What did you do to your TJ today? - Page 6050 - JeepForum.com
 391Likes
post #90736 of 111970 Old 11-20-2013, 03:45 PM
rikkards
rikkards's Avatar
Originally Posted by 0IIIIIII0 View Post
Have fun with that lol....if I never replace those nutserts again, it will be too soon.
What a hassle.
Yeah, I will probably be redoing mine next spring
Machete don't tweet
- Machete
rikkards is offline
post #90737 of 111970 Old 11-20-2013, 04:22 PM
Batty505a
Replaced the 2 spinning nutserts on the wife's TJ. My wife who was turning the bolt while I kept the nutsert from turning , decided to stop exerting upward force which let the breaker bar slip off and whack me in the chin. Just glad my mouth closed so no teeth were broken. Still not convinced it was an accident.
Lolz
Wives!
2006 Chevy Silverado (DD)
1998 Jeep TJ Wrangler Sport (DD)
1993 Jeep YJ Wrangler *Parts Vehicle*
Batty505a is offline
post #90738 of 111970 Old 11-20-2013, 04:25 PM
Batty505a
Originally Posted by Knuckelhead
How many well built Jeeps do you see without an expensive winch?...
Hi knuckles
Are asking if a guys jeep has a winch, it's well built?
post #90739 of 111970 Old 11-20-2013, 04:29 PM
Batty505a
Originally Posted by 1911rocks
I decided to do a bit of touch-up to my 2001 Wrangler. The Color Coded hinges for the rear door were starting to "Bubble" so I sanded them down and primed and then painted in a semi-gloss black. I also touched/repainted the Door latches. The passenger side had a bit of rust. After I did it last night, the "anality" inherent in my character dictated that I do the Driver's door as well. I also did the Center Dash surround in a Silver to go along with the Black and Silver look. I was inspired by either someone on this Forum or another Jeep Forum who had done their's in Red (Red/Black theme). Next project either Iggee's or Marathon Seat Covers. Any opinions?
I may do this in the spring. Frozen paint and snow, not a great combo lolz
post #90740 of 111970 Old 11-20-2013, 04:36 PM
Batty505a
Originally Posted by LilyBayXJ
Swapped out the 55W bulbs in my Hella's for 100W ones. Big improvement
I went to HIDs after noticing how dim the TJ lights were compared to my 06chevy.
Best investment ever! Lolz
post #90741 of 111970 Old 11-20-2013, 04:52 PM
BLK00TJ
Word to the wise if you go the bolt w/spacer install method, use a long enough bolt that you can get a pair of BIG vice grips on It. I used too short a bolt and could only grip it with a pair of channel locks with narrower jaws.
Made for a real PITA install.
There is a thread on here that explains how too get the old ones out fairly easily and I can vouch for the info. Removal was fairly painless.
I thought you were supposed to use two wrenches? Is it cheating to use an impact wrench?
BLK00TJ is offline
post #90742 of 111970 Old 11-20-2013, 04:54 PM
JEK3
JEK3's Avatar
If ya ain't cheating, ya ain't trying!
JEK3 is offline
post #90743 of 111970 Old 11-20-2013, 05:20 PM
0IIIIIII0
The problem I had was that I couldn't get the star washer to effectively hold the nutsert from spinning as we cranked the bolt down. We used the channel locks on the rim of the nutsert until it finally had enough pressure to hold itself.
Sent from my TJ
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #90744 of 111970 Old 11-20-2013, 05:25 PM
cjlinn
Made my TJ jealous by washing the wife's car.
cjlinn is offline
post #90745 of 111970 Old 11-20-2013, 05:44 PM
1911rocks
Mud testing with my Son....the Mud passed the analysis.
Pumpkins- 0,
Tannerite and 223 55gr VMAX- 3
The 223 and Tannerite won!!
1911rocks is offline
post #90746 of 111970 Old 11-20-2013, 06:09 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I don't consider it cheating and neither would you if you sold them. That way you get to sell more to the same guy.
I've found through some experimenting that a big C-clamp and an open end wrench work the best after you make a good setting tool.
Take the setting tool with the nutserts on it and hold it in the frame with the open end wrench. Clamp the wrench to the frame and it will hold the nutserts in tightly and stop the nut from turning.
I don't use the serrated washer. I take a 9/16's fine thread nut and cut a series of small shallow slots with a cut off wheel so it looks like you were marking the hour marks on a clock face. Just a series of small cuts around one side of the nut. That goes against the nutserts and the sharp edges from the cuts stop the nutserts from spinning. I use a 1/2" hardened grade 8 washer on top of that with some anti-seize on the part under the head of the bolt but not on the nut side.
A ratcheting breaker works very well and the initial upset force is not as high as folks would have you believe. The tendency is to over tighten which stresses the threads in the insert, so once it starts setting, just snug it down.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #90747 of 111970 Old 11-20-2013, 07:11 PM
jeeptjman2000
Just drove it. Its been a couple days. Over the weekend I also did blue leds in my dash and hvac. Got them from superbrightleds.com
jeeptjman2000 is offline
post #90748 of 111970 Old 11-20-2013, 07:12 PM
Wakeride89
Hey guys this is off topic but where should I go to get some chromo shafts for my dana 30 in my tj? I have 35" KM2s an arb and 456 gears and I broke a stock axle last time I went out and I don't want to do it again.
Wakeride89 is offline
post #90749 of 111970 Old 11-20-2013, 07:51 PM
dwbrown
2014 JK Wrangler
Originally Posted by thedaringmove View Post
Sweet! Can you post a picture of it before you put it in?
I haz pictures now.
Off the Jeep, paint drying.
Moar
Back in
I think Hendrix pulls off the truck look bettter.
USAF
dwbrown is offline
post #90750 of 111970 Old 11-20-2013, 08:02 PM
gumby_144
Originally Posted by dwbrown View Post
I haz pictures now.
Moar
Back in
What cage kit is that
gumby_144 is offline
modifications , tj
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
