What did you do to your TJ today? - Page 896 - JeepForum.com
 824Likes
post #13426 of 113386 Old 09-17-2008, 08:35 AM
JA66
Originally Posted by NeoAnderson View Post
Cut off some excess threads off a bolt holding my swaybar link on as it was rubbing on my frame making a moose in heat sound.....then i farted and went back in the house.
Oh pleasant.
Originally Posted by peeweeXJ View Post
Got my 5 31" Maxxis Bighornies mounted and balanced to replaced my Mickey T MTZ's.
Are you sure your tire wasnt flat and you hadn't noticed? Maybe you ran over a nail while driving and it went flat. Cause it sure looks like a flat tire blow-out.
As for my jeep, absolutely nothing, im at college without my jeep
JA66 is offline
post #13427 of 113386 Old 09-17-2008, 08:59 AM
snsedwards
snsedwards's Avatar
2011 JK Wrangler
Dropped it off at the shop to have all of the brake lines replaced
You got that?............ Good!
snsedwards is offline
post #13428 of 113386 Old 09-17-2008, 11:34 AM
joker713
Originally Posted by silverjeep View Post
Built and installed a hydrogen generator in my LJ. Let's see if it helps with the mpg.
So? What were the results? I've been thinking about this a lot recently since gas is the way it is...
joker713 is offline
post #13429 of 113386 Old 09-17-2008, 12:56 PM
stadleroux
stadleroux's Avatar
So I actually did pick up my tow bar from the dealership today, and it came with two different-sized hitch balls and two receiver plugs, hehehe...
It came with the smaller ball and the one plug included in the large box, and then they also gave me the wiring and a bigger ball in a "fitting kit," and an extra plug in its own injection moulded packet, just like you would buy it off the shelf. I guess they give us a spare over here because they know how quickly the original one would disappear in what we call affirmative shopping!
I think the bigger ball is the local requirement over here, but now the threaded shaft is also significantly thicker, so I'm wondering if it would be safe to have the hole in the tongue enlarged. Surely that would weaken the tongue? Gonna give them a call tomorrow.
stadleroux is offline
post #13430 of 113386 Old 09-17-2008, 01:55 PM
A2SuperCrew
Ouch! What did THAT run you?
2000 Jeep Wrangler SE 2.5L Automatic
Black Jeep Society Member
A2SuperCrew is offline
post #13431 of 113386 Old 09-17-2008, 03:20 PM
FL 4.0L
Sweet. 901 pages, but you're the first to admit it!
'97 TJ Sport, 4.0L, AX-15, D30/35, BFG TA KO 183K
'12 F30, '03 E46, '06 Rabbit, '13 Jetta
FL 4.0L is offline
post #13432 of 113386 Old 09-17-2008, 04:20 PM
littledevilTJ
got my Banks exhaust installed today. i was worried it was going to be loud and obnoxious because its a straight through muffler but it sounds amazing and not too loud... got that done then went to play in the rocks near a retention pond. nothing serious but just to mess around in... heres a pic i took when i stopped for a sec...
littledevilTJ is offline
post #13433 of 113386 Old 09-17-2008, 04:23 PM
alecmcmahon
in the middle of installing my rough country 2.5" suspension lift.
question
the bump stop fell out while trying to jam one of the new springs in, and i am finding it impossible to shove it back in. any tricks?
gotta run to harbor frieght now to buy a spring compessor, i'm never going to shove that in without it!
alecmcmahon is offline
post #13434 of 113386 Old 09-17-2008, 04:31 PM
Camo Deere
Camo Deere's Avatar
Took it to a friend's house and did a little mudding.
And filled her up with gas(ouch).
Camo Deere is offline
post #13435 of 113386 Old 09-17-2008, 04:33 PM
TJ-xtreme
If you have an auto zone near by you can rent the spring compressor for free...
Also, If you just remove th bumpstops and retainers and set them inside the spring it will be easier to get the spring in. then bolt on the retainer and use something against the spring to pry the bumpstop back into place...
2001 TJ Sport w/ D44, 2.5" Susp. lift,1" BL w/ MML, 35x12.50 BFG KM2's on 15x8 Soft 8's, Smittybilt XRC Front Bumper and Rocker Guards, S/B SRC Rear Bumper, Xenon 4" Flat Flares, JKS Disconnects, 48" Hi-Lift Jack, OBA System, Optima Blue Top, Hella Lighting. More on the way... ;}
JEEP= Just+Empty+Every+Pocket.....
EAT-SLEEP-JEEP OlllllllO
TJ-xtreme is offline
post #13436 of 113386 Old 09-17-2008, 04:35 PM
littledevilTJ
alecmcmahon... spray some lithium grease on it and push it in really hard and twist at the same time
post #13437 of 113386 Old 09-17-2008, 04:44 PM
2005X
let my wife drive it to work
2005X is offline
post #13438 of 113386 Old 09-17-2008, 05:01 PM
Panici
(O|||||||O)
Panici's Avatar
-Changed the oil using Royal Purple full synthetic 10W30 and a Napa Gold filter
-Greased all the zerks using Green Grease
-Washed out the frame, getting all sorts of rocks and dirt out of there!
-Took off the front wheels and started fixing up the surface rust on the frame. I wire wheeled the problem welds and spots, and then shot them with semi-gloss Rustoleum.
-I also quickly painted the hub assemblies, after blowing off the flaking rust with high pressure shop air (impossible to get the die grinder in there!)
_______
|_
_|
(OlllllllO)
Panici is offline
post #13439 of 113386 Old 09-17-2008, 05:14 PM
rikkards
rikkards's Avatar
mounted a 5lb fire extinguisher at the base of the driver seat ala the Geezer jeep (Jerry Branford).
The only catch is that his driver seat isn't ez-entry while mine is which makes it a little more difficult as there is less metal lower on the bracket to put a hole through. I ended up using a 2" wide bar where he had used a 1" and bolted it higher up. It works.
rikkards is online now
post #13440 of 113386 Old 09-17-2008, 05:16 PM
Pvt_Joker
Originally Posted by reverie02tj View Post
installed the rough country 2.5" lift, next week: locker for the d30
breakage waiting to happen
Pvt_Joker is offline
modifications , tj
AlpineBB , beber , carrotman
