What did you do to your TJ today? - Page 766 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What did you do to your TJ today?
Rough Country Lift Kits and Parts!Father's Day & Moving Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-25-2008, 11:22 PM   #11476
cheapjeep06
new shocks and seafoam
Well, today I finally installed my front 4WD Hardware shocks. Rides a little softer than the stock gas-charged ones.
Also, I did the seafoam thing (in the TB). Never smoked. Didn't notice a change. Engine still ticks.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline   Reply With Quote
Unread 05-26-2008, 12:53 AM   #11477
SGT Superman
SGT Superman's Avatar
Originally Posted by kjs tj View Post
put on my new rocker guards the second to last pair AEV ever made right in the transition to ARB so they are marked as ARB
before
during
after
i still need to put in a bunch of the rivets but that will be a quick job
Beautiful, now clean your doors or dirty the res the the jeep cause that looks horrible.
Now you know, and knowing is half the battle. G.I. Joe!
Green Jeep Club Member #174
GO COUGS!
SGT Superman is offline   Reply With Quote
Unread 05-26-2008, 02:59 AM   #11478
snellav
Originally Posted by 05moabTJ View Post
Installed a new set of EBC yellowstuff front disc brake pads. These things look great and after the break in period I will do a good trail test on them to see if they are as great as everyone who has them on their rig says they are.
Attachment 49034
Attachment 49035
They really are as great as everyone says. Made a huge difference in my braking
00 TJ with a few mods. Hopefully more someday...
snellav is offline   Reply With Quote
Unread 05-26-2008, 08:33 AM   #11479
stacerbob
4" Superlift, 1" Poly BL, 33x12.50x15 Firestone M/T, CD player Had it a week.
stacerbob is offline   Reply With Quote
Unread 05-26-2008, 09:56 AM   #11480
kjs tj
dont worry bout that theyll be coated in dirt and mud without me even tryin to
i also gave her a whole new set of lug nuts to keep this technical
kjs tj is offline   Reply With Quote
Unread 05-26-2008, 01:34 PM   #11481
Tommy R
Geaux Tigers!
Tommy R's Avatar
I bet the snot of my A to Z sliders when I landed on a rock pretty hard.
2001 Wrangler Sport - homemade long arm lift, 4.56s, 35" MTR Kevlars, D30/Lock Right/alloys, D44/Detroit
My Jeep Build Journal
Long Arm Suspension Build
2001 Dodge 2500 4x4 - Cummins
1930 Ford Model A - SBC, 4 speed
Tommy R is offline   Reply With Quote
Unread 05-26-2008, 02:02 PM   #11482
neverbackdown
well i was out on a trail about 2 weeks ago and broke my stock tail light off the back of my jeep so i weent to work with a 4 1/2" hole saw and this is what i ended up with
neverbackdown is offline   Reply With Quote
Unread 05-26-2008, 02:18 PM   #11483
Wamp
No click! Neat look.
Wamp is offline   Reply With Quote
Unread 05-26-2008, 03:19 PM   #11484
neverbackdown
yea its a work in progress
im actually getting ready to install the reverse lights now
any body have anytips on fixing a hard top ?
i cracked mine yesterday wheelin i could kick myself for leaving it on i always take it off but yesterday i left it on and sure enough it made friends with a tree
any advise would be great
Unread 05-26-2008, 03:24 PM   #11485
BloodThirsty
Wash and waxed her!
BloodThirsty is offline   Reply With Quote
Unread 05-26-2008, 04:26 PM   #11486
scottman
2010 JK Wrangler
Washed and waxed last night...
scottman is offline   Reply With Quote
Unread 05-26-2008, 04:41 PM   #11487
JeepinTpr
Since I just bought my 1998 TJ a couple of days ago, I drove with with the top down and the tunes up for the first time!!
JeepinTpr is offline   Reply With Quote
Unread 05-26-2008, 06:54 PM   #11488
BucBall87
Side Mirrors
What and how do you have your side mirrors mounted ??
Originally Posted by Rub1c0nLJ View Post
Installed Rokmen Sliders..............
JEFF
BucBall87 is offline   Reply With Quote
Unread 05-26-2008, 07:21 PM   #11489
Recoil
Recoil's Avatar
1988 MJ Comanche
I repaired a crack and a hole in my hardtop just go to an auto parts store and pick up some short strand fiberglass filler and some glazing putty...scuff and then clean the area well with alcohol. Then mix up the needed amount of fiberglass and apply as smooth as possible. Sand it down once it has set for at least 30minutes then apply a second coeat, allow it to set and the sand to shape. once you have finished that apply a very thin coat of glazing putty (if needed) to smooth out the finish. Once that has set prime and paint with krylon fusion satin black...I did that and it turned out great...looked brand new
www.indyorv.com
EPIC
Recoil is offline   Reply With Quote
Unread 05-26-2008, 07:34 PM   #11490
PBR
During the day I put a new oil pressure sending unit in and replaced my emergency brake shoes.
At night I adj. my antirock, but messed up one of the treads on one of the joints so i had to saw like 1/4" off one the the threads to make the nut go on again! Also realized my front axle is off center to the passenger side by like 1/4". But it doesnt cause any problems. Should i fix it?
It kinda was a bad night working on the jeep, Anyone know where i can get one replacement femiale heim joint for a currie antirock?
PBR is offline   Reply With Quote
modifications , tj
