What did you do to your TJ today? - Page 617 - JeepForum.com
 813Likes
post #9241 of 113360 Old 01-12-2008, 05:47 AM
jeep06
jeep06's Avatar
2015 KL Cherokee
I'm already wondering what is the best kind of auxiliary lights to put on the front bumper. When I was going down the arroyo more light was definitely needed. Well, here we go...[/QUOTE]
Congrats on the new rig...of course pictures will be mandatory... . Also welcome to the forum...this is the best when it comes to Jeep info, can't go wrong here!! As for lights, you might consider a head light conversion/upgrade kit,,,, you will have good lighting all the time then with out adding any thing else. But auxilary lights are always welcome too....depends on which route and how much $$$$ you want to spend. Jeeps are good for draining your pockets....BUT DAMN WELL WORTH EVERY PENNY!!!
2015 Cherokee Limited (granite) 4x4, 2.4L, 8.4AN, luxury group, wireless charge pad.
jeep06 is offline
post #9242 of 113360 Old 01-12-2008, 08:25 AM
wangus
Welcome NewMexico , just keep in mind that JEEP does stand for something Just Empty Every Pocket . And I agree with Jeep06, a headlight upgrade is always a good idea. Even if you upgrade to different factory style headlights, I have a set of Sylvania silverstars and they area great improvement over stock, and they're not too expensive, compared to other things you can do. And today I am going to try to mount my ammo cans in he back.
2002 Black Tj Sport. 2" Skyjacker BB and 31" Kumho Roadventures. Black Rugged Ridge dual tube bumpers, and lorts more to come.
wangus is offline
post #9243 of 113360 Old 01-12-2008, 08:48 AM
PBR
PBR's Avatar
geting my tires rebalenced hoping it will get rid of my little shimmy i got!
PBR is offline
post #9244 of 113360 Old 01-12-2008, 09:35 AM
john NC
john NC's Avatar
Originally Posted by rmb2485
Thats the low pressure intake for the compressor. I figured rather than use the crappy foam filter and plastic assembly that came with it I would use the Jeep's filter.
gotcha, that's pretty clever
john NC is offline
post #9245 of 113360 Old 01-12-2008, 10:03 AM
Mino
Having fun...
Just want to say hi to everyone here on the forum and simply drop a few lines. This is my first response to a topic. I am still relatively new to the Jeeping scene but I look forward to owning such a capable vehicle. Anyways, in response to the topic... I just installed a set of JKS Sway Bar Quicker Disconnects and a set of Riddler Differential covers. I can't wait to put them to good use.
I am still fairly new to the 4x4 scene so I could really use some leads on some good off-roading spots and clubs . Can anyone give me some good info on both these things? I live in Houston, Tx in the southeast part of town. Thanks.
'05 Jeep Wrangler X
Rocky Mountain Edition
3" suspension lift, K&N cold air intake, Pro Comp MX6 shocks, JKS Quicker Disconnects & Front Track Bar, Dynomax Cat-Back system, SYE kit, Pro Comp Rock Crawler Wheels, 33" BF Goodrich A/T, Aussie Locker, and Warn XD9000i winch
Mino is offline
post #9246 of 113360 Old 01-12-2008, 10:34 AM
ElPaso2007
ElPaso2007's Avatar
Thanks much. I guess I'm not in any danger of spending more just yet, since I emptied by savings account for the downpayment, but I'm already looking at websites that sell accessories...
ElPaso2007 is offline
post #9247 of 113360 Old 01-12-2008, 12:44 PM
rmb2485
rmb2485's Avatar
Washed the engine! Just used the degreaser option on the DIY car wash. Rinsed with high pressure, applied degreaser, let sit for five minutes, rinsed with high pressure, repeated the process. Its still not all that clean, but at least I washed off about 10lbs of dried up mud water that was caked all over everything.
