What did you do to your TJ today? - Page 6052 - JeepForum.com
 1384Likes
post #90766 of 114282 Old 11-21-2013, 05:24 AM
97TJGUZZY
97TJGUZZY's Avatar
Originally Posted by carbert View Post
How's that handel work..looka very sturdy
Its this latch. You pull down to open and push forward to close it. The spring loaded pull pin with the black ball on the end holds the handle in place.
http://www.polyperformance.com/shop/...y-p-19993.html
For info on outdoor adventures in South Carolina check out
97TJGUZZY is offline
post #90767 of 114282 Old 11-21-2013, 05:47 AM
bhikku
damn thing won't start. crankshaft sensor CEL, fml
2004 Rocky Mountain Edition Wrangler
Utah Jeep Crew #152
US Navy 04-08
bhikku is offline
post #90768 of 114282 Old 11-21-2013, 06:11 AM
jetmech59
Finished the fenders and painted the body. Should I keep the grill black or paint it OD to match the body?
jetmech59 is offline
post #90769 of 114282 Old 11-21-2013, 06:13 AM
wwch99tj
Looks good black
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #90770 of 114282 Old 11-21-2013, 06:37 AM
jrallen
Originally Posted by wwch99tj View Post
Looks good black
x2. I love me some OD and flat black together
jrallen is offline
post #90771 of 114282 Old 11-21-2013, 06:43 AM
Tonellin
Either paint it OD, or repaint your sway bar cover black. I think it looks kinda funky mismatched, puts a lot of emphasis on the sway bar cover.
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #90772 of 114282 Old 11-21-2013, 08:10 AM
TrailJ
Replaced under warranty. Lasted two years. Maybe I'll get for total, then move up to agm.1385046639436.jpg
TrailJ is offline
post #90773 of 114282 Old 11-21-2013, 12:47 PM
The_Dealer
2003 KJ Liberty
Did the case seals, and sye. Waiting on the rtv to dry
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #90774 of 114282 Old 11-21-2013, 01:41 PM
Cptjeeves
Changed out to the little winter tires haha
Cptjeeves is offline
post #90775 of 114282 Old 11-21-2013, 02:15 PM
vanillathrilla
I finally got my new starter today... I'm ashamed to say it's still not finished several hours later. I'm a big guy and it's hard for me to snake my arms through some of those crevices and twist in certain directions that you need to in order to access the starter. Carpal tunnel is also kicking my *** right now... I got it in, and it fires right up, but it makes a grinding noise when it's starting. I took it back out and checked the connections because I was afraid it wasn't sitting correctly and grinding against the flywheel or something. Checked alignment, and bolted it back up--but it still makes the noise.
Now I do want to mention one thing... The starter I pulled out might very well be the original starter, and there was only one bolt in it. It was only attached via the lower bolt near the transmission and oil pan. Obviously I want to get another bolt to install it the way it's meant to be, but it never made a grinding noise like that before and it was already only bolted in with one bolt.
Should I be alarmed? Or is it probably just that simple and I just need another bolt? ...or worse, am I going to have to return the starter and repeat this process again?
edit: after doing some searching, it does sound like flywheel grinding... I guess I need to look into shimming the starter. Agreed?
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #90776 of 114282 Old 11-21-2013, 03:46 PM
sjones26573
Well today was pretty dang successful. I'm pretty confident we will have doubled our membership by time everyone joins up. There was also a large amount of people taking pictures from afar so I'm sure those will make it on Facebook and Twitter. Also sounds like we're going to have quite the crowd at our Dec 5-7 Uwharrie run.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #90777 of 114282 Old 11-21-2013, 05:03 PM
0IIIIIII0
Noticed a clunking on acceleration and then a machine one again upon deceleration driving home today
I'm thinking control arms, but not sure yet.
Sent from my TJ
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #90778 of 114282 Old 11-21-2013, 05:38 PM
jeepwrangler97
I'm not an expert...but maybe the starter isn't disengaging fast enough or something.
I'd put the other bolt in & then I'd swap it for another one if it still grinds, before I'd start shimming it. My experience is sometimes parts store reman parts are hit or miss.
Sucks about having to squeeze back in there...Haha I'm not a big guy, if I were close I'd help ya out
Sent by a messenger bird
jeepwrangler97 is offline
post #90779 of 114282 Old 11-21-2013, 05:43 PM
jeepwrangler97
That's awesome...there were like 8ish jeeps that were at my school & maybe 2-3 that wheeled...but I went to a small school.
post #90780 of 114282 Old 11-21-2013, 05:44 PM
Altonymous
2015 JK Wrangler
Technically not today.. But last weekend...
Installed a back seat
Swapped exhaust manifold
Swapped both front wheel bearings
Swapped the track bar
Swapped air filter
Swapped in new spark plugs
Changed oil and filter
Got a new set of 4 steel wheels
Rotated tires
Got aligned and balanced
GOT RID OF THE DEATH WOBBLE!
Altonymous is offline
modifications , tj
