What did you do to your TJ today? - Page 6566 - JeepForum.com
 1396Likes
post #98476 of 114284 Old 07-08-2014, 08:33 PM
bbradUSMC
found out why I have a P0455
bbradUSMC is offline
post #98477 of 114284 Old 07-08-2014, 09:47 PM
SpeedJeep
Originally Posted by clg82 View Post
how long after you ordered your metalcloaks did you get them? Just curious as i just ordered the rear mounting plates with rear fenders last week for their 4th of july free shipping sale.....
It took about 3 weeks but I ordered them without the powder coat which takes longer.
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline
post #98478 of 114284 Old 07-08-2014, 10:32 PM
sjones26573
Rock lights finally finished. Also put top/doors back on and packed it for Windrock.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #98479 of 114284 Old 07-09-2014, 06:10 AM
Matt Graham
Matt Graham's Avatar
What rock lights are those & how many did you use?
Instagram:
Twitter:
Youtube:
My Build Thread:
F-250 7.3 Tow Rig Build Thread:
Matt Graham is offline
post #98480 of 114284 Old 07-09-2014, 06:11 AM
Matt Graham
I ordered up a set of LED rock lights from www.under-glow.com . Anyone else use those?
Instagram:
Twitter:
Youtube:
My Build Thread:
post #98481 of 114284 Old 07-09-2014, 08:44 AM
T_K
started cutting my rear spring perches off
T_K is offline
post #98482 of 114284 Old 07-09-2014, 09:14 AM
sjones26573
Some Made-In-China deal someone bought 200 of and was selling off on here. They are the kind that the light is threaded with a nut on the back. Not recommended since they are tricky to install.
Jeep-Owner.com
post #98483 of 114284 Old 07-09-2014, 09:26 AM
rbkelley89
How did you cut that is so cleanly?
Sent from AutoGuide.com Free App
2001 orange tj 2.5L (113,000) 35" Km2 Black rims D lp 30 Front and d 44 rear with ARB 1"BD MML, 1.25" BL, 4" RC Lift, Flat tc Skid, Adj rear ca's (front soon) TW rear DS, Novak shifter cable, JB ss SYE, RE angled rear trackbar, 8,000Lb Mile marker, Custom front and rear (w/swing) bumpers. Homemade CAI. Lots more to come.
rbkelley89 is offline
post #98484 of 114284 Old 07-09-2014, 09:51 AM
Bootch
Today I actually drove my Jeep to work (didn't need to take the kids today). I also ordered some recovery gear, KC Lights w/ windshield mounts, tire deflator, and air compressor.
Bootch is offline
post #98485 of 114284 Old 07-09-2014, 10:00 AM
LA-Sahara
Saw this on ifunny, made my day.
LA-Sahara is offline
post #98486 of 114284 Old 07-09-2014, 10:04 AM
T_K
Cut off wheel around the welds on the outside of the frame. On the inside of the frame I use the cut off wheel to cut as much of the weld as I could, then I used a BFH to knock the mount down and bent it back and forth to cut the rest of the inside the frame welds. Really pretty easy on the passenger side. I have the outside of the driver side done, but I need to cut the inside of those welds tonight, I didn't feel like moving the fuel lines last night so I quit for the night. So far I only have about 2 hours of work in it, not bad at all.
T_K is offline
post #98487 of 114284 Old 07-09-2014, 11:56 AM
Mud Machine
Jeep Addict
Mud Machine's Avatar
Rebuilt my front track-bar. My Jeep was starting to feel different and I notice a wobble starting up that I never had before. After doing some examining I found that my front upper ball stud on the track bar was worn. Rebuilt it and it is good as new. Not bad considering it had over 100k on it.
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS-III, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #98488 of 114284 Old 07-09-2014, 01:33 PM
BamaJeepman21
Isn't that the truth.
In other news...I've been driving a 2011 F-250 crew cab for the past couple days. Let me tell you, I'm tempted to get a truck now.
-Jack
BamaJeepman21 is offline
post #98489 of 114284 Old 07-09-2014, 03:15 PM
jeepwrangler97
Okay, now I have a question for all those who have done a MML.
I went to swap out the mounts today, & got pretty much every bolt loose, then I ran into this snag.
I can't get a socket or a wrench on the driverside bottom bolt. A 5/8" fit on the other side, but even by itself I can't get a 5/8" on the this side. A 17mm seems too big & I don't have any 16mm sockets, but a 16mm wrench won't fit either. & I know 5/8" is closer up 16mm
Is there any trick to this bolt? The frame brackets get in the way. I'm going to go out & buy a 16mm socket & see if I can get at it with a universal or something. Sorry got the bad pic...it was starting to pour while I was under there.
It's hard to tell, but there is no room for a wrench & barely enough room for a socket & a universal...
If you look from under, half the nut is blocked by the bracket
jeepwrangler97 is offline
post #98490 of 114284 Old 07-09-2014, 03:32 PM
clg82
pull the thru bolt that is going thru the motor mount itself and than pull the couple of bolts that mount it to the engine....here is what I watched before I did mine good info in this video...
clg82 is offline
modifications , tj
