What did you do to your TJ today? - Page 6099 - JeepForum.com
 379Likes
post #91471 of 111944 Old 12-15-2013, 11:12 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by muddy05tj View Post
Installed my jks 1.25 inch BL and hopefully tomorrow the MML goes in so she's back on the road to play in the fresh powder we got... Any tips for it??
Remove the motor mount from the engine block (3 bolts) on the drivers side so that you can get the long bolt out of the mount its self, the A/C compressor prevents you from removing that bolt with the mount still attached to the engine block. When you reinstall the motor mount, install the long bolt from the rear to prevent that issue in the future... HTH
Knuckelhead is offline
post #91472 of 111944 Old 12-15-2013, 11:30 PM
rdock31
I got it out even with the A/C compressor there, didn't have to remove the block bracket. Just takes a little time and patience. Whatever technique works best for, go for it.
BDS - Savvy - Brown Dog - AtoZ - Metalcloak - Falken - RC
rdock31 is offline
post #91473 of 111944 Old 12-16-2013, 01:10 AM
Itstime
I also kinda fixed my seat I need a new spring so it folds up and away. Does anyone know if that's a real pain in the butt? Normally springs are.
Itstime is offline
post #91474 of 111944 Old 12-16-2013, 01:16 AM
Knuckelhead
AFSOC Retired
That's because your 1999 4.0L TJ doesn't have the A/C compressor in the same location as muddy05tj...
post #91475 of 111944 Old 12-16-2013, 01:21 AM
elltim92
Put in a new Tie Rod, Drag Link, and Track Bar. Removed the Steering Stabilizer, Hopefully cured my DW. Gonna Take it in for an alignment in the AM before taking it for a full on test run.
'06 TJ SE. 6Spd, 2.5L, 6 spd manual, 31"x10.5r15's, Crown HD Steering kit
elltim92 is offline
post #91476 of 111944 Old 12-16-2013, 01:31 AM
Knuckelhead
AFSOC Retired
Why not do the alignment for the front steering yourself and save some money?
Have you met Stu?:http://www.stu-offroad.com/index.asp
post #91477 of 111944 Old 12-16-2013, 01:53 AM
elltim92
Yeah, I did a fairly good one after I put the Linkage in, but the Jeep is my DD, and going in for inspection regardless, so for the extra $60 I'm not that worried about it.
With the amount of cash thrown at the Jeep, I'm not crying over the cash for the peace of mind.
I do like this Stu guy though, This looks like a really good resource, Thanks!
elltim92 is offline
post #91478 of 111944 Old 12-16-2013, 02:09 AM
thedaringmove
Cut up a few hockey pucks that got delivered today. (Not as easy as it sounds)
Tomorrow I'll go pick up some longer hardware and if I'm really lucky I'll get them installed as bumpstops in the rear. Been brainstorming the easiest way to get the rear coils out. Life would be so much easier with a hilift
thedaringmove is offline
post #91479 of 111944 Old 12-16-2013, 02:16 AM
LukeADukes
Let my local shop install a new radiator and tstat. They do a much better job than me. Changed spark plugs then went out in the snow. Needs a good wash
Always look both ways before crossing the stream.
LukeADukes is offline
post #91480 of 111944 Old 12-16-2013, 02:23 AM
Knuckelhead
AFSOC Retired
If you do happen to contact him, tell him from me that he's a old fart and Minnesota is going to suck!...
post #91481 of 111944 Old 12-16-2013, 04:54 AM
JEK3
JEK3's Avatar
Knuckelhead said to pull the motor mount off the engine. An alternative method (what I did) is to pull the long bolt out as far as you can, cut it in half with a cut-off wheel, and pull the remainder out. A replacement bolt is less than $10 at just about any auto parts store (found in the "Help" parts section). I believe it was Blaine who originally posted this method.
JEK3 is online now
post #91482 of 111944 Old 12-16-2013, 06:43 AM
Ben
Getting ready to pull the 4 squirrels of fury.
Ben is offline
post #91483 of 111944 Old 12-16-2013, 07:24 AM
kajones
This weekend I replaced my stock rubber brake lines with some steel braided extended brakes lines from roughcounty.
kajones is offline
post #91484 of 111944 Old 12-16-2013, 08:13 AM
Squint77
Squint77's Avatar
We thought about doing it this way but the three bolts are easy to get to, so no need...
Squint77 is offline
post #91485 of 111944 Old 12-16-2013, 08:15 AM
Squint77
Squint77's Avatar
We thought about doing it this way but getting a standard grinder or even a dremel was much harder than taking out the three bolts which are easy to reach...
Greg
(Soft top info:
Squint77 is offline
modifications , tj
CodaMan
