What did you do to your TJ today? - Page 6185 - JeepForum.com
 910Likes
post #92761 of 113578 Old 01-28-2014, 07:33 PM
aparise
Found my exhaust is ready to fall off! Just something else to fix!
aparise is offline
post #92762 of 113578 Old 01-28-2014, 09:26 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by Richisinyoface View Post
This is off Currie's site
Description: The Currie Currectlync® heavy duty tie rod and drag link system for TJ, LJ, XJ, and MJ vehicles features, a 1 ¼" diameter forged alloy drag link, and 1 ¼" solid alloy steel tie rod bar that is bored and threaded on the ends. All 7/8" thread tie rod ends with boots are included as well as the Currie heavy duty steering stabilizer bracket. This unit is a direct replacement for the stock parts. No modifications or machining to any part of the vehicle is necessary. This unit is rated at 200% stronger than the stock components. NOTE: This unit is designed to be used on vehicles with 4" of lift. It can be used on vehicles with less lift, but the vehicle must have a minimum of a 2" bump stop (over stock). Also, on vehicles with no lift, 2 of the tie rod ends may need be trimmed to achieve proper adjustment.
Not to mention that if you are in danger of over traveling the TRE at the pitman from a low lift and too much uptravel, it's a simple matter to put it in a press and take some of the bend out of it. We used to do the opposite for the XJ crowd on the first and second Gen stuff.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #92763 of 113578 Old 01-28-2014, 09:42 PM
thedaringmove
Is there a thread related to this?
thedaringmove is offline
post #92764 of 113578 Old 01-29-2014, 12:09 AM
sjones26573
Took it out in the snow. First I towed a stranded couple back to their house, with RPD blocking the major roads for me. Then I took it out to play with some club members. Had a blast.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #92765 of 113578 Old 01-29-2014, 09:08 AM
Youngster
Not what I did, but we finally got some snow in Auburn Alabama!
Door handles along with the windows were frozen shut
Youngster is offline
post #92766 of 113578 Old 01-29-2014, 10:00 AM
JPGoody
Tossed a pair of the Polk DB651s into the sound bar to compliment the new head unit. And by tossed I mean laid on my back with neck torqued at awkward angles, stressed out my dislocated shoulders, cursed at multiple failures and finally cracked a grill while finnaglin' with the last of 4 screws. Got em' in, but they don't slip right in as many have said.
Luckily I added poly-fil on my first attempt, cause there won't be any more. Found it to be a wee bit easier to do the install form the rear of the jeep. Sound bar removal would have made it easier, but not taking the top off in these temps.
Sounds is solid and definitely improved.
JPGoody is offline
post #92767 of 113578 Old 01-29-2014, 10:23 AM
jeeptjman2000
Cancelled my order for my Rustys steering and ordered the currie setup!!(: the local 4x4 shop didnt place the order for the rustys yet anyhow so its all good plus i got a much better setup.
jeeptjman2000 is offline
post #92768 of 113578 Old 01-29-2014, 10:41 AM
bbradUSMC
I had to trim the edges of the speakers like so, oh and the covers that came with them dont even some close to fitting.
bbradUSMC is offline
post #92769 of 113578 Old 01-29-2014, 11:20 AM
AndyAllen
Took it out to play a little. It was funny to watch the guys in the front wheel drive cars spinning out.
1998 TJ Sahara, (Sold to Dad)
1995 YJ SE, (Finishing up the deal)
AndyAllen is offline
post #92770 of 113578 Old 01-29-2014, 12:42 PM
chopstix333
Attachment 1041201
Attachment 1041209
Hey, I'm in Auburn too! Everyone said to stay off the streets... but I couldn't resist
'98 Jeep Wrangler 2.5L | 4" Pro Comp Lift | 33x12.5x15 Dunlop Mud Rovers | Two 10" Polk Audio Subwoofers | 2 Amps (800w Eclipse and Alpine MRP-1000 Mono) | Kenwood Head Unit | Ham Radio w/ Comet SBB-7 Antenna (Call Sign: KK4BUE) |CB Radio | Hella Vision Plus Conversion with 50w 6k HID bulbs | Lotta Lights |
chopstix333 is offline
post #92771 of 113578 Old 01-29-2014, 01:03 PM
Richisinyoface
Richisinyoface's Avatar
I believe you will be happy you did, you will like the Currie setup
Just Empty Every Pocket.......yup they are empty all right.................
NRA Life member
Sienna Jeep club member #65
Richisinyoface is offline
post #92772 of 113578 Old 01-29-2014, 01:04 PM
Brians77
Originally Posted by SouthFLJeeper
Did you paint the interior tan? If so, what paint did you use. I've got a set of 1/2 doors I need to change the door panel color.
It's sem color coat. The color is camel. You can order it from summit racing. It cost 9.95 a can
Brians77 is offline
post #92773 of 113578 Old 01-29-2014, 01:16 PM
jeepwrangler97
Coming from someone who's done their entire dash/doors/console:
1. Make sure you prep very well
2. Sem holds up better than the duplicolor stuff in my experience
3. Prep, prep, prep
4. A clear coat of some sort is highly, highly recommended for longevity
5. Prep
6. Did I mention it's mostly about the prep work?....everything must be CLEAN & use a good adhesion promoter
...7. Prep...
Sent by a messenger bird
jeepwrangler97 is offline
post #92774 of 113578 Old 01-29-2014, 01:49 PM
SouthFLJeeper
SouthFLJeeper's Avatar
Ordered some from Amazon. What exactly needs to be done to prep it correctly?
3. Prep, prep, prep
5. Prep
...7. Prep...
'00 TJ Sahara - 1" Body Lift, awaiting many upgades
'00 TJ Sahara (R.I.P.) - 2.5" Rancho Lift, 2" BB, 1" Body Lift, 35" XTerrain's, Warn 9000lb Winch, Warn Bumpers & Sliders
'05 Excursion 6.0 Diesel
SouthFLJeeper is offline
post #92775 of 113578 Old 01-29-2014, 02:19 PM
bwall_1972
Replaced the old chrome headlight bezels with these black ones. Inexpensive upgrade but, makes a huge difference I think!
bwall_1972 is offline
modifications , tj
Redfish7
