What did you do to your TJ today? - Page 6037 - JeepForum.com
 817Likes
post #90541 of 113373 Old 11-14-2013, 09:24 AM
Navydoc1
Originally Posted by mrblaine
Almost savvy. A savvy version would recognize that two small screws into thin sheet metal is not quite as good as two larger fine thread machine screws into nutserts. It's also slightly more savvy if you keep the height tucked down as low to the dash as possible for better viewing sorta like this.
What did that mount cost though? I built mine from a scrap piece of aluminum i had laying on the shelf....Mine is sturdy it doesn't move at all, and with it sitting behind the registration and inspection stickers the view isn't anymore obstructed than it normally is
Navydoc1 is offline
post #90542 of 113373 Old 11-14-2013, 09:34 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I have no idea what it cost. I made it from some scrap sheet metal I had laying in the shop, a vise, a hammer, and a bit of welding. My wife has a friend with a powder coat shop and she got it coated for 10 bucks.
As far as the view, you are probably taller than the 64" or so that my wife is, so keeping it as low as possible was paramount.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #90543 of 113373 Old 11-14-2013, 09:49 AM
Navydoc1
Really nice job on the design, I thought it was a piece like rugged ridge sells. Yeah at 6'1 I don't have any problem seeing over the cb.
Navydoc1 is offline
post #90544 of 113373 Old 11-14-2013, 11:24 AM
0IIIIIII0
Finally replacing the mtr's on the front of my jeep with Duratracs... Been a hell of a month. New tires for the wife, broken shock, worn out skid plate nutserts, leaking tranny seal, flat tire...
Is it December yet?!
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #90545 of 113373 Old 11-14-2013, 02:21 PM
Cptjeeves
Was out cruising around in the slush and saw a sweet yj on the road that I have never seen before I wonder where it was hiding
Sorry double post
Cptjeeves is offline
post #90546 of 113373 Old 11-14-2013, 02:24 PM
Cptjeeves
Was out cruising around in the slush and I saw a sweet yj that I have never seen before, I wonder where it was hiding....on another note saw about 10 stock Jk's lol
post #90547 of 113373 Old 11-14-2013, 02:35 PM
0IIIIIII0
Originally Posted by Cptjeeves
Was out cruising around in the slush and saw a sweet yj on the road that I have never seen before I wonder where it was hiding Sorry double post
Is he running tj doors?
Sent from my TJ
- Samuel Adams
post #90548 of 113373 Old 11-14-2013, 02:50 PM
rikkards
rikkards's Avatar
Hemmed and hawed of whether I should buy a diff spreader for my forthcoming HPD30 regear. I am not only regearing but also putting in an ARB (RD100). The reason for the indecision is that I have read that you need to go with a higher carrier preload to ensure that the carrier doesn't leak under load. I guess because of the size of the diff it has a tendency to flex a bit causing enough deflection that could cause the carrier to leak. However I am unsure if this occurs on the new model or was a older (RD30) model issue that was resolved.
Machete don't tweet
- Machete
rikkards is online now
post #90549 of 113373 Old 11-14-2013, 03:03 PM
wwch99tj
Sent from my TJ
Looks like it's got the windbreaker to me
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #90550 of 113373 Old 11-14-2013, 03:04 PM
vanillathrilla
Finally installed a new HVAC mode switch that a forum member was nice enough to send me... Still only blowing from the defrost, but now I have another problem as a result of it. I think the shaft might have been longer on the switch that he sent me, because the knob won't fit back on. I can hold the knob on the shaft to select different modes, but the knob itself won't sit flush inside the opening enough to stay on. Did I do something silly wrong? You can only install the switch one way.
Any input on why it's STILL only blowing through the defrosters would be absolutely fantastic. Temp's have been in the low 20's and 30's at night here already, and will surely get much colder as we get into the winter. This is something I can't put off any longer. I'm going to look for an entire new non-a/c HVAC unit in the meantime.
Also, I'm pretty sure I've found why speed 4 has never worked. The plug on the inside of the speed switch is clearly melted. I guess I'll add that to the ever growing list of things I need just to make my TJ...normal.
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #90551 of 113373 Old 11-14-2013, 04:50 PM
The_Dealer
2003 KJ Liberty
Spent half the day trying to track down some vibes. Thought it was the rear, so I pulled that shaft. Then I pulled the front. Then pulled both. The vibe was there with either shaft in, but gone with both out. Also greased the front CV. Set it on 4 jack stands to see where the vibes were coming from. All 4 of my soft 8's. Great. I've been wanting some pro comp 8069's anyways.
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #90552 of 113373 Old 11-14-2013, 05:00 PM
0IIIIIII0
Originally Posted by vanillathrilla
Finally installed a new HVAC mode switch that a forum member was nice enough to send me... Still only blowing from the defrost, but now I have another problem as a result of it. I think the shaft might have been longer on the switch that he sent me, because the knob won't fit back on. I can hold the knob on the shaft to select different modes, but the knob itself won't sit flush inside the opening enough to stay on. Did I do something silly wrong? You can only install the switch one way. Any input on why it's STILL only blowing through the defrosters would be absolutely fantastic. Temp's have been in the low 20's and 30's at night here already, and will surely get much colder as we get into the winter. This is something I can't put off any longer. I'm going to look for an entire new non-a/c HVAC unit in the meantime. Also, I'm pretty sure I've found why speed 4 has never worked. The plug on the inside of the speed switch is clearly melted. I guess I'll add that to the ever growing list of things I need just to make my TJ...normal.
You've got a vacuum leak. Follow the vacuum hoses that go through the firewall.
When mine was doing that, a hose had just popped off a nipple. Popped it back on and instantly fixed.
Hopefully it's not cracked.
Sent from my TJ
- Samuel Adams
post #90553 of 113373 Old 11-14-2013, 05:03 PM
Jeffro06
Jeffro06's Avatar
I haven't seen my TJ for days, much less done anything to it.
Jeffro06 is offline
post #90554 of 113373 Old 11-14-2013, 05:17 PM
Cptjeeves
Sent from my TJ
not to sure unfortunately i didn't get to meet the guy driving it
post #90555 of 113373 Old 11-14-2013, 05:28 PM
0IIIIIII0
Originally Posted by wwch99tj
Looks like it's got the windbreaker to me Sent from my Samsung Galaxy S3 using JeepForum
You're right... I thought the YJ doors were angled in the back corner... Google proves me wrong.
Sent from my TJ
- Samuel Adams
modifications , tj
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
Diverdown87 , TJR238
