What do you guys use to change the tranny fluid and xfer case fluid?? - JeepForum.com
post #1 of 12 Old 12-14-2004, 11:32 AM Thread Starter
Wheelman
Wheelman's Avatar
I got all the fluids, got under my jeep, and realized i have no idea how i am going to get these drain and fill plugs out that have square holes in them...They are alot bigger than even the 1/2' drive wrench i have
2006 Silverstone Nissan 350Z
6 Speed|Bone Stock
Wheelman is offline
post #2 of 12 Old 12-14-2004, 03:13 PM Thread Starter
Wheelman
Wheelman's Avatar
Anyone? 10 characters
6 Speed|Bone Stock
Wheelman is offline
post #3 of 12 Old 12-14-2004, 03:53 PM
Dogman
Dogman's Avatar
Not sure about the Tranny, I have the AX-15 in mine. But the Transfercase drain/fill plug is a hex bolt, I can't recall the size though.
John 3:17
Dogman is offline
post #4 of 12 Old 12-14-2004, 05:19 PM
y-hike
http://www.4x4xplor.com/trannyservice.html
99 TJ 4.0 33" BFG Mud-Terrains
4 1/2" Rubicon Express Superflex
EZ Locker Front & Rear 8.8 Detroit Locker
OBA & OBW
y-hike is offline
post #5 of 12 Old 12-14-2004, 05:30 PM Thread Starter
Wheelman
Wheelman's Avatar
Guess I'm crazy, and they are allen bolts, I will go to sears and pick up a 10mm and a 17mm.......what about the transfer case??
6 Speed|Bone Stock
Wheelman is offline
post #6 of 12 Old 12-14-2004, 06:47 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
t-case should be 10mm allen bolts, too...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #7 of 12 Old 12-14-2004, 06:55 PM
Dogman
Dogman's Avatar
Also, I don't know about everyone else, but the next time I do it, I'm going to take off the skid, or come up with a better plan than to just let the fluid drain into the skid. That was messy
EDIT: talking about the transfer case...
John 3:17
Dogman is offline
post #8 of 12 Old 12-14-2004, 07:03 PM
Stu Olson
Stu Olson's Avatar
Dogman....tin foil is your friend in times like these. You can be creative with it and get the oil to go where you want.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #9 of 12 Old 12-14-2004, 07:13 PM
Dogman
Dogman's Avatar
Yeah, good idea! Thanks Stu, love the site. And the dog
John 3:17
Dogman is offline
post #10 of 12 Old 12-14-2004, 07:51 PM
Stu Olson
Stu Olson's Avatar
Thanks! The dog is a purebred pitman. You get one of those by having a doberman as the father and a pitbull as the mother.
Stu Olson
ARB Locked & Loaded
post #11 of 12 Old 12-15-2004, 03:28 PM
RWB214
RWB214's Avatar
If I recall correctly my Dana 30 had a square plug.. but the 3/8 drive socket wrench with no socket fit perfectly.
RWB214 is offline
post #12 of 12 Old 12-15-2004, 03:33 PM
FlexyTJ
FlexyTJ's Avatar
10 mm hex on the xfer case. I use a humongous allen key.
3/8" square on the diffs- my 3/8 socket/extensions fit it perfectly.
MK Motorsport & Fabrication
FlexyTJ is offline
Need to change tranny fluid in my ax-15 soon any tips? fluid to use? Mitchin TJ Wrangler Technical Forum 37 07-04-2010 01:06 PM
Xfer Case & Tranny Fluid Type? 5artist5 TJ Wrangler Technical Forum 2 01-05-2009 12:22 PM
Trans /Xfer case fluid change Brew461 TJ Wrangler Technical Forum 4 01-01-2007 03:36 PM
X-fer case and Tranny fluid change. need help Gabe TJ Wrangler Technical Forum 5 12-26-2006 10:52 PM
xfer case fluid? benvh TJ Wrangler Technical Forum 2 07-11-2006 08:42 AM
