What did you do to your TJ today? - Page 6179 - JeepForum.com
 1065Likes
post #92671 of 113806 Old 01-26-2014, 09:12 PM
thgr8alex
Installed a 2000 XJ intake manifold on my 98 tj. Wasnt too hard. Only had to extend amd solder one sensor and the vacuum line i rerouted. Other than that, bolted right up and runs great. The newer design was said to give 15 hp but i cant really tell although the exhaust has a bit deeper tone. Had to replace anyway so figured why not get the newer design...
thgr8alex is offline
post #92672 of 113806 Old 01-26-2014, 09:15 PM
watsoc08
Spray some WD40 on the rear rubber bump stops and use some Channel lock pliers to pull the rubber jounce out. It helps if you use a floor jack under the frame to get some gaps opened up on your rear springs. Once I used this method it almost seemed to easy after my first struggles. Good luck.
watsoc08 is offline
post #92673 of 113806 Old 01-26-2014, 09:20 PM
Maverickxeo
Ah, I wasnt sure if a lubricant would work on the rubber. Ill give that a try next weekend; thanks!
Maverickxeo is offline
post #92674 of 113806 Old 01-26-2014, 09:24 PM
watsoc08
I would spray some PB Blaster on the top of the bolt for the bump stops as well. Mine were pretty seized up so hit it up a couple of times prior to starting to reduce your effort in getting the bolt out once you remove the jounce.
watsoc08 is offline
post #92675 of 113806 Old 01-26-2014, 09:26 PM
Mattific
Originally Posted by 2003X
New radio.
What do the red numbers mean in the pass airbag spot?
Mattific is online now
post #92676 of 113806 Old 01-26-2014, 09:27 PM
sjones26573
Trans temp probably
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #92677 of 113806 Old 01-26-2014, 10:08 PM
bbradUSMC
I always lube my rubbers.
OT: Finished my monstaline project. Pics in the morning.
bbradUSMC is offline
post #92678 of 113806 Old 01-26-2014, 10:13 PM
geroux
Just don't use a petroleum base lubricant
geroux is offline
post #92679 of 113806 Old 01-26-2014, 10:18 PM
Rican142
New radio.
that looks really clean, where did you get the mounting plate/the piece around the radio lol
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #92680 of 113806 Old 01-26-2014, 10:33 PM
Cwest22
Bought ujoints but forgot to get a 36mm socket while I was in town. So they the sit brakes off until Tuesday when I go into town again
Cwest22 is offline
post #92681 of 113806 Old 01-27-2014, 12:36 AM
sjones26573
Change them with the hub on. Thats how we did mine. Worked just fine.
Jeep-Owner.com
post #92682 of 113806 Old 01-27-2014, 05:39 AM
wwch99tj
Originally Posted by jjvw View Post
My new ZJ tie rod is arriving Tuesday, so I didn't bother with the alignment only to do it again a couple days later. I will just have to avoid the highway for a couple days.
Given that the original steering components have 68,000 miles on them, I would not be surprised if something is worn out and the lift, small as it is, is highlighting that. I'll know more later this week. I'll check the trackbar while I'm at it.
Hope the new tie rod end and alignment solve your problem...
Just FYI my steering components have over 250k driven and whatever the PO towed it behind his motorhome...
I only replaced one tierod end on mine due to a split boot a few months ago...
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #92683 of 113806 Old 01-27-2014, 06:22 AM
Mhelle
Finished my homemade window roll (looks great!)
Waiting for my security deck enclosure... (its taking forever!!)
Mhelle is offline
post #92684 of 113806 Old 01-27-2014, 06:55 AM
markgavin
Well, the other day/evening. pull in to fill up, turn off jeep......pay for gas.....get back in jeep.....no start. Thankfully Kmart (within walking distance) carries diehard......unfortunately no platinum.......had to get gold just to get jeep home. Maybe next time platinum.
Battery had been in there at least 4 years (when I bought it). Knew it was going.....just procrastinated long enough to do it in 15-20 degree temps at a gas station instead of my garage. Guess Ill get it an inspection sticker today since it expired in December.
markgavin is offline
post #92685 of 113806 Old 01-27-2014, 07:00 AM
SlackJaw
baby jeep
SlackJaw's Avatar
Originally Posted by thedaringmove View Post
How long did it take you? You do the 80$ HD one?
I had to triple check research, make a couple runs to parts and hardware store, and fab/modify some tools, so it turned into a full day. Aside from that I would probably budget 4 hours minimum. A pro on the clock could do in 2 or less.
The rebuild kit I used is Dana, Part # D/S708203... at 4WP, $74.99.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
modifications , tj
