What did you do to your TJ today? - Page 6329 - JeepForum.com
 1018Likes
post #94921 of 113780 Old 03-24-2014, 11:00 AM
cowstick
Plasti dipped the Bezels.
"Victory is our reward for all the blood we spill" - Amon Amarth
cowstick is offline
post #94922 of 113780 Old 03-24-2014, 11:01 AM
tyvanwie
Geez you took so long it snowed!
tyvanwie is offline
post #94923 of 113780 Old 03-24-2014, 11:03 AM
cowstick
Ha! Yeah I started late last night. Good ol' MinneSNOWta.
cowstick is offline
post #94924 of 113780 Old 03-24-2014, 11:17 AM
JBTJ
Originally Posted by aquezada View Post
Washed my LJ.
Looks like you have some tire cupping going on in the front.
JBTJ is offline
post #94925 of 113780 Old 03-24-2014, 12:03 PM
DTC-TJ-97
i did mine with some sandpaper, steel wool and a can of spray paint... flat black, simple change that eliminated the last bit of chrome outside the jeep.
i think it looks a lot better on the Red/Black
DTC-TJ-97 is offline
post #94926 of 113780 Old 03-24-2014, 02:20 PM
bisleywrangler
Originally Posted by tjty11
How do you like that bender?
It works great, gives a nice smooth bend without deforming the tube section, really easy to use as well.
bisleywrangler is offline
post #94927 of 113780 Old 03-24-2014, 02:46 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Free soft top finally arrive, now I just have to track down the frame for it. Also got in Blaine sway bar brackets, factory jack and door muckets.
May TJ of the Month 2015
TexasTJ is online now
post #94928 of 113780 Old 03-24-2014, 03:14 PM
RKCWLER
Originally Posted by DTC-TJ-97
QUESTION: if there were no fuel tank armor / shield in place, would i be able to access the inside rear bumper / frame bolt holes - specifically the two pair between the frame rails? our QR3 frame hitch / bumper connection plates require i bolt up (thankfully didnt have to align, mark and drill) through them and i cant get my hand back there. dont know if our fuel tank armor is stock or aftermarket, but it seems to be blocking access. thanks in advance for your input / responses.
I had to drill holes for my rear bumper tire carrier on my 04 TJ. I made a plate 1/8 x 3/4 x 1-1/2 and drilled 2 holes to match the crossmember. I tack welded 2 bolts to the plate. This will keep them from turning when you put the lock nuts on. I was able to slip the bolts in between the frame and the shield and then I used a magnet to guide the bolts through the hole. I then use some wire to hold the bolts in place around the threads until I put the bumper on I got a nut started. Then I remove the wire and tightened the bolts.
Eat-Sleep-Fish
RKCWLER is offline
post #94929 of 113780 Old 03-24-2014, 03:43 PM
WranglerX2006
I installed my BDS 2" lift. I ended up with about 3" front and rear, It looks way better now. It rides so much better than stock, we have lots of frost heaves here in NH right now and it handles them 10x better than stock. I added a new rear tire cover too.
I also seafoamed the intake and then took out and cleaned the Throttle body and IAC using the threads on this site
IMG_20140324_154835_673.jpg   IMG_20140324_154831_208.jpg   IMG_20140324_161215_598.jpg   IMG_20140320_210904_593.jpg
WranglerX2006 is offline
post #94930 of 113780 Old 03-24-2014, 03:48 PM
04Xrook
Oops
04Xrook is offline
post #94931 of 113780 Old 03-24-2014, 03:50 PM
04Xrook
I also seafoamed the intake and then took about and cleaned the Throttle body and IAC using the threads on this
Damn, your 06 is a spittin image of my 04. Life is good tire cover to boot. I like the look of the 2". That will be down the road for me as well. And driveline probs yet?
04Xrook is offline
post #94932 of 113780 Old 03-24-2014, 03:53 PM
04Xrook
I received and installed upgraded wire harness for the hella bulbs I put in for the headlights.
It better start to warm up soon. I need to get out and away from Internet. My pockets can't handle any more cooped up and prepping for spring up in these parts
04Xrook is offline
post #94933 of 113780 Old 03-24-2014, 03:55 PM
WranglerX2006
I don't have any vibs that I have noticed yet, only drove it for about 15 mins though but it seemed to ride great. The only problem I had was the rear axle did shift more than I expected and I have to order a trackbar relocation bracket. It was just barely touching the tire, but unfortunately I have to drive it today and tomorrow so I took a BFH to the spring perch to get it away from the tire until the bracket comes in. I found out that trick after searching on this site.
post #94934 of 113780 Old 03-24-2014, 03:57 PM
WranglerX2006
I have been doing the exact same thing! Getting impatient for spring to get here and have been searching and ordering stuff for the jeep like crazy in the last couple weeks. I don't think spring is ever going to get here in NH this year.
post #94935 of 113780 Old 03-24-2014, 04:08 PM
LukeADukes
Originally Posted by Mattific
Yes it is
rugged ridge SYE known to leak most replace the seal before installing
Always look both ways before crossing the stream.
LukeADukes is offline
modifications , tj
