#10396 | |
Today I figured out why the floor mats that came with my jeep didn't fit... they were for the liberty (used dealer put them in.)
Also wanted to take off the doors antry my newly made mirror... Couldn't get those things off for the life of me.. yes I took off the retaining nut. and the limiting strap. I can't believe how tough this is compared to my last TJ. overall.. day of disapointment.
#10397 |
(O|||||||O)
Got my hands on two cans of seafoam (somewhat of a rarity in these parts), and i'm going to use 1/2 in the crankcase (drive around for 30 mins then change oil), 1/2 through the brake booster, and a full can in an empty gas tank (then fill it to full).
Going to be doing this as part of my spring tuneup, along with oil/filter change, air filter change, and new plugs.
#10398 |
Some Call me RockDog
explain to me what the sea foam is supposed to do again for the record. I've heard several different things.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#10399 | |
(O|||||||O)
#10400 |
Well, let's see. I found jeepforum.com, registered, browsed through answering all sorts of questions I have had for a while, and decided to order a new 6.5" sub for my blown one. Also went out and got an additional cigarette lighter to hide my GPS power cord, and plan to repaint my flares tomorrow. Being unemployed isn't fun, but it gives me time to work on my Jeep.
![]() Oh, and found the West Texas Jeep Club, got info on it, and am going to try to go wheeling in a few weeks. All in all a productive day for the Red Rider (as my kids call it). TexTiger |
#10401 |
added a winch guard w/light tabs and found the right type of rattle cans to simulate the rubicon/textured look in order to match the rest of the bumper and roof rack. now to figure out which lights to add.
#10402 | |
Photographer at heart Have questions about something photography related? Click here!Like Coheed and Cambria? Join the club! My Jeep Build My Photography (New as of Jan. 25th) 1982 Motorcycle Build |
#10403 |
Finally!
Bought it! Got the transmission rebuilt, and put my first 100 miles on it. Yay!
#10404 |
US Army 19D
My LS2 Wrangler build http://www.jeepforum.com/forum/showthread.php?t=540376 Wheelers for the wounded Great cause, check it out http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=320 753688 A democracy is nothing more than mob rule, where fifty-one percent of the people may take away the rights of the other forty-nine. - Thomas Jefferson |
#10405 | |
Bovi-sapiens
No clicky! Looks good. Now its time for some upgrades!! As for mine, I chipped the ice away from the doors on the shed so I could actually close the door and keep it out of the weather. The door has been frozen in 4" of ice for some time now.
2000 WJ Grand Cherokee Limited, 4.7l V8, Quadra-drive Farming is easy when your plow is a pencil and you are a thousand miles from the cornfield. -Dwight D. Eisenhower Don't curse the farmer with your mouth full. Ah, cows. A thousand roast beef sandwiches wrapped in a gorgeous leather coat. |
#10406 |
I added a Taurus e-fan.
![]() ![]() For the mounting of the overflow canister and power steering res I used part of the old shroud and mounted everything near the stock location. A little work with a reciprocating saw and some drilling and it worked fine.
02 2.5.L automatic: 4.0L t.b., 4.0l air intake, K&N filter, Scream'n Demon coil, 8.5mm MSD Super Conductor plug wires, Stage 1 Jet Chip, 29" BFG all terrain KO's. Taurus E-fan, Hummer front bumper, Skyjacker high capacity trans pan, 48" hi-lift, Rubi susp, 3/4" Daystar BB. Last edited by dexetr30; 04-01-2008 at 02:53 PM.. Reason: Added info |
#10407 |
Last weekend: New water pump, thermostat, and serpentine belt
This weekend: New soft top. It was a return fom JC Whitney so I had to get some bolts form the hardware store ($4.61) and there was a plastic tab broken off which I replaced with at bolt. Not bad considering the brand new top was half price! |
#10408 |
Dexetr30
That is scary, pic 2 looks too similar to some of the ones I took while replacing my water pump. White jeep too. For half a second i wondered how my picture got uploaded. By the way, is the air intake supposed to be pointed down like that. Mine points up. Last edited by JasonZ; 04-01-2008 at 09:44 AM.. Reason: clarity |
#10409 |
It can be swivled around by hand. Mine points up as well... I haven't had any problems with it up, and I would think more water would get in it if it points down.. but the little water (if any) that would would just sit in the bottom of that intake box, no harm done.. I don't think it matters in any way shape or form which direction that thing points..
It's easier to go down a hill than up it but the view is much better at the top. -Henry Ward Beecher Current - '98 Black Z28 with some goodies Previous - '97 Gun Metal Blue TJ Northern Illinois Extreme Jeep Club www.ExtremeJeepClub.com |
#10410 |
ordered a rokmen steering box skid and skid row engine skid
i really wanted some new shocks and adj trackbars, but i can live with a crappy ride and off center axles for now if it means not destroying anything ![]() |
| Tags |
| modifications, tj |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
