What did you do to your TJ today? - Page 6148 - JeepForum.com
 215Likes
post #92206 of 110778 Old 01-12-2014, 12:32 PM
TJ_Tim
Interwebz Specialists
TJ_Tim's Avatar
After fighting TPS sensors and IAC sensors and clearing and rechecking codes... The jeep is once again going AWOL
Now throwing codes
P0122 - TPS voltage low
P0132 - O2 short to bank 1
P0500 - vehicle speed sensor
Frustration - 1
Tim - 0
Sent from Teletran 1
1969 Mercury Cougar 351w
1998 Jeep Wrangler Sport 4.0
2009 Yamaha V Star 950
2006 Jeep Commander 4.7 Base
Build Thread: Operation Funsized
TJ_Tim is offline
post #92207 of 110778 Old 01-12-2014, 12:36 PM
sjones26573
Now throwing codes
Frustration - 1
Tim - 0
Hmmm... New Mopar TPS cleared my P0122 right up.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #92208 of 110778 Old 01-12-2014, 12:42 PM
TJ_Tim
TJ_Tim's Avatar
Did that already. Threw the TPS code and the one for the IAC. Got 2 sensors from vautozone and they were both bad. Went and got the mopar one and it cleared. Switched out the IAC and cleaered all the codes. Drove it around the block and warmed it up and now I have 3 codes.
TJ_Tim is offline
post #92209 of 110778 Old 01-12-2014, 01:37 PM
GilaMtnJeep
Brian & Stewy in 2016!
GilaMtnJeep's Avatar
Have you checked the wiring and made sure all the grounds are good?
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
http://www.treadlightly.org/
Siena Jeep Owner's Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #92210 of 110778 Old 01-12-2014, 01:48 PM
0IIIIIII0
Originally Posted by jeepwrangler97
Haha, awesome. Post pics when you're done. I gotta fishing cutting mine...then painting the fenders (under the flare), then the flares & bumpers are getting rattle can bed liner Sent by a messenger bird
We'll have a Joan Rivers "who wore it better" contest
Sent from my TJ
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #92211 of 110778 Old 01-12-2014, 01:49 PM
bbradUSMC
What I was thinking. Trace all of your wiring and look for any fraying or loose ground wires.
OT: Finished painting all wheels.
When reinstalling the tire I didnt realize the board I was using on top of my jack had a nail sticking out of it. While the axle was resting on jack stands the board fell off the jack next to the inside of the tire. When I remounted the tire the board go caught between the jack and tire and the nail went right into the side wall. Patched with on of those plugged things from Advanced Auto for now. Will see how long that lasts. Time to start saving for another tire.
bbradUSMC is offline
post #92212 of 110778 Old 01-12-2014, 03:21 PM
Cptjeeves
-50C had to open the rear gate thought it was a little stuck, turns out it was basically a iceberg and when I opened it, it stripped off all the tail gate seal, so anyone run without it? Or had a suggestion for a adhesive?
Cptjeeves is offline
post #92213 of 110778 Old 01-12-2014, 03:31 PM
0IIIIIII0
All done...
Ignore the half assed paint job. Was quickly running out of daylight and had to get something on there to protect it.
I decided to leave the inner brace intact. I like the sort of aggressive look it has now. I just trimmed the cut edge in self stick automotive moulding and I'm quite pleased.
Sent from my TJ
- Samuel Adams
post #92214 of 110778 Old 01-12-2014, 04:05 PM
bwall_1972
Ordered all new pre-
formed stainless steel brake lines...mine are about to burst.
bwall_1972 is offline
post #92215 of 110778 Old 01-12-2014, 04:41 PM
jeepwrangler97
Originally Posted by 0IIIIIII0 View Post
All done...
Sent from my TJ
Looks good!
Here's mine...the flares aren't dry yet, so they will have to go on tomorrow. I also need to paint the rears tomorrow, & the bumpers...& wire my new reverse lights in.
Clear JK turn signals should be here soon...don't judge my zip tied signals
I left the support brackets in tact & put some paint on em
jeepwrangler97 is offline
post #92216 of 110778 Old 01-12-2014, 04:41 PM
IH8PEPL
Attachment 992314
Daymn!
IH8PEPL is offline
post #92217 of 110778 Old 01-12-2014, 04:52 PM
0IIIIIII0
Looks good! Here's mine...the flares aren't dry yet, so they will have to go on tomorrow. I also need to paint the rears tomorrow, & the bumpers...& wire my new reverse lights in. Clear JK turn signals should be here soon...don't judge my zip tied signals I left the support brackets in tact & put some paint on em Sent by a messenger bird
Not too shabby. You left a lot more of the metal than I did. I took it back to where the bracket lip is and went straight across.
Are you going to do anything with the raw edge?
Sent from my TJ
- Samuel Adams
post #92218 of 110778 Old 01-12-2014, 04:59 PM
jeepwrangler97
Sent from my TJ
Thanks, I left a good bit b/c most of my paint on the fenders is in pretty good shape....& thought it'd look better on mine
I think I'm going to add door edge trim molding to the fender; as long as it doesn't throw off the line with the flares. At the very least, I'll add the trim molding to the part I cut by the grille.
Oh &:
post #92219 of 110778 Old 01-12-2014, 06:21 PM
SpringRubiconTJ
Replaced a leaking inner axle seal on my D44 and replaced both axle u joints while i was in there. just have to button up the brakes and fill the diff in the morning.
SpringRubiconTJ is offline
post #92220 of 110778 Old 01-12-2014, 07:39 PM
DezertTJ
took it on it's first trail ride since I bought it
DezertTJ is offline
modifications , tj
