What did you do to your TJ today? - Page 6164 - JeepForum.com
 536Likes
post #92446 of 112599 Old 01-20-2014, 09:36 PM
sjones26573
Installed BDS 3" coils, Bilstein 5100's, and Crown Perf brake lines in the front. Didn't have time to touch the rear. Sits with a pretty obvious rake now but that just convinces me that the 2" rear coils will be perfect. Felt good on the road but I noticed the biggest difference on the gravel driveway. Front end floated over the gravel like it was paved.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #92447 of 112599 Old 01-20-2014, 10:23 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by thedaringmove View Post
All my batteries have been optimas. They last a while
Not any more... IMO
Knuckelhead is offline
post #92448 of 112599 Old 01-20-2014, 10:42 PM
thedaringmove
Holy crap. Brain failure. I meant to say "All ive run are die hards. They last a while"
My bad yall
Ive never had an optima.
thedaringmove is offline
post #92449 of 112599 Old 01-21-2014, 04:26 AM
peigrand
Well we got a warm enough day to work outside so I got the oil changed and new plugs in
peigrand is offline
post #92450 of 112599 Old 01-21-2014, 06:01 AM
gumby_144
I started building a over the mirror switch console that will house switches for my lights, cooling fan, andcobra 75 wxst cb, also made provisions in it for in cab winch controls, on board air and arbs. Will post pics when done
gumby_144 is offline
post #92451 of 112599 Old 01-21-2014, 06:37 AM
blubaru2002
Originally Posted by jeepwrangler97
Haha, all the FL cars aren't used to "cold" weather...my mom's car needs a battery now too. I've read good things about the Sears diehard platinum batteries. I'm running an Optima....supposedly they aren't as good of quality anymore, but it's the best I could get at the time & it's held up well for 4ish years so far Sent by a messenger bird
This one lasted 5 years that I know of. Not a bad run.
I'm going to purchase a sears battery to replace it.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #92452 of 112599 Old 01-21-2014, 06:40 AM
xxxxxxxxxxxxhilde
Guest
Started it...sat in it for a while ...
I have the Jeep hibernating in the barn over the salty-roads winter but I snuck out to the barn, hopped in, fired it up and sat in it for a while.
xxxxxxxxxxxxhilde is offline
post #92453 of 112599 Old 01-21-2014, 07:52 AM
rt4422
Originally Posted by ThatWhiteJeep
Ordered new spicer 5-760x u joints for the old girl. Pb blasted all the joints in prepping for the new lift kit and tires tomorrow. I'm gonna do the hammer method to swap out the u joints on the axle shafts instead of taking it to a shop, anyone have any luck with this?
Go buy the harbor friend u joint/ball joint tool. I've used it for 5+ u joints. It's cheap and it definitely makes the job easier.
My TJ Build:
rt4422 is offline
post #92454 of 112599 Old 01-21-2014, 07:59 AM
apaTJ
The hammer method works fine. That's all I've used. But i plan on getting a press it will be a lot easier.
apaTJ is offline
post #92455 of 112599 Old 01-21-2014, 08:14 AM
ThatWhiteJeep
The upsetting thing is I just had it aligned after the lift yesterday, and I'll have to have it aligned again after replacing the U joints. Nice waste of money.....
Like my GrandPappy said, only way to learn is to do it yourself. Even if you break some things along the way.
ThatWhiteJeep is offline
post #92456 of 112599 Old 01-21-2014, 08:40 AM
JPGoody
Originally Posted by OR-TJ View Post
Changed oil, did front pinion seal and fresh gear oil in it. Also finally got around to putting my iggee seat covers on...
Those look real nice. I'm gonna have to get a set for my 12 yr old seats.
Where/how did you purchase them?
That state of the art web site they are running?
Cheers
JPGoody is offline
post #92457 of 112599 Old 01-21-2014, 08:41 AM
bbradUSMC
The only problem I ran into using only a hammer was that the original U-Joints were retained by a plastic injection from the factory. Required a ball joint tool and an impact to snap them loose. Look at the ear of the drive shaft, notice the little white spot? That is what I am talking about.
bbradUSMC is offline
post #92458 of 112599 Old 01-21-2014, 09:01 AM
jjvw
jjvw's Avatar
A blowtorch also works to break the plastic injection free.
2003 Rubicon
jjvw is online now
post #92459 of 112599 Old 01-21-2014, 09:03 AM
festerw
festerw's Avatar
You won't change the alignment at all if you're just replacing the u-joints.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
post #92460 of 112599 Old 01-21-2014, 09:15 AM
wwch99tj
Cheers
Check ebay
http://www.ebay.com/bhp/iggee-seat-covers-jeep
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
modifications , tj
zackcj7 , Zigster
