What did you do to your TJ today? - Page 89 - JeepForum.com
 816Likes
post #1321 of 113367 Old 05-25-2006, 06:23 PM
tommaho
tommaho's Avatar
Got my staun deflators, Skyjacker shift bracket (for bellyup), and bug screen. Mounted the bug screen and set up the stauns.
Tom
tommaho is offline
post #1322 of 113367 Old 05-25-2006, 06:41 PM
FmrVette
FmrVette's Avatar
2008 XK Commander
Put in the third brake light riser and got legal. At least temporarily.
Jim
"Basically, I'm for anything that gets you through the night - be it prayer, tranquilizers or a bottle of Jack Daniels. - Frank Sinatra
"When the last Blackhawk helicopter goes to the boneyard, it will be on a sling under a Huey." - Every Huey pilot that lived through it.
'95 YJ, '00 XJ, '06 TJ, (Current:) '08 XK
FmrVette is offline
post #1323 of 113367 Old 05-26-2006, 01:00 AM
AWILD
AWILD's Avatar
Pulled the carpet and sprayed down the inside of the tub.
TJ
4.0L, 5spd, 2"BB, 31x10.5 Mud Terrains, Black Steelies,Hella 100W, Custom Brushguard, IPF H4 housings w/ Fatboys, Sirius 23 Hair Nation!
AWILD is offline
post #1324 of 113367 Old 05-26-2006, 01:04 AM
Red_
2016 KL Cherokee
Started rebuilding my front DS
Red_ is offline
post #1325 of 113367 Old 05-26-2006, 02:51 AM
wheelinman03
I had the joy of replacing a yoke because and a u-joint. all because the U-joint blew up and munched the yoke.
98 TJ- Kilby gastank/ steering box skids, Sky jacker high clearance tcace skid, 1'' BL, M.O.R.E. 1" MM's, Poison spyder rocker guards and sport cage, Warn XD9000i on A to Z fab Winch plate, RE 2" BB, Nth Diff slider, Quick disco's, PSC Rock Ring, JB Conversions Super short SYE kit, and a burly CV Drive shaft.
LOTS more to come
I wave, Do you?
wheelinman03 is offline
post #1326 of 113367 Old 05-26-2006, 06:57 AM
ATL TJ
Originally Posted by AWILD
anymore info on that 3rd brake light"?
It's a 2-wire sealed LED brake light from eBay for $20 shipped. I tapped into the 6-wire harness behind the passenger side taillight...black to black and white to red. And I removed all the stock 3rd brake light wiring and pieces in the tub since it's not used anymore.
If you look closely in the first pic, you can see the LED strip mounted to the body...it's between the swing out and the bumper. I have a 1" body lift so the spacing was perfect.
ATL TJ is offline
post #1327 of 113367 Old 05-26-2006, 03:52 PM
deathbynosleep
put 1.5" seat risers in my girls jeep. I was going to do this a few weeks ago, until i started losening the bolts only to realize i needed a T-50(which i did not currently own) All in all it was really easy.
-Tim
deathbynosleep is offline
post #1328 of 113367 Old 05-26-2006, 05:35 PM
CalRanger
Adjusted the front upper control arms for more caster and better steering on road.
Also put in my new Husky Liners.
04 Rubicon , Solar Yellow
RE 4.5 SF , 33" MTRs
KOZ Bumpers
CalRanger is offline
post #1329 of 113367 Old 05-26-2006, 05:49 PM
ZoomZoom
ZoomZoom's Avatar
Took the hard top off. Put on the safari top and the duster cover. I'm sure it will rain now!
Blue Jeep Club Member # 53
2001 Steel Blue Wrangler 4.0 Sport, Pioneer DEH-P4600 CD Player, Memphis Speakers, Dual Tops, Duster Cover In The Summer, Mastercraft Grab Handles, Bestop Modular Rack, Tuffy Security Glove Box, Olympic Grill Guard and Brush Guard.
My Other Vehicle Is A Cannondale!
My Work Vehicle Is An Ambulance!
ZoomZoom is offline
post #1330 of 113367 Old 05-26-2006, 05:50 PM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
Purchased an Avenger supercharger.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #1331 of 113367 Old 05-26-2006, 06:07 PM
LSUswanny
changed the starter
Geaux Tigers!
LSUswanny is offline
post #1332 of 113367 Old 05-26-2006, 06:59 PM
Red_
2016 KL Cherokee
Finished rebuiling my front DS, no more birdys....
Red_ is offline
post #1333 of 113367 Old 05-26-2006, 08:35 PM
imblown-ru
i broke my front track bar and absolutely covered my jeep in nasty peanut butter mud. adjustable trac bar tomorrow.
imblown-ru is offline
post #1334 of 113367 Old 05-26-2006, 11:49 PM
1997 TJ Sahara
I got in my '97 Sahara and drove to Waikiki Beach in Honolulu, parked it, then went snorkeling followed by an hour of sun on the beach (lots of bikinis on the beach I noticed, just in passing of course). When I tired of those activites I got back in my Jeep and drove back home and had a Mai Tai. Yep, you're right, overall today was a real crappy day from a Jeep perspective, but what can I say?
'97 TJ Sahara - 4.0 Liter 6 cylinder; 4" Skyjacker lift; 6" Bushwacker Pocket Flares; 33" X 12.5" BFG A/T's; 15" X 8" Rockcrawlers; Dana 44 Rear & 30 Front; IPF Headlamps; Stainless Steel Light Guards.
1997 TJ Sahara is offline
post #1335 of 113367 Old 05-27-2006, 12:13 AM
GoldenP51
GoldenP51's Avatar
I installed the nerf bars...which look awesome and now I can get in my vehicle a lot easier
And I installed my XM radio and antenna...going to be installing my CB radio probably in the next 4-5 days along with tuffy glove box and auxiliary input adapter.
GoldenP51 is offline
modifications , tj
TXduck , xtreem
