What did you do to your TJ today? - Page 6032 - JeepForum.com
 1402Likes
post #90466 of 114291 Old 11-10-2013, 04:57 PM
thedaringmove
Originally Posted by HyTronix
Still not sure if I want to stroke the 4.0 out to a 4.6ish or not... But in any event, I'll be in tear-down mode tomorrow. -John
I vote do it!
thedaringmove is offline
post #90467 of 114291 Old 11-10-2013, 05:11 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Went wheeling today with a local club, alot of Jeeps few Toyotas and Nissans. Not much to report other than mine did very well, I spent the least amount of time on most obstacles. Talked to one of the guys and he said that putting the little black door trims on the light bar can stop the whistling, I'll have to give that a try. Can't wait for Hidden Falls next weekend.
May TJ of the Month 2015
TexasTJ is offline
post #90468 of 114291 Old 11-10-2013, 05:22 PM
boy1212
Last night put in a hp 30 with 456 gears and a arb today I got to finally get my dana 35 out and put in my dana 44 with a arb and teraflex disk brake conversion now I have to figure out what brake pads work with the calipers and what emergency brake kit I need anyone have a clue
boy1212 is offline
post #90469 of 114291 Old 11-10-2013, 06:39 PM
gregstudeny
2006 WK
Installed a blue monkey speedo healer.
gregstudeny is offline
post #90470 of 114291 Old 11-10-2013, 07:56 PM
tinktinkTJ
Tinted my front windows (35%). It wasn't as difficult as I expected but it sure as **** wasn't easy.
tinktinkTJ is offline
post #90471 of 114291 Old 11-10-2013, 09:11 PM
FL 4.0L
Removed the OEM steps. One bolt came out a couple revs then wanted to stay in its nutsert. Cut the head off. Wiggling the remaining shank side to side and up and down got the inside half of the nutsert to fall into the frame. Fished it out with a magnet. I know they aren't worth anything to most, but the old steps are available for free. Pass step is metal with a plastic skin and unusable, except for the arms which attach to the frame. The driver's side step is molded plastic and must have been changed by the PO and is in good condition. Dropkick Slyders to be ordered tomorrow!
'97 TJ Sport, 4.0L, AX-15, D30/35, BFG TA KO 183K
'12 F30, '03 E46, '06 Rabbit, '13 Jetta
FL 4.0L is offline
post #90472 of 114291 Old 11-10-2013, 11:40 PM
powerstroke01
powerstroke01's Avatar
2005 WK
Boy, you're really helpful
Best grease I would suggest is Mobil 1 synthetic grease. Look on the back of the grease tubes. You should see a symbol on the back like the pic below. Give's you a good idea of what to run with.
Thank you!
Jeepers do it in the mud. ;)
powerstroke01 is offline
post #90473 of 114291 Old 11-11-2013, 06:31 AM
bhikku
CEL went off by itself, celebration time!
2004 Rocky Mountain Edition Wrangler
Utah Jeep Crew #152
US Navy 04-08
bhikku is offline
post #90474 of 114291 Old 11-11-2013, 07:40 AM
bbradUSMC
That's always scary to me. If there's anything I have learned from working on Jeeps it's that problems never go away.
bbradUSMC is offline
post #90475 of 114291 Old 11-11-2013, 07:45 AM
bhikku
Yeah, tis the nature of jeeps. But i think it was due to bad fuel sitting while i went on a vacation. It went away halfway through a new tank of gas, so im hoping that was what did it.
Utah Jeep Crew #152
US Navy 04-08
bhikku is offline
post #90476 of 114291 Old 11-11-2013, 07:48 AM
bbradUSMC
I always use fuel stabilizer if it has to sit for a while. Mine sat for a year while I was in Hawaii and only got driven 3 or 4 times. I filled her up, added fuel stabilizer and changed the oil. Not a single problem except she needed a new battery.
post #90477 of 114291 Old 11-11-2013, 07:57 AM
bhikku
Yeah it was only like ten or eleven days, but i may get a fuel system cleaner or additive tonight just in case.
Utah Jeep Crew #152
US Navy 04-08
bhikku is offline
post #90478 of 114291 Old 11-11-2013, 11:13 AM
The_Dealer
2003 KJ Liberty
Originally Posted by HyTronix View Post
What I did today:
-John
You can get an ATK crate 4.7 from Summit for $2900
Edit: the went up $99 since I got mine
http://m.summitracing.com/search/bra...ines/make/jeep
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #90479 of 114291 Old 11-11-2013, 11:21 AM
rikkards
rikkards's Avatar
Good news is I swapped the speedo gear as I went from 33's to my winter 31's. The bad news is I saw whiteness in the fluid. I assume this means I got water in it at some point. Any suggestions on how to flush the transfer case? Mostly how many times or is once enough?
Machete don't tweet
- Machete
rikkards is online now
post #90480 of 114291 Old 11-11-2013, 11:37 AM
festerw
festerw's Avatar
Found this stuck in my tire this morning, guess that's why it's been losing air.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
modifications , tj
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Shiffty1
