what does Trail Rated mean - JeepForum.com
post #1 of 19 Old 12-02-2010, 09:20 AM Thread Starter
yamaha450
just got my frist jeep and have lots of question. i'll start with a couple; what does trail rated mean? also my jeep has 31" tires and my speedometer is off, how much trouble is that to fix and how? thanks
yamaha450 is offline
post #2 of 19 Old 12-02-2010, 09:27 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Trail Rated is really just a marketing thing added several years ago, it doesn't mean a Jeep with a Trail Rated badge has any better offroad capability than an earlier version without the Trail Rated badge.
And yes, a larger tire size will throw your speedometer off. It is easily recalibrated with a new speedometer gear that snaps into the gear holder mounted onto the side of the transfer case. The following link will show you how to do the gear swap which only takes a few minutes with nothing more than a 1/2" wrench. You will need to know your axle ratio to know what speedometer gear tooth count to go with. You can find your axle ratio stamped onto a small metal tag bolted onto your axle's differential cover at its 9 o'clock position. It will say 3 07, 3 55, 3 73, or 4 10 or within .01 of those ratios.
Changing Your Jeep Speedometer Gear
When you get to that page, click on the chart to make it big enough to read. And a big welcome to JF.
Jerry Bransford is offline
post #3 of 19 Old 12-02-2010, 10:47 AM Thread Starter
yamaha450
thanks
post #4 of 19 Old 12-02-2010, 12:09 PM
AVNINE
Trail rated mean it has successfully run the "rubicon trail" without winch or help from another vehicle.
....At least it used to mean that.
AVNINE is offline
post #5 of 19 Old 12-02-2010, 12:22 PM
stwilson74
stwilson74's Avatar
??? says who?
Its a marketing thing, back in 2004 they basically took a list of specs that their vehicles already met and called it trail rated... vehicle has to be able to articulate so much and ford water of a certain depth and blah blah blah...
Jeep - 4x4 Basics - Trail-Rated Certification - 4WD SUVs
"Betsy" 2005 Unlimited Rubicon Sahara Edition #603 of 1000
Originally Posted by Necromancer_tat View Post
I like having my panties in a wad though, because when I get DW they rub me in just the right way! :D Wadded panties plus DW equals Jeepgasm! :D :kiss:
stwilson74 is offline
post #6 of 19 Old 12-02-2010, 12:46 PM
AVNINE
Yea specs they took from the original vehicles they tested on the rubicon trail. I'm at work can't find it now. Will post up link later.
AVNINE is offline
post #7 of 19 Old 12-02-2010, 01:04 PM
stwilson74
stwilson74's Avatar
Ok, I don't remember that but then again I have forgotten more important things... (anniversary...)
I thought Trail Rated was always a fairly arbitrary thing. I thought the only Jeep they actually tested on the Rubicon were the original first year of the Rubicon TJ's... hence the name Rubicon. Like I said though, it wouldn't surprise me a bit if I am wrong on this one.
Bottom line for the OP though, its just an excuse to put a badge on the Jeep thought up by some marketing genius... I just don't understand why they only put em on the driver side... LOL
post #8 of 19 Old 12-02-2010, 01:13 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
GOLENJEEPTJ is offline
post #9 of 19 Old 12-02-2010, 01:34 PM
lancetkenyon
What does the badging mean? Absolutely nothing. Just something else to scrape off the side.
lancetkenyon is offline
post #10 of 19 Old 12-02-2010, 01:37 PM
stwilson74
stwilson74's Avatar
yep, this was in post 5... not seeing anything there that says anything about the Rubicon trail though...
post #11 of 19 Old 12-02-2010, 01:37 PM
LostJeeper
It means you just spent 15 bucks for that badge. lol look at the paper work from when jeep was new it says right there lol
Armed Forces Jeeps
MT WAVE SAR
KF7IRO
LostJeeper is offline
post #12 of 19 Old 12-02-2010, 02:08 PM
kd006
"Mrs. Olsen Hushes A Husband (Try Folgers. The Mountain Grown Coffee. Mountain Grown For Better Flavour.)" (1957)
Mad Ave strikes again.
kd006 is offline
post #13 of 19 Old 12-02-2010, 02:25 PM
Brian86992
Mine doesn't have a badge, but wooo does that baby go
What do you think would give me a better performance gain? front locker, 35's or a Trail Rated badge?
Brian86992 is offline
post #14 of 19 Old 12-02-2010, 02:29 PM
JeffBowser
Shortening your air intake tube?
JeffBowser is offline
post #15 of 19 Old 12-02-2010, 02:32 PM
Brian86992
Don't hate on the ghetto snorkel
I've got a real one now
Trail rated my *** Frenchy905337 TJ Wrangler Technical Forum 7 06-15-2010 09:58 AM
Trail Rated? Omega5 TJ Wrangler Technical Forum 26 12-09-2008 05:36 PM
Trail rated basscj7 TJ Wrangler Technical Forum 15 12-02-2007 08:08 PM
Trail Rated sccabrian TJ Wrangler Technical Forum 44 03-14-2007 08:02 AM
Trail Rated redrubi04 TJ Wrangler Technical Forum 12 12-30-2003 05:00 AM