At its dirtiest
In the garage last night
Now
Now I can't wait to work on something and not have dried mud fall in my eyes and get all over my clothes.
rmb2485 is offline
post #9248 of 113360 Old 01-12-2008, 01:06 PM
jeep06
jeep06's Avatar
2015 KL Cherokee
Just finished rotating my tires, giving her a grease job, pulled all my brake calipers, cleaned all the sliding parts, re-greased with silicone grease and all is good!! Can't beat an afternoon in the garage with the Jeep!!
jeep06 is offline
post #9249 of 113360 Old 01-12-2008, 03:29 PM
Humboldt
Humboldt's Avatar
Finally installed the Novak TC shifter. SO much better shifting.
Humboldt is offline
post #9250 of 113360 Old 01-12-2008, 05:44 PM
Wallace
put some flash new ARB diff covers on my D44 rear and D30 front...
very nice and - i love that the filler point is alot higher than standard... so when the diff is rotated when my new TnT customs lift goes on - i can still fill it properly.
2000 TJ Wrangler Sport
Half Door - Soft Top
WARN Rock Sliders, 4.5" RE Springs
TnT Customs Dual Triangulated Long Arm Lift, NV4500
35" M/T Baja Claws, TBT Rear Bar with Tyre Carrier
ARB Front Bar - Dual Hella 4000 Spotlights.
Wallace is offline
post #9251 of 113360 Old 01-12-2008, 06:20 PM
SGT Superman
SGT Superman's Avatar
After waiting a week for a part to come in I finally fixed my driveshaft, WOOT!! nomore public transportation.
Now you know, and knowing is half the battle. G.I. Joe!
Green Jeep Club Member #174
GO COUGS!
SGT Superman is offline
post #9252 of 113360 Old 01-12-2008, 06:28 PM
FmrVette
FmrVette's Avatar
2008 XK Commander
McGard Lug Nut Failure
Yesterday evening, just before dark, I noticed that the pin that is inserted into the swingarm of the rear bumper (Body Armor) was up about 1/2". This morning I checked it out; it was too tight to be forced back into position even with a fairly large hammer. Figuring that removing the spare tire would lower the weight on the arm I tried to remove the spare. The McGard lock nut literally sheared off when I used the key in a four way lug wrench! I've never seen that before - the lug nut was rusted clear through.
After liberal doses of penetrating oil, and notching the remaining part of the lug nut with a cold chisel I was able to get enough of a grip with vicegrips and unscrew the remains of the lug nut.
Once I had that piece off the other two standard lug nuts were easily removed, the spare came down and I was able to fully insert the pin back into the swing arm. (I took the opportunity for tightening the bumper up a bit. Nice and snug now, no rattles).
I'll be contacting McGard on this one...they aren't terrific for locking wheels, but do at least slow the thieves down - but the lousy things shouldn't rust in half in 18 months, even in Michigan weather.
Jim
"Basically, I'm for anything that gets you through the night - be it prayer, tranquilizers or a bottle of Jack Daniels. - Frank Sinatra
"When the last Blackhawk helicopter goes to the boneyard, it will be on a sling under a Huey." - Every Huey pilot that lived through it.
'95 YJ, '00 XJ, '06 TJ, (Current:) '08 XK
FmrVette is offline
post #9253 of 113360 Old 01-12-2008, 06:36 PM
PearlJam1003
Dropped my 2" BDS lift off at my buddy's house so we can install it on Tuesday night
PearlJam1003 is offline
post #9254 of 113360 Old 01-12-2008, 07:04 PM
daniel01TJ
Drove to a GA WMA and had the beagles run some rabbits
01 Silver TJ Anniversary edition, 4.0L 6cyl, nv3550 tranny, 3.73 gears, dana 30fr/44rr, FT 3" Economy, JKS Quicker Discos, 33x12.5 Trxus MT, 15x8 Rock Crawlers, Rokmen Sliders
daniel01TJ is offline
post #9255 of 113360 Old 01-12-2008, 07:04 PM
badoosh27
badoosh27's Avatar
finished putting in my poly bushings on my front control arms, huge pain in the rear. the stock upper bushing rubber was like tar and stuck to everything including my hands. not looking forward to doing the rear ones
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
modifications , tj
jbryant , Mikeyc911 , MrDubbe
