What did you do to your TJ today? - Page 6003 - JeepForum.com
 1019Likes
post #90031 of 113784 Old 10-29-2013, 01:34 PM
jlp437
Originally Posted by festerw View Post
Put the snow tires on and in the process found I need brakes all around, right side u-joint and left side tie rod end. Also found the front pinion seal and rear main seal are both slightly leaking.
Sometimes I hate working on my own vehicles.
If the Pinion seal wasn't leaking you might be out of fluid!
thats my reason anyways.....
jlp437 is offline
post #90032 of 113784 Old 10-29-2013, 02:18 PM
festerw
festerw's Avatar
That's a good point, I figured the blow off would just be rust proofing.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
post #90033 of 113784 Old 10-29-2013, 02:21 PM
SlackJaw
baby jeep
SlackJaw's Avatar
lol, I rust-proofed the hell out of mine when the parts store gave me the wrong seal for my 44
SlackJaw is offline
post #90034 of 113784 Old 10-29-2013, 03:25 PM
booya1967
Install the kargo master rack that I bought off EBay.
1990 YJ Red with Black Hard top, work in progress.......
2006 TJ Silver with Black soft top
booya1967 is offline
post #90035 of 113784 Old 10-29-2013, 03:27 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Hit 148,000 miles today, crazy to think I've been riding in this Jeep since it had less than 100 miles.
May TJ of the Month 2015
TexasTJ is offline
post #90036 of 113784 Old 10-29-2013, 04:10 PM
Renegade88
Parked mine for who knows how long. Got a job out in texas don't know when I'll be home. But I did put a nice cover on it.
2006 LJ
PanhandlePierFishing.com
Renegade88 is online now
post #90037 of 113784 Old 10-29-2013, 04:24 PM
Oman Jeep
Oman Jeep's Avatar
Today's - Got the rear axle in place and the arms fitted. Got the springs and shocks in. Front lower control arms are in but still pending is the front upper control arms - need to do the truss / axle housing modifications for the upper mounts.
Oman Jeep is offline
post #90038 of 113784 Old 10-29-2013, 04:47 PM
thedaringmove
Did a little daylight flex test today.
RTI score of 786 (20 degree)
thedaringmove is offline
post #90039 of 113784 Old 10-29-2013, 05:28 PM
LA-Sahara
Got the last bit of bling in today.
LA-Sahara is offline
post #90040 of 113784 Old 10-29-2013, 05:37 PM
Tonellin
awesome...thank you for continually updating in this thread its amazing to see the work being done to your rig
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #90041 of 113784 Old 10-29-2013, 06:36 PM
bbradUSMC
Bought new FUCA bushings for the axle side, Rented CA bushing removal tool. Tool too small. Took back to Advanced. Got ball joint removal tool. Would not fit with spring still in. Spent 3 hours fighting this.
Wanted to:
1. replace CA bushings
2. replace T-case fluid
3. continue windstar intake system
What did I get done NOTHING! I feel like throwing everything across the garage. Sometimes you just have to call it quits for the night, pop a cap and order a pizza. Till tomorrow night you POS.
bbradUSMC is offline
post #90042 of 113784 Old 10-29-2013, 07:08 PM
Mr_Speakeasy
Wanted to:
Its a love/hate relationship.
Mr_Speakeasy is offline
post #90043 of 113784 Old 10-29-2013, 07:13 PM
ThatWhiteJeep
Replaced both hub assemblies, 2 tie rod ends. 3 dust boots, and had it aligned. Still have death wobble, on top of that, the CD player went out and it squeaks at low speeds. I can't even stand to look at it right now.
Like my GrandPappy said, only way to learn is to do it yourself. Even if you break some things along the way.
ThatWhiteJeep is offline
post #90044 of 113784 Old 10-29-2013, 07:21 PM
The_Dealer
2003 KJ Liberty
Ordered my mml, and started on the shift shaft seal. Getting the old seal put was simple. Took some 3/4" conduit, clamped it down to put pressure on the seal, and threaded it in with my channel locks. Done. Now getting the new one in seemed to give me a hard time. I didn't have the right size pipe, washers, or socket. Then when I finally got a handful of things to use to drive it in, I realized there isn't any room to hit it. My c-clamp wouldn't press it in straight. I finally got it(I hope). Now I just got to put the damn thing back together
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #90045 of 113784 Old 10-29-2013, 07:33 PM
jjvw
jjvw's Avatar
Its too cold in the morning to keep the rear window rolled up, so the hardtop went on for the season. The mucket seals stayed on!
2003 Rubicon
jjvw is online now
modifications , tj
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
festerw , SoKnoJeep
