I need to get 3in shocks right? Also what else do I need besides the lift? I don't need a new drive shaft do I?
YellowJeepGuy is offline
post #2 of 15 Old 09-08-2013, 08:50 PM
tyvanwie
Wait what? You're putting on a 2" budget boost and a 1" budget boost?
tyvanwie is offline
post #3 of 15 Old 09-08-2013, 09:07 PM Thread Starter
YellowJeepGuy
2 inch spacer lift and a 1inch body lift
post #4 of 15 Old 09-08-2013, 09:11 PM
pmcjeep
You dont add the bodylift into your shock choice.
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline
post #5 of 15 Old 09-08-2013, 09:30 PM
Spud100
3 inches is kinda high for 31s.
Spud100 is offline
post #6 of 15 Old 09-09-2013, 07:24 AM
ctorres018
1930 JK Wrangler
You need to read more on thus forum that's what you need.
http://www.jeepforum.com/forum/f22/light-sleeper-2-0-a-1800073/
ctorres018 is offline
post #7 of 15 Old 09-09-2013, 11:19 AM Thread Starter
YellowJeepGuy
I have been. Send me some links
post #8 of 15 Old 09-09-2013, 11:49 AM
IslandHopper
Lifting the tub above the frame doesn't affect the distance between shock mounting points.
Many people will do 2" spacers with stock shocks. But if you need new shocks anyway, it would make sense to get the "right" length...
Nothing else would be "needed" unless you have other worn out components. (Well, you'll need alignment adjustments.)
There is a POSSIBILITY at 2" that you could introduce driveline vibrations, which could be "fixed" by dropping the transfer case by 1/4 - 1/2 inch... so for that you'll need a handful of washers.
IslandHopper is offline
post #9 of 15 Old 09-09-2013, 12:03 PM Thread Starter
YellowJeepGuy
Wouldn't the 2 inch spacer lift wear the shocks faster. I really don't want to get new shocks unless I have to. 5000 miles ago I bought some Offroad shocks that were $80 each
post #10 of 15 Old 09-09-2013, 12:46 PM
biffgnar
biffgnar's Avatar
Confusing post. Your first sentence is true if talking about body lifts but if talking about coil spacers then it isn't true. Then you finish up by talking about change in driveline angles which body lifts don't affect but which coil spacers do.
Romney in 2020!
biffgnar is online now
post #11 of 15 Old 09-09-2013, 01:56 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
I swear I saw this before, today even. LOL
2" BB and 1" BL will need 2" shocks (BL doesn't effect suspension) and bump stops (length depending on tire size). You can upgrade control arms, track bars if you want but not needed. 3" is kind of high for 31s but will work. You don't need to mess with drive shafts for 2"
RnEmOvr is offline
post #12 of 15 Old 09-12-2013, 06:13 PM Thread Starter
YellowJeepGuy
Do I need a MML for a 1in BL?
post #13 of 15 Old 09-12-2013, 06:19 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
the BB is independent of the MML. the BL and MML usually go hand in hand so you don't have to do other mods that come with separating the motor and body. but the BL and MML do not have to be done together, but it's simpler that way.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #14 of 15 Old 09-13-2013, 10:34 AM Thread Starter
YellowJeepGuy
Ok I'll probably do both. I don't want to lower the transfer case and have weird vides on my engine
post #15 of 15 Old 09-13-2013, 06:04 PM
IslandHopper
You're right... I did a poor job of articulating my ideas.
Lifting the tub changes NOTHING in the suspension.
If you lift the SUSPENSION, then the rest of the post applies.
My Bad, but I'm not gonna let that stop me from posting while drinking!
lift
