What did you do to your TJ today? - Page 6030 - JeepForum.com
 1501Likes
post #90436 of 114454 Old 11-09-2013, 01:04 PM
powerstroke01
powerstroke01's Avatar
2005 WK
installed a new battery and tried to figure out where the popping noises from the rear are coming from. Ive a got a few ideas. Also filled the windshield washer fluid res. It was DRY....
Jeepers do it in the mud. ;)
powerstroke01 is offline
post #90437 of 114454 Old 11-09-2013, 01:23 PM
wwch99tj
Originally Posted by powerstroke01 View Post
... tried to figure out where the popping noises from the rear are coming from. Ive a got a few ideas. Also filled the windshield washer fluid res. It was DRY....
That's what I did the other night and it turned into me not figuring it out... but I did get the rear brakes adjusted.
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #90438 of 114454 Old 11-09-2013, 01:28 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Went to a Jeep event with local club for toys 4 tots. It was at 4WP store, so of course I couldn't leave without buying something. Got me a snatch block for my gear bag, and also a replacement center cap for one of my PCxx69s.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #90439 of 114454 Old 11-09-2013, 01:36 PM
FarmerinVA
Originally Posted by The_Dealer View Post
Have you uses a lubelocker before? Im curious to see if they really install easily with no leaks. Im thinking about getting a lubelocker pan gasket for my 32rh. I need to do a driveway flush and filter, and I have the worst luck when it comes to getting a pan gasket to not leak after I mess with it. All of the leaks I had weren't really from install error, but it's happened enough to make me paranoid. Also thought about getting the guys to use them when I regear. It will be less hassle when I do my break in drain and fill
I have them on my 30 and 35. They work perfectly, no leaks. I took seriously the directions, which say that surface prep is key, so I had the mating surfaces on the diffs and covers almost shiny clean before I installed them. I don't know if that was really necessary.
My do-it-yourself install thread for a TrueTrac in the rear, upgraded shafts, and a PowerTrax No-Slip in the front:
FarmerinVA is offline
post #90440 of 114454 Old 11-09-2013, 02:10 PM
686keydragon
Cleaned my soft top windows with Plastx cleaner. It got rid of a lot of hazing and some of the smaller scratches. Before: Name:  image-1683117903.jpg
Size:  248.9 KB After: Name:  image-3017798234.jpg
686keydragon is offline
post #90441 of 114454 Old 11-09-2013, 02:48 PM
Batty505a
Originally Posted by Batty505a
Yeah. If you mean door surrounds or lock sets.
It was just the lock cylinders. The clips are still on the old doors with old locks
2006 Chevy Silverado (DD)
1998 Jeep TJ Wrangler Sport (DD)
1993 Jeep YJ Wrangler *Parts Vehicle*
Batty505a is offline
post #90442 of 114454 Old 11-09-2013, 04:50 PM
DezertTJ
Took it out for one of its last trips. All the Windows come off and it was a beautiful day!
DezertTJ is offline
post #90443 of 114454 Old 11-09-2013, 04:57 PM
sjones26573
Changed out my busted Duralast wipers for the nice new Trico's. Really wanted to get more than that done today. Damn early sunset.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #90444 of 114454 Old 11-09-2013, 04:57 PM
armymedicsfc
Replaced exhaust manifold. Not too bad of a job. Now she purrs like a kitten. Straightened out steering wheel. Next up, Savvy 4" lift and SYE install.
-Can Do Easy
-98 TJ, Lifted and Locked.
armymedicsfc is offline
post #90445 of 114454 Old 11-09-2013, 05:21 PM
andrewk
2007 KJ Liberty
Ordered 2 General Grabber AT2's from Tire Rack
andrewk is offline
post #90446 of 114454 Old 11-09-2013, 07:40 PM
06philaTJ
Washed/waxed it for winter and checked on the LED backup bulbs in the stock TJ taillights I installed over the summer. All it took was two 1157 socket extensions from ebay to reposition the bulbs to the front center, two 5 watt cree projector leds, and some cable anchors to hold them in place. So far they have been working great with no issues and are plenty bright to illuminate probably guessing 15-20ft or more behind the TJ. The stock TJ brake/tail light bulbs are just standard as they work fine for me, just wanted to make the stock backup lights more useful for parking and being in the woods at night without having to mount/wire external lights.
You can see the projector bulb in the center of backup light reflector:
Daytime pic, just the backup lights:
My phone camera sucks for night time pics as this is the best I could get with just the backup lights on:
06philaTJ is offline
post #90447 of 114454 Old 11-09-2013, 08:08 PM
jjvw
jjvw's Avatar
Changed the engine oil and also the F/R diff oil.
I'm fairly certain the diffs have never been opened until now. Everything looked clean and the old oil was still honey colored with the rear being slightly darker. The good news is that my rear locker's slowness to engage seems to have been fixed with the fresh oil. I used Royal Purple 75w-140.
2003 Rubicon
jjvw is online now
post #90448 of 114454 Old 11-09-2013, 09:35 PM
gregstudeny
2006 WK
Installed new BM brake pads and centric rotors.
gregstudeny is offline
post #90449 of 114454 Old 11-09-2013, 10:33 PM
Scarfist
Finished replacing the master cylinder, proportioning valve and front left hard brake line. Bled the whole system with new fluid.
On my last wheeling trip a rock kicked up and hit the bracket where the hard and soft line connect. Cracked the hardline and broke off the end of the soft line.
Time for a beer or 4.
I'm too old to play with Lego's, so I got a Jeep. 97 TJ club member
Scarfist is offline
post #90450 of 114454 Old 11-10-2013, 03:23 AM
NH-JK
I fired my steering wheel, then hired a replacement! Can't post pics as usual... Photos a tad go big... As always. I like wrangler forums Mobil app better.
NH-JK is offline
modifications , tj
davewjcook
