What did you do to your TJ today? - Page 6328 - JeepForum.com
 1225Likes
post #94906 of 114041 Old 03-23-2014, 09:16 PM
sjones26573
Tired of studying and annoyed by the 2 flickering Autolumination LED's in the cluster, I decided to order all new cluster and HVAC bulbs from Superbrightleds.
The links for any who might need them.
https://www.superbrightleds.com/more...base/228/1069/
https://www.superbrightleds.com/more...-led/221/1003/
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #94907 of 114041 Old 03-23-2014, 09:20 PM
cbrant
Since yours is a 2004 as well, and I know you're in electrical engineering - I think - how many of each do I need to order for the cluster and HVAC? Did you get some for behind the rocker switches?
cbrant is offline
post #94908 of 114041 Old 03-23-2014, 09:24 PM
sjones26573
EE is correct.
5 74's for the cluster.
3 Neo's for the HVAC (4mm, there are 3,4, and 5 so be sure to pick the right one)
I have an aftermarket panel and switches so they came with their own LED's
Jeep-Owner.com
post #94909 of 114041 Old 03-23-2014, 09:31 PM
thgr8alex
Wow it's identical! Apparently the Trailgear ones could have been had for $80. The Fabtech is $382 for the exact same thing. Weird how that works huh?
That was also some time ago.. I think the avg. front bumper cost now is between 200-500 so thats not too bad when compared to the others. But it does look pretty good. Check your local CL and surrounding areas for one and also check ebay for one.
thgr8alex is offline
post #94910 of 114041 Old 03-23-2014, 10:25 PM
carbert
Finally finished front/back break change..took 2day.cuz I was on call and middle way working on them had call for work..cam back..started on my braces again then another call for work.
All in all.she has new breaks.and now stops when I tell her to stop:-)
carbert is offline
post #94911 of 114041 Old 03-23-2014, 10:39 PM
smotrs
Found out that in order to remove the sound bar, you have to remove the top. Unfortunately, my GF is only 5ft tall, so she couldn't help lift it.
So, ended up adding a lift to the ceiling.
Shaun
smotrs is offline
post #94912 of 114041 Old 03-23-2014, 11:59 PM
Neudiin
I just did my dash. got mine from Vleds....$3.99 a pair for the 74s.
Neudiin is offline
post #94913 of 114041 Old 03-24-2014, 01:04 AM
thedaringmove
Picking up a poison spyder comp stinger today. I can say today now that it's 12:03am
Picks to come
thedaringmove is offline
post #94914 of 114041 Old 03-24-2014, 02:27 AM
Richisinyoface
Richisinyoface's Avatar
Trail Gear. They don't make them anymore.
Are you sure that is not a Fabtech?
[/URL]
Just Empty Every Pocket.......yup they are empty all right.................
NRA Life member
Sienna Jeep club member #65
Richisinyoface is offline
post #94915 of 114041 Old 03-24-2014, 05:16 AM
sc00bz
Originally Posted by Richisinyoface
Are you sure that is not a Fabtech? [/URL]
Nope. It's a trail gear which is no longer made. It has 2 of the diagonals on each immediate side of the winch opening whereas the fabtech only has one per side.
Source: I have the same bumper.
97 TJ with some stuff.
sc00bz is offline
post #94916 of 114041 Old 03-24-2014, 05:26 AM
yamaha225
Originally Posted by DTC-TJ-97 View Post
then I guess its good that I have enough knowledge to be dangerous, the stamina to put up with it, and the tools to give it a shot... and an eager 15yr old son that is immune to swearing, and actually comes up with some excellent ideas for problem solving.
its easy to dismiss the ideas of a child, when you think you have looked at things from every angle and have applied your own experiences... but sometimes I am finding, inexperience and a fresh perspective can actually provide an excellent solution.
he's looking to go into engineering, so I think encouraging him and showing him the ropes in the garage and tools will be beneficial to both of us.
As a current Mechanical Engineering student the time I spent in the garage with my grandfather as a kid was extremely valuable and what really got me into cars, specifically jeeps
1997 TJ, 2.5 4 cyl, AX-5, Hella 700's
Black Jeep Society, Eagle Scout Jeepers
yamaha225 is offline
post #94917 of 114041 Old 03-24-2014, 07:43 AM
Richisinyoface
Excellent, glad to know the difference, Thanks!
NRA Life member
post #94918 of 114041 Old 03-24-2014, 08:15 AM
jarrodblake
1978 CJ10
jarrodblake is offline
post #94919 of 114041 Old 03-24-2014, 08:23 AM
Tonellin
Originally Posted by jarrodblake View Post
Lookin real good so far, can't wait to see it completed
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #94920 of 114041 Old 03-24-2014, 09:37 AM
DTC-TJ-97
QUESTION:
if there were no fuel tank armor / shield in place, would i be able to access the inside rear bumper / frame bolt holes - specifically the two pair between the frame rails?
our QR3 frame hitch / bumper connection plates require i bolt up (thankfully didnt have to align, mark and drill) through them and i cant get my hand back there.
dont know if our fuel tank armor is stock or aftermarket, but it seems to be blocking access.
thanks in advance for your input / responses.
DTC-TJ-97 is offline
modifications , tj
Currently Active Users Viewing This Thread: 6 (3 members and 3 guests)
davewjcook , Jonny Jeep , moemuledeer
