What did you do to your TJ today? - Page 6112 - JeepForum.com
 1227Likes
post #91666 of 114047 Old 12-22-2013, 06:08 PM
jarrodblake
1978 CJ10
New smittybuilt tonneau cover came in.
Now I need to add a lip to the willys tail gate to keep it sealed up.
jarrodblake is offline
post #91667 of 114047 Old 12-22-2013, 06:24 PM
sjones26573
For those that asked for a write up on the panel and fuse block, here's what I've got so far.
http://www.jeepforum.com/forum/f20/w...block-1914898/
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #91668 of 114047 Old 12-22-2013, 07:05 PM
rbkelley89
thanks man it looks like a good project that im dipping into myself
2001 orange tj 2.5L (113,000) 35" Km2 Black rims D lp 30 Front and d 44 rear with ARB 1"BD MML, 1.25" BL, 4" RC Lift, Flat tc Skid, Adj rear ca's (front soon) TW rear DS, Novak shifter cable, JB ss SYE, RE angled rear trackbar, 8,000Lb Mile marker, Custom front and rear (w/swing) bumpers. Homemade CAI. Lots more to come.
rbkelley89 is offline
post #91669 of 114047 Old 12-22-2013, 07:08 PM
sjones26573
No prob.
Jeep-Owner.com
post #91670 of 114047 Old 12-22-2013, 07:12 PM
rbkelley89
just bolted up my smittybuilt corners. Man i might be in some trouble getting the leds cut out my hole saw just wasnt cutting it and stuck a bunch became very dangerous so i need to figure out another way. anyone have any tips? I can take it all off at my grandmas tomorrow here partner has a nice shop im going to be using tomorrow for motor mount swap and he has a acetylene torch i can do it with but ive never been able to do a sturdy cut with a torch. I have a black and decker jig saw id need to pick up some heavy duty blades though.
also i dont like the look of the corners next to my sliders. has anyone sanded these down flat and repainted them to match. i think thats what im going to do.
post #91671 of 114047 Old 12-22-2013, 07:49 PM
jeeprubi2005
Took my drivers seat apart to find the squeak and found some cracked metal so i broke out the welder and fixed it all of 30 min work
jeeprubi2005 is offline
post #91672 of 114047 Old 12-22-2013, 08:44 PM
Badonkadonkey
Repaired the blown center console subwoofer with only slightly more than popsicle sticks and chewing gum.
Yellow 2003 TJ: Stock, 4.0L I6, Manual Transmission
Badonkadonkey is offline
post #91673 of 114047 Old 12-22-2013, 08:47 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You got a wrtie up on that switch panel and fuse box? Im about to add a ton of switches and want to design something
The best in cab remote is the one that re-uses the plug that comes on the winch remote. Remove and record the wiring pin out on the switch end. Plug the other end into the winch. Route it through the engine compartment to the dash location of your choice, mount and hook up the switch.
If you want an arm switch, break the ground side and run it through a simple On Off switch with a guard on it.
That way you never have to delve into the solenoid wiring, it takes no skill or understanding of wiring and if you want to use a remote from outside the rig, simply unplug the dash mounted version and plug in the remote.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #91674 of 114047 Old 12-22-2013, 09:02 PM
sjones26573
That isn't a bad idea. I just like the clean integrated look and don't mind figuring out the wiring. It wasn't hard at all but I enjoy this so it may be more difficult for someone else.
Jeep-Owner.com
post #91675 of 114047 Old 12-22-2013, 09:26 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I wanted an in dash winch control with an arm switch (and flashing arm light) so I did this (I installed it there so that it could be used while standing outside the Jeep):
Added a harness plug at the winch for the dash control that allowed the original Warn remote harness hook-up plug to remain in place:
And added switch on the front of the winch (with flashing arm light powered from the dash arm switch) for respooling the winch line:
I haven't used the Warn control harness after installing this setup, its been stored in one of my tool bags for over 8 years without use...
Knuckelhead is offline
post #91676 of 114047 Old 12-22-2013, 09:30 PM
yellow_snocone
Originally Posted by Knuckelhead View Post
I wanted an in dash winch control with an arm switch (and flashing arm light) so I did this:
Added a harness plug at the winch for the dash control that retained the OEM remote control hook-up cable mount in place:
And an switch on the front of the winch (with flashing arm light powered from the dash arm switch) for respooling the winch line:
I haven't used the Warn harness control cable after installing this setup, its been in one of my tool bags for over 8 years without use...
Looks like a smiley face on the front of your winch
Military Jeepers
S.W. New Mexico region
yellow_snocone is offline
post #91677 of 114047 Old 12-22-2013, 09:36 PM
sjones26573
I haven't used the Warn control cable harness after installing this setup, its been stored in one of my tool bags for over 8 years without use...
Nice. Mine has an arm switch as well and the upper light will be the arm light. I like the flash idea. Can't integrate that into mine unfortunately, unless I used another separate light. I had thought about integrating one into the cluster somehow.
Jeep-Owner.com
post #91678 of 114047 Old 12-22-2013, 09:57 PM
Knuckelhead
AFSOC Retired
I've been told that a time or two:
I just tell them that I have a happy Jeep.
I made that cover from a mud flap to keep dirt and mud (mud = dum) off my winch line...
post #91679 of 114047 Old 12-22-2013, 10:09 PM
yellow_snocone
Thats a great idea and way to keep the line clean
Military Jeepers
post #91680 of 114047 Old 12-22-2013, 10:22 PM
thedaringmove
Went wheeling up in big bear.
thedaringmove is offline
modifications , tj
festerw
