What did you do to your TJ today? - Page 6592 - JeepForum.com
 817Likes
post #98866 of 113372 Old 07-26-2014, 07:39 PM
LA-Sahara
Took it wheeling for the first time since the 4-link. Just a small trail ride so no pics. No problems other than tearing a valve stem, but I'll take that!
LA-Sahara is offline
post #98867 of 113372 Old 07-26-2014, 08:32 PM
sjones26573
Installed the new antenna mount and got my antenna back on. In the process I managed to accidentally drill an extra hole, slightly dent in the tub using a screw as a punch, and then majorly dent out the tub trying to get the first dent out but hitting too hard and too far over. Managed to mostly straighten it out with a hammer and paper booklet (padding) but the dents and cracked paint are pretty obvious if you're looking for it. It'll all be covered in armor before too long so I'm not beating myself up about it. Overall happy with the turnout. Best of all, I can now get in the garage without pulling the antenna.
While I had the grinder and cutoff out (had to trim the mount's reinforcement plate to fit it under the tub rail), I cut the end of one of my extra Fabtech LCA's off to measure the ID. Going to order some tube inserts and Duroflex joints to put on one end of the extra arms and swap them out in the front. The joints will eventually get recycled for my 3 link/axle swap later in the year.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #98868 of 113372 Old 07-26-2014, 08:47 PM
Ljcrawler05
Test fitted my 20" led light bar that'll replace the light force hids. .. already have the switch wired in so all there is to do is find a couple washers in the shop for the bracket and wire in the relay and hook it up. Probably take an hour
Ljcrawler05 is offline
post #98869 of 113372 Old 07-26-2014, 10:34 PM
BamaJeepman21
Belt slipped off. Had to get it towed home.
-Jack
BamaJeepman21 is offline
post #98870 of 113372 Old 07-26-2014, 10:50 PM
ActionJackson
Wheeled it yesterday, unloaded it off the trailer today. Give her a once over and possibly install hood pins tomorrow.
RED JEEP CLUB MEMBER #519
ActionJackson is offline
post #98871 of 113372 Old 07-27-2014, 12:53 AM
chagan02
Replaced Steering Box. All tight now.
chagan02 is offline
post #98872 of 113372 Old 07-27-2014, 12:57 AM
ItsJustD
Cut off the dump on the stock exhaust, kept smashing it on the ground and plugging it.
ItsJustD is offline
post #98873 of 113372 Old 07-27-2014, 09:29 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Ran out of paint.
Sent from my phone where grammar isn't easy.
RnEmOvr is offline
post #98874 of 113372 Old 07-27-2014, 09:42 AM
JBTJ
Originally Posted by RnEmOvr View Post
20 years from.now the Jeep will be traded for a buggy, if fun is even still allowed by then. I'll be well past retirement by then.
The Jeep isn't a daily driver. I have my 06 Cummins for that. The AC in that will make an Eskimo shiver.
That's what I thought about the new 1980 CJ7 that I bought, no AC, figured what did I need that for. Still have too.
JBTJ is offline
post #98875 of 113372 Old 07-27-2014, 11:18 AM
gumby_144
Ran out of paint.
What size turn signal lights are those. I am looking at tube fenders on mine
gumby_144 is offline
post #98876 of 113372 Old 07-27-2014, 12:06 PM
RnEmOvr
RnEmOvr's Avatar
4"
RnEmOvr is offline
post #98877 of 113372 Old 07-27-2014, 12:15 PM
DTC-TJ-97
Ran out of paint.
well you didn't get far... just the edges of the hood?
if ours didn't have such a fantastic paint job remaining from the factory, was going to go flat desert tan, possibly with digital cammo pattern. though I was intending to go for more of a Gulf War paint pattern with the black stencil lettering and inverted V.
yours is really taking shape, keep at it - been enjoying the posts and pics
DTC-TJ-97 is offline
post #98878 of 113372 Old 07-27-2014, 02:20 PM
Dave02TJ
How's your Jeep doing today? Any updates?
Dave02TJ is offline
post #98879 of 113372 Old 07-27-2014, 04:00 PM
jgezelin
My metalcloak arms came in!!!
jgezelin is offline
post #98880 of 113372 Old 07-27-2014, 05:38 PM
RnEmOvr
RnEmOvr's Avatar
Thanks. I got the windshield frame, grill, front of tub and lined the hood louver.
I may do some stenciling but not sure, my main reason for painting is scratches from trees and stuff. Its hard to see in the pics but where it says Jeep and wrangler are the original color and still shiny, at least for now.
I need to get it regeared bad, this lack of 4wd is killing me.
RnEmOvr is offline
modifications , tj
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
tweenerlj
