What did you do to your TJ today? - Page 6187 - JeepForum.com
 800Likes
post #92791 of 113345 Old 01-30-2014, 04:31 AM
NH-JK
Originally Posted by bwall_1972
Finally replaced these deteriorated brake lines with preformed stainless steel. It was a nightmare but, it's all better now. Replaced the pads and rotors while I was at it...
What made it a nightmare? I'm getting ready to do the same thing. Did you buy the kit ( pre bent) how much$
NH-JK is offline
post #92792 of 113345 Old 01-30-2014, 05:28 AM
bwall_1972
The pre-bent lines from Quadratec are about $150 or so. I've never had to do this before so fishing the new lines across the front of the jeep was a challenge. It took more time than expected and honestly at one point I thought it wasn't going to happen. It was really hard to route the new lines the exact same way as the old ones but after several hours and a couple of cold ones, I got it. I recommend using deep creep from sea foam for those stubborn hard to turn lines. Also, recommended on this thread... Cut the old lines and use a six sided ratchet. I didn't do that but, will if I ever have to do it again! Good Luck!
bwall_1972 is offline
post #92793 of 113345 Old 01-30-2014, 05:36 AM
NH-JK
Great advice
NH-JK is offline
post #92794 of 113345 Old 01-30-2014, 06:42 AM
04Xrook
'04 TJ X with 4.0.....had a nasty intermittent tick. Wouldn't you know another oil change later(k&n and rotella) with half quart MMO later plus a coil pack and plug change, she runnin pretty damn good. Also just recently put in Dynomax catback system....
04Xrook is offline
post #92795 of 113345 Old 01-30-2014, 06:49 AM
KoolAidMan888
I wanted to do this but it scares me to throw anything in the motor that not a motor oil
Aerospace CNC tube bending.
KoolAidMan888 is offline
post #92796 of 113345 Old 01-30-2014, 07:24 AM
04Xrook
I tried a little at first, 4oz or so. Bout 2 days before oil change. It helped with what I thought was a sticky lifter/exhaust valve. ( because of how it sounded during idle). MMO came as advice from my old man who had a 67vette stored in a dirt floor, unheated garage. Which after sitting 20+ years cranked over before restoring it.
Tick was still there but much less noticeable. I've used sea foam to try to "ungunk" insides before oil change. The last step, coil and plugs really seemed to help the most.
Can you recommend a quality motor oil w more zinc in it?
04Xrook is offline
post #92797 of 113345 Old 01-30-2014, 08:51 AM
KoolAidMan888
No I can't I just use mobil one synthetic 10 30. But I have a little tick / knock . I want to try to get rid of the noise but don't wanna hurt it ya no?
post #92798 of 113345 Old 01-30-2014, 11:28 AM
SouthFLJeeper
SouthFLJeeper's Avatar
Thanks for the great info. Looking forward to painting my panels.
Originally Posted by jeepwrangler97
Just make sure everything is clean. They sell plastic prep wipes & things at the autoparts stores....but I've not used those. I was instructed by the local paint place not to use stuff like MEK for cleaning on the plastic b/c it is too harsh. I have used alcohol on some of the parts, but not too much of it. I usually rinse, scrub with a hard brush & dish soap, rinse, scrub with dish soap, rinse, scuff with fairly fine sandpaper (nothing too aggressive), rinse, scrub/soap, rinse, air dry & wipe down with microfiber. Then I use the adhesion promoter (usually 2 coats), wait 15min, then a very light coat of color, wait 5-10min, then 3 coats of color (last 2 pretty thick) with about 10 min between coats, then 1-2 coats of clear....I recently tried a rustoleum matte clear over SEM satin black & I love the finish, but can't say how it holds up yet. My photobucket isn't loading right now, but you can check out my "build" thread....& an old thread I have titled "painted my console" or something Sent by a messenger bird
'00 TJ Sahara - 1" Body Lift, awaiting many upgades
'00 TJ Sahara (R.I.P.) - 2.5" Rancho Lift, 2" BB, 1" Body Lift, 35" XTerrain's, Warn 9000lb Winch, Warn Bumpers & Sliders
'05 Excursion 6.0 Diesel
SouthFLJeeper is offline
post #92799 of 113345 Old 01-30-2014, 01:42 PM
irnmadn88
Crossed the Rubi locker switch mod off the list. Used one of the wires from the tiniest one of these. Clipped the wire short with a cut bevel opposite each other.
Jumped pins 1 & 4. The bevel of the cut helped the wire slip inside the hole next to end of the pin.The loop makes it easy to pull out.
Colorado Jeep Club Member #667
irnmadn88 is offline
post #92800 of 113345 Old 01-30-2014, 01:52 PM
SouthFLJeeper
Installed my Smittybuilt SRC rear bumper.
post #92801 of 113345 Old 01-30-2014, 02:40 PM
A4LiterV8eater
spaced the front seats up an inch
A4LiterV8eater is offline
post #92802 of 113345 Old 01-30-2014, 02:43 PM
Ferrachi
I picked up a Lincoln Weldpac HD yesterday. I have not welded in 19 years, managed some halfway passable welds while practiceing last night with it. I made these brackets today to store my highlift in front of my Tuffy Jumbo Box. Just have to paint them up now. Will post pics of everything installed once finished.
Ferrachi is offline
post #92803 of 113345 Old 01-30-2014, 03:45 PM
eplumer400
Couple of things. Got an email from Brown Dog saying my MML was shipped. Got my body mounts loosened for the body lift, installed my Teraflex bar pin eliminators. I'm feeling the itch to wheel, so I parked on the snow pile outside of my work for the day.
eplumer400 is offline
post #92804 of 113345 Old 01-30-2014, 08:32 PM
Badonkadonkey
Originally Posted by jeeprubi2005 View Post
Is there a wright up on this would love to do it toy jeep
Write up for the aux input posted.
Yellow 2003 TJ: Stock, 4.0L I6, Manual Transmission
Badonkadonkey is offline
post #92805 of 113345 Old 01-30-2014, 08:43 PM
Ferrachi
All finished and mounted up.
Ferrachi is offline
modifications , tj
