What did you do to your TJ today? - Page 6033 - JeepForum.com
 1480Likes
post #90481 of 114431 Old 11-11-2013, 03:10 PM
The_Dealer
2003 KJ Liberty
Originally Posted by rikkards View Post
Good news is I swapped the speedo gear as I went from 33's to my winter 31's. The bad news is I saw whiteness in the fluid. I assume this means I got water in it at some point. Any suggestions on how to flush the transfer case? Mostly how many times or is once enough?
Cheap fluid. Use the cheapest you can(super tech from WalMart). Drain and fill as normal. Then drain again, leave the plug out and add another quart or two to flush. Put the plug back in, and refill. Drive about 25 miles, and drain again. Leave the plug out, and run some more thru to flush. Put the plug back in, and refill. Drive 100-200 miles, then do another drain and refill. At least that's how I'd do it. I did a manual trans the same way, and everything worked out. I might have went a little overboard with continuous flushing, but better safe then sorry
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #90482 of 114431 Old 11-11-2013, 03:30 PM
rikkards
rikkards's Avatar
I made the mistake with my transmission of only flushing once. That cost me. Unfortunately the only ATF+4 I can get locally is the Castrol one which is $8.95 a liter. However I can get ATF fluid cheap, for the flush where the plug is out can I use that and then fill with ATF+4?
Machete don't tweet
- Machete
rikkards is offline
post #90483 of 114431 Old 11-11-2013, 06:03 PM
irnmadn88
The best thing about having bought a mostly built Jeep?
When your lap top and smart phone decide to meet the great bit maker in the same week and you aren't going "Dammit, there went my lift fund again!"
irnmadn88 is offline
post #90484 of 114431 Old 11-11-2013, 06:16 PM
The_Dealer
2003 KJ Liberty
Im not familiar enough with atf+3/4 to say. But I think the problem is with mixing the two. My trans takes atf+4, and I've heard to never ever ever mix with regular atf. I think it will spontaneously combust or sonething
My build
post #90485 of 114431 Old 11-11-2013, 06:37 PM
rikkards
rikkards's Avatar
The intent was to not keep it in just to flush the water out but if thwre is an issue with the two mixing then probably better to play it safe
Machete don't tweet
- Machete
rikkards is offline
post #90486 of 114431 Old 11-11-2013, 06:54 PM
wrangler97
Overbuild
wrangler97's Avatar
Finally pulled the trigger on some 35" KM2's, no electricity this month
1997 Wrangler 6cyl 5-spd; 4" short arm, 35X12.50's, all the supporting goodies...
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats"
wrangler97 is offline
post #90487 of 114431 Old 11-11-2013, 07:14 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Take the fill plug out first.
ATF+4 is backward compatible with ATF+3...
Knuckelhead is offline
post #90488 of 114431 Old 11-11-2013, 08:05 PM
rikkards
rikkards's Avatar
Was aware of pulling the fill plug first as it would be very sucky if you could drain it but not fill it.
So I should have no issue introducing ATF+3 temporarily?
Machete don't tweet
- Machete
rikkards is offline
post #90489 of 114431 Old 11-11-2013, 08:09 PM
0IIIIIII0
Placed an order with Mr.Blaine for a new set of T-case skid nutserts to repair the ones that were all jacked up... Yay for another day on my back
Sent from my TJ
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #90490 of 114431 Old 11-11-2013, 08:15 PM
Knuckelhead
AFSOC Retired
If you're ever in that situation, you can fill the transfer case through the speedometer sending unit hole.
Not at all, if you can find some. It's been gone from the store shelves for quite a few years...
post #90491 of 114431 Old 11-11-2013, 08:19 PM
rikkards
rikkards's Avatar
Smart idea for the speedo hole never would have thought of that
What about normal ATF or Dextron III?
Machete don't tweet
- Machete
rikkards is offline
post #90492 of 114431 Old 11-11-2013, 08:30 PM
The_Dealer
2003 KJ Liberty
care to elaborate? This +3 +4 crap confuses me. The trans/tcase normally calls for +3, but they don't make it anymore correct? Or at least I never seem to see it
My build
post #90493 of 114431 Old 11-11-2013, 08:46 PM
Knuckelhead
AFSOC Retired
The transfer case wont care, an automatic transmission might care.
Google it, lots of information on the web about how the two are compatible...
post #90494 of 114431 Old 11-11-2013, 08:52 PM
lockedwheels
Towed it 2400 miles to our new home.. Sin City..
lockedwheels is offline
post #90495 of 114431 Old 11-11-2013, 09:30 PM
BrianDavid
Originally Posted by vanillathrilla View Post
Do you have a sub in your center console (or elsewhere?)
If not, It seems like your component speakers handled low frequencies better than mine do in the TJ.
No i do not have a ny subs (YET). it may be because of my head unit helping with the lows but im not sure
BrianDavid is offline
modifications , tj
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
carbert
