What did you do to your TJ today? - Page 6282 - JeepForum.com
 1017Likes
post #94216 of 113780 Old 03-09-2014, 01:30 PM
TJ_Tim
Interwebz Specialists
TJ_Tim's Avatar
Put these on. No more bouncy hood.
Sent from Teletran 1
1969 Mercury Cougar 351w
1998 Jeep Wrangler Sport 4.0
2009 Yamaha V Star 950
2006 Jeep Commander 4.7 Base
TJ_Tim is offline
post #94217 of 113780 Old 03-09-2014, 01:36 PM
jeepwrangler97
Originally Posted by apayne View Post
I did actually try smacking the starter. And the battery and cables are good cause everything electronic in the jeep still works no problem.
It could also be the neutral safety switch
Edit: or its just as simple as it being the starter
Sent by a messenger bird
jeepwrangler97 is offline
post #94218 of 113780 Old 03-09-2014, 02:10 PM
tyvanwie
Washed it and cleaned most of the interior. And took the doors and windows off.
tyvanwie is offline
post #94219 of 113780 Old 03-09-2014, 02:19 PM
Thedawgshow
Just because electronics work, does not mean battery, cables and connections are not bad. What are the symptoms? Any grinding? Electronics do not take a lot of power, but cranking the engine does.
DAWG
My pappy was a pistol, I'm a son of a gun.
Thedawgshow is offline
post #94220 of 113780 Old 03-09-2014, 02:22 PM
apayne
The first time it cranked for about a second but then stopped. Now when I turn the key I hear a single click from the ignition area but nothing else also can hear a click in the engine comp. But no grinding or cranking at all.
Advocare - We Build Champions!
www.advocare.com/1210313
apayne is offline
post #94221 of 113780 Old 03-09-2014, 02:32 PM
Thedawgshow
Can never be sure since I am not there, but it doesn't sound like a starter. Sounds like not enough juice. You have juice, just not enough. Try moving the cables around or a jump first.
DAWG
post #94222 of 113780 Old 03-09-2014, 02:34 PM
Thedawgshow
The clicking is a symptom of not having the juice, and the system is working. Good luck!!!
DAWG
post #94223 of 113780 Old 03-09-2014, 02:39 PM
h1driver
Attachment 1157153
I like
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed."
So, Suck-It Trebek!!! MOΛΩN ΛΑΒΕ
My "Build" -
h1driver is offline
post #94224 of 113780 Old 03-09-2014, 02:40 PM
Thedawgshow
Drove the boys and I to brunch after a long night of honky tonking and noticed bubbling paint on the rear drivers side corner where the body comes together. SUCK!!!! Another job for my build page.
DAWG
post #94225 of 113780 Old 03-09-2014, 03:15 PM
apayne
It's not a dead battery clicking. It's more of a faint click from the ignition switch which I'm assuming is normal.
apayne is offline
post #94226 of 113780 Old 03-09-2014, 03:44 PM
Thedawgshow
Hmmmmmmmm? Well, I don't know if you have AAA or what, and I don't know your level of mechanic ability, but I sure would try the whole jump thing first as I see it from here. A jump from someone is sure cheaper than a tow. More than likely, you have already tried something like this already though I am guessing.
DAWG
post #94227 of 113780 Old 03-09-2014, 03:45 PM
686keydragon
Sounds more likes dead battery based on that. Have you tried using jumper cables?
686keydragon is offline
post #94228 of 113780 Old 03-09-2014, 04:19 PM
apayne
Yes I've tried jumping it and it does the same thing while hooked up to another car.
It started perfectly 4 other times yesterday and now nothing.
apayne is offline
post #94229 of 113780 Old 03-09-2014, 04:36 PM
blubaru2002
Installed 6 inch springs on my rear axle and continued trying to eliminate the driveline vibrations I'm getting with my 8.8 axle.
I had no idea these axles were such a pain to get dialed in and vibration free...
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #94230 of 113780 Old 03-09-2014, 04:48 PM
dillonjm
2013 WK
They shouldn't be.
I've set up a couple and never had an issue. Are you using a magnetic angle gauge and setting the pinion angle 1-2 degrees below the driveshaft angle? (I'm assuming you have a SYE based on lift height and axle swap)
Also, what is the driveshaft angle in relation to the transfer case output angle? (DS * - tcase *)
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
modifications , tj
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Mousejockey , RKCWLER
