What did you do to your TJ today? - Page 5992 - JeepForum.com
 530Likes
post #89866 of 112565 Old 10-25-2013, 09:35 AM
JahnPaters
Originally Posted by TheDoc25 View Post
Dumped the engine oil and changed the filter.
I hope you put oil back in after
JahnPaters is offline
post #89867 of 112565 Old 10-25-2013, 10:07 AM
686keydragon
Originally Posted by Eckoh
i went to a direct drive flex fan when mine did that. when my AC worked it was blowin snow.
I am probably going to go that route in the near future. When I changed the fan clutch I noticed that the radiator is weeping so I will be replacing that and the fan setup at the same time.
686keydragon is offline
post #89868 of 112565 Old 10-25-2013, 10:30 AM
HobieSun
Replaced my Steering Gear
Got the death wobble for the first time about 3 months ago and the steering gear started leaking shortly after badly. Just sitting it would empty the fluid. So I replaced it and have been driving it every day since. Pretty easy removal and install. Don't hesitate to do it yourself. Now I need tires, shocks, a new stabilizer and an alignment!
HobieSun is offline
post #89869 of 112565 Old 10-25-2013, 11:07 AM
bbradUSMC
Got the CB wired in. Now just need to mount a firestick.
bbradUSMC is offline
post #89870 of 112565 Old 10-25-2013, 12:06 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Uniden Pro520XL?
May TJ of the Month 2015
TexasTJ is offline
post #89871 of 112565 Old 10-25-2013, 12:25 PM
brian93tj
2009 JK Wrangler
Put a Kenwood KDC452, Polk DB521's in the front with Nalin adapters and DB6501's in the bar. Debating on where to put the tweeters. Thinking about in the bar half way between the speakers and light. Any placement suggestions?
brian93tj is offline
post #89872 of 112565 Old 10-25-2013, 01:03 PM
SlackJaw
baby jeep
SlackJaw's Avatar
recovered a F150 buried up to the frame in wet sand and river. My cheap *** Chinese POS ****tybilt xrc8, with its dangerous steel cable, didn't break, again.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #89873 of 112565 Old 10-25-2013, 01:11 PM
The_Dealer
2003 KJ Liberty
Reset the pcm per fsm instructions. Didn't do it yesterday after cleaning the iac, t-body, map. Runs so much smoother now
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #89874 of 112565 Old 10-25-2013, 01:41 PM
bbradUSMC
Originally Posted by Cavasar View Post
Uniden Pro520XL?
Yes sir.
Have to get it ready for the Bandera trip opening weekend. Need the reducing elbow to get here so I can finish my windstar intake setup.
post #89875 of 112565 Old 10-25-2013, 01:55 PM
The_Dealer
2003 KJ Liberty
Received my shift shaft seal from rock auto. It tripped me out that this little seal came in such a big box. Seal=$1.07, shipping=$1.46
My build
post #89876 of 112565 Old 10-25-2013, 04:10 PM
GregStephens2
Installed a brand new TW's rear driveshaft.
Monday the toasted on is going back for a rebuild.
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline
post #89877 of 112565 Old 10-25-2013, 04:14 PM
Tonellin
Yes sir.
You might want to flip the CB, those have the speaker on the other side..a lot of the sound might get blocked/muffled by the console
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #89878 of 112565 Old 10-25-2013, 04:41 PM
jeepwrangler97
Used some straps to hold the rear window up; it was getting annoying nut being able to roll up the window on the rampage top
Sent by a messenger bird
jeepwrangler97 is offline
post #89879 of 112565 Old 10-25-2013, 05:19 PM
The_Dealer
2003 KJ Liberty
You might want to cut a bed sheet to rollup with it. It will help keep from scratches and hazing up. Mine got bad quick
My build
post #89880 of 112565 Old 10-25-2013, 05:56 PM
Yellow02
Put on my UCF diff cover and changed diff fluid.
USN Jeep Club Hull #144
#83 Rubicon Sahara Edition
Yellow02 is offline
modifications , tj
oscartj
