What did you do to your TJ today? - Page 6160 - JeepForum.com
 820Likes
post #92386 of 113376 Old 01-18-2014, 07:59 PM
TXLJ
Installed a trussed locked hp30, axle seals, 1 " body lift, rebuilt and balanced front ds, and a new radiator to round it out. forgot, clutch master and slave cylinders
TXLJ is offline
post #92387 of 113376 Old 01-18-2014, 08:08 PM
tvwebguy
Installed a Teraflex oil skid plate.
tvwebguy is offline
post #92388 of 113376 Old 01-18-2014, 08:16 PM
Griff1918
Originally Posted by hewesyourdaddy View Post
Put on a set of 2013 Rubicon wheels and tires.
I wanted the black ones but I couldn't pass up the deal I got on these.
There is a black set up for sale for pretty cheap in the classifieds
Griff1918 is offline
post #92389 of 113376 Old 01-18-2014, 08:57 PM
Jayson44
installed my CB, "fixed" the latches on my doors so they actually work (they're still loose though...so new one's in the future), and put my high-lift on the bumper.
J.
98 TJ Sahara patrolling the FSRs above Denver...
Colorado Jeep Club Member #280
Jayson44 is offline
post #92390 of 113376 Old 01-18-2014, 09:50 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Same one I'm trying to sell, I never even scratched it up.
May TJ of the Month 2015
TexasTJ is offline
post #92391 of 113376 Old 01-18-2014, 11:02 PM
sjones26573
Replaced the power steering pressure line and flushed the system using the return line. Had to get all the power steering fluid out and get proper ATF in. Return line had some non-reusable clamp so we used a normal hose clamp instead.
Did a late night last minute before-ride axle shaft u joint replacement. Left the hub on the stub and used the hammer method to knock the caps loose. Dry as a bone. Pressed in the new Spicer joint with a vise and reassembled everything, ready to put the gear oil in in the morning. Still want to do the other side sometime but this one was a ticking (literally) timebomb.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #92392 of 113376 Old 01-19-2014, 08:28 AM
Justins_TJ
Finally got my A to Z Fab winch mount and installed my Christmas present. It required a bit of modification. I'll make a thread explaining for the next person that tries this combination.
Justins_TJ is offline
post #92393 of 113376 Old 01-19-2014, 08:32 AM
tyvanwie
Is that just the stock bumper cut down? Looks good.
tyvanwie is offline
post #92394 of 113376 Old 01-19-2014, 08:59 AM
blubaru2002
Replaced my positive battery terminal. Also attached my KC's positive wires to the side post terminal on my optima red top. I kept the winch hooked up to the main top terminal.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #92395 of 113376 Old 01-19-2014, 08:59 AM
shatteredsoul
After almost two years of buying my TJ I finally installed a CB (always broke), went with the Uniden 510 along with a 4' Firestik.
shatteredsoul is offline
post #92396 of 113376 Old 01-19-2014, 09:08 AM
Justins_TJ
Yeah I just cut the ends off. Maybe four inches from either side
post #92397 of 113376 Old 01-19-2014, 03:16 PM
DezertTJ
Looked into why i was getting terrible mileage even after changing the plugs. Found the oem air filter to be black instead of white and made in 2011. Looking at the carfax, that's when it was at a dealer for a tune up last. Figured it was time for a change
DezertTJ is offline
post #92398 of 113376 Old 01-19-2014, 03:52 PM
jjvw
jjvw's Avatar
I joined the Diehard Platinum club today. The 3 year old Walmart battery that came with the Jeep has felt weak recently and stopped holding a charge a couple days ago.
The Diehard is at least 5lbs heavier than the old battery!
2003 Rubicon
jjvw is online now
post #92399 of 113376 Old 01-19-2014, 04:54 PM
apayne
Repainted my rear bumper with some spray on bedliner and mounted the fire extinguisher.
And put a shift boot on my auto shifter
Advocare - We Build Champions!
www.advocare.com/1210313
apayne is offline
post #92400 of 113376 Old 01-19-2014, 05:48 PM
TanMan99
Gave her a long overdue washing.
TanMan99 is offline
modifications , tj
moemuledeer
