What did you do to your TJ today? - Page 6144 - JeepForum.com
 438Likes
post #92146 of 112203 Old 01-09-2014, 07:47 PM
TJ_Tim
Interwebz Specialists
TJ_Tim's Avatar
Originally Posted by blubaru2002
What was your jeep doing in order to warrant replacing the TPS?
Threw code P0122. Bucking and surging under acceleration and nearly stalling out at idle. Bought a bad sensor, code remained so I put in another sensor. That fixed the issue intermittently for a week but the code remained so today I put the third sensor on and the code disappeared.
Sent from Teletran 1
1969 Mercury Cougar 351w
1998 Jeep Wrangler Sport 4.0
2009 Yamaha V Star 950
2006 Jeep Commander 4.7 Base
TJ_Tim is offline
post #92147 of 112203 Old 01-09-2014, 07:49 PM
JBTJ
Where did you get the sensors from?
JBTJ is offline
post #92148 of 112203 Old 01-09-2014, 07:54 PM
TJ_Tim
TJ_Tim's Avatar
2 from autozone. The last one from the stealership.
TJ_Tim is offline
post #92149 of 112203 Old 01-09-2014, 07:57 PM
JBTJ
Just confirming my suspicions, Thanks
JBTJ is offline
post #92150 of 112203 Old 01-09-2014, 07:59 PM
TJ_Tim
TJ_Tim's Avatar
Yep. As were mine.
TJ_Tim is offline
post #92151 of 112203 Old 01-09-2014, 08:01 PM
sjones26573
5100's arrived back at home and sliders finally sold for $180.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #92152 of 112203 Old 01-09-2014, 09:33 PM
joeyk803c
Bought a AGM battery from my work. Have a new 12 fuse panel that I will be wiring in later this week. Going to use it as a secondary box for all my extra electrical parts on the Jeep.
joeyk803c is offline
post #92153 of 112203 Old 01-09-2014, 10:16 PM
jjvw
jjvw's Avatar
My new to me Old Man Emu springs and shocks arrived today!
2003 Rubicon
jjvw is online now
post #92154 of 112203 Old 01-09-2014, 10:27 PM
Necko2529
Will be following to see your impressions on the overall performance since we have somewhat similar Jeeps. ~
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #92155 of 112203 Old 01-09-2014, 11:25 PM
jjvw
jjvw's Avatar
Sienna Pearl Rubis 4ever!
I'll start a thread on the install. My plan is to try to get a thorough understanding of bump stops, track bars, control arms, etc during the process and also do it from a beginner's perspective starting from stock. The goal is to move to 33" tires and intelligently over-build everything else to the best of my abilities.
2003 Rubicon
jjvw is online now
post #92156 of 112203 Old 01-09-2014, 11:27 PM
Texanav8r
New spark plugs because I had a CEL / Code for 'Cylinder 6 Misfire.' Huge difference - soooooo much smoother now at idle!
My Jeep Build Thread: http://bit.ly/15MGE7C
Texanav8r is offline
post #92157 of 112203 Old 01-10-2014, 12:03 AM
686keydragon
My stock tie rod had seen it's better days so I swapped in a 98 V8 ZJ tie rod. This thing is much beefier than the stock one. As many other threads have stated this is a direct bolt in swap. Adjusting the toe is a lot easier with the adjusting sleeve compared to the stock bar too which is nice.
686keydragon is offline
post #92158 of 112203 Old 01-10-2014, 12:07 AM
TexasTJ
No Longer DD
TexasTJ's Avatar
Re-tuned the CB, could here the other guys from ~5 miles away in the city.
May TJ of the Month 2015
TexasTJ is offline
post #92159 of 112203 Old 01-10-2014, 07:40 AM
SouthFLJeeper
SouthFLJeeper's Avatar
Originally Posted by method84 View Post
I just went with the 4.5 RE superflex kit but swapped out the 4.5 springs for the 3.5. Its a pretty complete kit minus the rear adj. trackbar. I havent installed it yet but Ive only heard good things about RE
I'm planning on doing one of the RE lifts. Curious why you switched out the 4.5 springs with the 3.5?
'00 TJ Sahara - 1" Body Lift, awaiting many upgades
'00 TJ Sahara (R.I.P.) - 2.5" Rancho Lift, 2" BB, 1" Body Lift, 35" XTerrain's, Warn 9000lb Winch, Warn Bumpers & Sliders
'05 Excursion 6.0 Diesel
SouthFLJeeper is offline
post #92160 of 112203 Old 01-10-2014, 09:42 AM
GilaMtnJeep
GilaMtnJeep's Avatar
The Echelin brand from NAPA is a quality replacement, too. Much cheaper than the stealership. Got my TPS there, no issues.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
modifications , tj
Ben
