What did you do to your TJ today? - Page 6153 - JeepForum.com
 1069Likes
post #92281 of 113812 Old 01-14-2014, 06:50 PM
TomTJ97
Originally Posted by thedaringmove View Post
Forgot the pic ha
it's perfect because they look clean and there's so much room to wire them up.
I'm planning on putting driving lifts on my push bar eventually and doing exactly what you did here and put the switches right next to each other
TomTJ97 is offline
post #92282 of 113812 Old 01-14-2014, 08:20 PM
jlp437
Stuck a group 65 battery in the TJ. Fits like glove. The battery tray needed a massage with an angle grinder and I used a hold down kit from Walmart
jlp437 is offline
post #92283 of 113812 Old 01-14-2014, 08:27 PM
JStMarie
JStMarie's Avatar
Changed sway bar links on my '06.
Manually adjusted the "automatically adjusting" rear brakes on the '98. One of the adjusters was seized opposite the thread side. Opened up the thread side and sprayed some PB Blaster in there and let it sit. Once I got the end off I cleaned her up and put her back on. Can park the manual on hills again without thinking I'll come back to to it crashed at the bottom of the hill.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline
post #92284 of 113812 Old 01-14-2014, 08:41 PM
Mattific
Currently building a tire carrier for my tj
This is how it looks as of right now. Gotta add the D-ring tabs, mount on the back to attach it to the frame, and the stock tire carrier will be welded onto the 2 bars on the tire carrier. Then it will get powder coated and be done!
Mattific is offline
post #92285 of 113812 Old 01-14-2014, 09:00 PM
carbert
Pretty sweet....hows that latch mechanism? Works well?
carbert is offline
post #92286 of 113812 Old 01-14-2014, 09:13 PM
Mattific
Seems like it'll work. There's a little bar at the left end where the tire carrier ends that the latch pulls it down onto. There's a plate behind it too spit won't swing back too far. I'll have to see how it holds up on the trails though
Mattific is offline
post #92287 of 113812 Old 01-14-2014, 09:19 PM
Dave02TJ
Those latches work great when mounted horizontally, so I imagine it will work equally well vertically for you.
Dave02TJ is offline
post #92288 of 113812 Old 01-14-2014, 09:37 PM
91rrc
Originally Posted by Tonellin
Fluid filmed the jeep, this stuff is amazing...recommend it to anyone in the rust belt
What is fluid filmed?
91rrc is offline
post #92289 of 113812 Old 01-14-2014, 09:42 PM
aquezada
Originally Posted by glake
Finished up the trunk on my LJ.
Nice job!
aquezada is offline
post #92290 of 113812 Old 01-15-2014, 04:44 AM
wwch99tj
A protective coating
http://www.fluid-film.com/
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #92291 of 113812 Old 01-15-2014, 05:41 AM
JEK3
JEK3's Avatar
Originally Posted by cbrant View Post
Found out my LJ came with both tops like the ad said, but no frame for the soft-top. That's gonna be a task to find.
If you were closer to me, I'd let you have the one in my garage (missing a few small pieces, but mostly there). Those things are too big to ship.
JEK3 is offline
post #92292 of 113812 Old 01-15-2014, 07:31 AM
Tonellin
A rust inhibitor and corrosion resitant that comes in a spray can or gallon cans. Ever wonder why plow/salt trucks don't look like giant rust buckets even though they only see winter work? Most towns absolutely drench their vehicles in this and its been around for years.
It's non conductive, non tacky, wont freeze and you can literally spray it on anything so everything under my jeep gets hit
It's an amazing product that has a bizillon applications, definitely recommend it as necessary for anyone in the rust belt
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #92293 of 113812 Old 01-15-2014, 08:39 AM
Ben
Motor mounts showed up last night.
Ben is offline
post #92294 of 113812 Old 01-15-2014, 10:39 AM
06philaTJ
Installed an ARB (IPF) H4 headlight wiring harness this morning. It was cheaper than the rallylights harness when I bought it and the quality is great. Couple things to note:
-You don't need to remove the headlights, only the headlight bezels to make it a bit easier to move the loom through the grill up to the driver's side headlight.
-The majority of the wiring/relays is set up to be on the passenger side and use the passenger side headlight plug as the trigger. This worked to my advantage as I did not want to use the OEM driver's side headlight plug since it has been causing me issues for the last few months.
-I mounted the relays on the firewall to the right of the heater core box. The relays/relay plugs are very heavy-duty and large so if you have or are going to install a cowl intake, you might have to great creative with mouting them.
-There are three small plugs in the wiring loom attached to the relays. These are not used as ARB included them for Toyota truck applications.
Overall the install was very simple (took about an hour taking my time), headlights work great, and as an added bonus my TJ runs/performs better and starts easier since I cleaned the all of the battery/cable connections at the same time.
06philaTJ is offline
post #92295 of 113812 Old 01-15-2014, 11:04 AM
ryan97TJ
Installed my 2" BDS lift. Gained about 2-3/8" in rear, and near 3.5" up front, but my original front springs were in bad shape and sagging horribly. Added a 3/4" spacer in the front as well, now the front sits about 1/2" higher than the back. I expect a little settling though, and when I take the hard top off after this winter should be nice and level I would expect.
I was not planning on the front axle shifting roughly 1.5" though with a 2" lift. Looks like adjustable track bar will be ordered shortly.
ryan97TJ is offline
modifications , tj
Holm-z , TJR238
