What did you do to your TJ today? - Page 990 - JeepForum.com
 1229Likes
post #14836 of 114054 Old 11-29-2008, 09:08 AM
marylandjeeper
i just installed a tow hook on the drivers side rear per the instructions on stu's site. should i install one on the passenger side or is one enough? i only ask because it seems like i'd have to remove the plastic end caps off the rear bumper to get the passenger side one to fit...at a 45 deg. angle it pretty much touches the bumper and would make getting a tow strap on there impossible. is one enough?
marylandjeeper is offline
post #14837 of 114054 Old 11-29-2008, 09:34 AM
JEEP97TJ
One is better than none. I did the driver's side first, (harder to install), then decided to put one on the passenger side also. From the factory, TJ's only came with one hook on bottom the driver's side framerail
Blacksburg, VA
JEEP97TJ is offline
post #14838 of 114054 Old 11-29-2008, 09:37 AM
rikkards
rikkards's Avatar
Really? I found the passenger side harder with the exhaust pipe being somewhat in the way. Well more annoying anyways
rikkards is online now
post #14839 of 114054 Old 11-29-2008, 10:33 AM
marylandjeeper
i'm gonna rock it with one and see how it goes.
post #14840 of 114054 Old 11-29-2008, 10:37 AM
RVA_TJ06
Installed RC Winch plate, Superwinch Epi9.0 w/ Synthetic rope, some RE 4.5" springs and a 3/4" spacer.
Finally paid off...
RVA_TJ06 is offline
post #14841 of 114054 Old 11-29-2008, 10:59 AM
vtjeepguy97
Used it to be the DD last night. Had to pull out the my rear cargo rack to fit the seat in. Really was a pain.
vtjeepguy97 is offline
post #14842 of 114054 Old 11-29-2008, 11:04 AM
marylandjeeper
are you running the stock front bumper? how did everything look mounted up? thinking about the same thing...
post #14843 of 114054 Old 11-29-2008, 11:10 AM
RODDOR
I re-enforced the rear crossmember to make the rear swingout more solid, made an air tank out of the rear bumper and made a mounting system for my pull-pal on the on the swing out. I also relocated the quick release mount for my my rear mudflaps. Actually took a couple of days.
RODDOR is offline
post #14844 of 114054 Old 11-29-2008, 12:59 PM
rikkards
rikkards's Avatar
Drove it to the grocery store to do groceries. Definitely not the best vehicle for that role but definitely the most fun
post #14845 of 114054 Old 11-29-2008, 01:11 PM
Imped
Imped's Avatar
Parked it and am "borrowing" the grandma's BMW for a week. I love my jeep more than just about anything but wow....soooo smooth and fast.
OlllllllO
IndyORV
Imped is offline
post #14846 of 114054 Old 11-29-2008, 01:14 PM
RobFromRI
Installed an Old Man Emu Steering Stabilizer...
OME vs. OEM
1999 Jeep Wrangler TJ 4.0 5 Speed Chili Pepper Red
2003 VW GTI 1.8T 6 Speed
Jazz Blue 20th Anniversary Edition #3177 of 4000
RobFromRI is offline
post #14847 of 114054 Old 11-29-2008, 02:28 PM
dale88
OME vs. OEM
Mmm beefy!
02 Jeep Wrangler
2.5 cyl 2" lift 235/75/15 Goodyear tires.
If you aint jeepin you should be sleeping
dale88 is offline
post #14848 of 114054 Old 11-29-2008, 02:50 PM
RVA_TJ06
Yeah I'm running the stock bumper.. I've never posted a pic of my jeep here but I'll post on tomorrow.. it was a pain to get the hawse mounted to the plate and have the winch fit.. (if I was at the shop I could've done it quicker with a cutting tool) but I had to cut th bolts that go through the front in half as well as the nuts.. let's just say my right arm was tire from the hacksaw. It looks really good.
Finally paid off...
RVA_TJ06 is offline
post #14849 of 114054 Old 11-29-2008, 02:54 PM
Du510
I just found this thread - I like it!
Its funny you guys mention above about groceries.... on the 23rd of Nov, the wife was wicked sick and this was the shot:
I took that photo and emailed to a jeeping buddy of mine with the caption "seriously, what the f..."
But today, I set up some toolboxes & my recovery gear bag, and mounted the HiLift on the cage using 2-1/8" muffler clamps. Works pretty well, wicked tight with no rattle... too dark for photos though.
New solenoids for the winch arrive Monday, so that's coming up next.
Du510 is offline
post #14850 of 114054 Old 11-29-2008, 03:13 PM
BomberJeep
2011 WK
I did an oil change and changed my spark plugs. She runs much better now
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline
modifications , tj
WinterJeep
