What did you do to your TJ today? - Page 6098 - JeepForum.com
 678Likes
post #91456 of 113124 Old 12-15-2013, 04:08 PM
thedaringmove
Originally Posted by LA-Sahara
Finally did some real work on my homemade tube fenders. Used the cardboard templates to make the outer tube rails. Came out awesome!
Sweet! Look good!
thedaringmove is offline
post #91457 of 113124 Old 12-15-2013, 04:47 PM
jbryant
Dropped the gas tank to drain the 2 year old gas that was left. Luckily there was very little in there. Whole job wasn't as bad as I thought it would be, only took about 45 mins. Now I need a battery and some vacuum lines and hopefully the Magnum will come to life.
2000 TJ 5.9/46re, Zone 4.25, 35" Goodyear MTR's w/Kevlar
jbryant is offline
post #91458 of 113124 Old 12-15-2013, 05:17 PM
Jeeper4life88
2016 JK Wrangler
Replaced the crank sensor on mine, hopefully my problems are fixed!
2016 Jeep Wrangler Unlimited
2004 Jeep Liberty
1981 Jeep CJ5
1977 Jeep CJ5
Jeeper4life88 is offline
post #91459 of 113124 Old 12-15-2013, 05:32 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Gave the interior a little winter clean so the dealer mechanic won't get dirty pulling it into his bay, lol... 7a appt to get the OPDA tuned and then off to the muffler shop.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #91460 of 113124 Old 12-15-2013, 05:35 PM
Itstime
Put in a new TPS and battery. Nothing to big but it runs 100% better. I said goodbye to that low idle issue.
Itstime is offline
post #91461 of 113124 Old 12-15-2013, 06:24 PM
91rrc
Chased a clunking sound most of the day. It sounded like u joints in the front drive line so I pulled it. Test drove nope noise still there. Put the front back on and pulled the rear and test drove. Nope still there. Crap thought it might be the front diff coming apart. Put it on stands with just the front shaft in and no noise. Figured it must only do when under a load so I figured I might as well pull the diff cover off and inspect it. Everything looked fine. What the heck drove it again this time I could definitely tell it was coming from the rear. Now I'm thinking I snapped an axle on my pos D35. Nope what do I find a loose freakin wheel. I can't believe I spent all day chasing my tail for a loose wheel. At least it didn't fall off. One stud was broken and the others were all jacked up. Replaced all 5 put the rear drive shaft back in and test drove. Guess what no more noise.
91rrc is offline
post #91462 of 113124 Old 12-15-2013, 06:40 PM
AndyAllen
Originally Posted by zackcj7
If it's the original tranny mount from 1998 it's probably toast.
How can I tell? Ive been under there and looked but I dont know what to look for.
1998 TJ Sahara, (Sold to Dad)
1995 YJ SE, (Finishing up the deal)
AndyAllen is offline
post #91463 of 113124 Old 12-15-2013, 06:50 PM
tuhmayo
Oil change and I installed a fram air filter in my stock air box and wow does it make a difference on the road, anyone know if it'll make a difference with sucking in more off-road debris?
2000 Wrangler 4.0L
tuhmayo is offline
post #91464 of 113124 Old 12-15-2013, 06:58 PM
wwch99tj
Fram paper filter? That's what I use and if its really dusty you might need to change it sooner than
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #91465 of 113124 Old 12-15-2013, 07:07 PM
tuhmayo
Originally Posted by wwch99tj
Fram paper filter? That's what I use and if its really dusty you might need to change it sooner than Sent from my Samsung Galaxy S3 using JeepForum
Yeah that's the one and did you notice an acceleration improvement ?
2000 Wrangler 4.0L
tuhmayo is offline
post #91466 of 113124 Old 12-15-2013, 07:22 PM
wwch99tj
I've always ran one so I couldn't tell you if it makes a difference
Was you old one clogged up?
wwch99tj is offline
post #91467 of 113124 Old 12-15-2013, 07:46 PM
nickmur
Changed the CCV valve and valve cover gasket....then "test drove" it on the back country snow covered roads
nickmur is offline
post #91468 of 113124 Old 12-15-2013, 09:26 PM
muddy05tj
Installed my jks 1.25 inch BL and hopefully tomorrow the MML goes in so she's back on the road to play in the fresh powder we got... Any tips for it??
2005 Jeep Wrangler Sport, 31" Cooper Discoverer STT wrapped around Dick Cepek DC-2s, Teraflex Oil Pan Skid, Rock Ready Steering Box Skid, Rigid Industries Duallys Windshield Lights, Trucklite LED headlights, BDS 2in Suspension, JKS 1.25in Body Lift, JKS 1in MML, JKS Quicker Discos
muddy05tj is offline
post #91469 of 113124 Old 12-15-2013, 09:33 PM
JJeeper09
Take your time. And don't get frustrated with how annoying some areas are to reach
JJeeper09 is offline
post #91470 of 113124 Old 12-15-2013, 09:52 PM
thedaringmove
That's a ***** of an instal. Make positive you do one side at a time. Undo both mounts at the same time and you're most likely screwed.
modifications , tj
blkrubi88 , ladytex70 , Nueces
