What did you do to your TJ today? - Page 5987 - JeepForum.com
 671Likes
post #89791 of 113110 Old 10-22-2013, 09:01 PM
exhooah
Back home from a 2800 mile family vacation to Colorado. Pulled my TJ trailer; it hauled clothes for 7 and a front fender i picked up while out there.
exhooah is offline
post #89792 of 113110 Old 10-22-2013, 09:05 PM
ivester1992
Originally Posted by thedaringmove View Post
Sucked it up and spent 40$ on a 40 piece ratchet/socket set for his tool box. Made by Stanley... Anyone have experience with them? Wish i had the cash for some snap-on goods
ive had my kit for 6 years, it was given to me when i was in highschool. only thing i can say is after using a 2ft cheater bar i made the 3/8 ratchet a little loose
4.88s, 35 bfg a/t, 4.5 inch rubicon express springs, rear 4 link, single radius front, 6 inch rc 2.0 shocks, rc quick discos, eautogrilles rockers and corners.
ivester1992 is offline
post #89793 of 113110 Old 10-22-2013, 10:34 PM
thedaringmove
Thanks for the tip. Ill keep too much strain off of it!
That was weird wording... Too lazy to rewrite that crap
thedaringmove is offline
post #89794 of 113110 Old 10-23-2013, 04:01 AM
TheDoc25
Stanley are a good brand, like above don't expect miracles and you won't break them, we use them at site on 2 projects and they are holding up. Not much choice out here..
TheDoc25 is offline
post #89795 of 113110 Old 10-23-2013, 08:26 AM
FireMark93
Someone say halloween spirt?! How bout the jeepkin?!
FireMark93 is offline
post #89796 of 113110 Old 10-23-2013, 08:29 AM
SSpig
Installed 2" coil spacers and new shocks yesterday. Lessons learned:
1-not having a floor jack and using factory jack from Jeep - SUCKED!
2-Coil Spring compressors are a PITA! (Having never used them before)
3-Man I could use some air tools
4-Buy a large tub of icy hot for next day's recovery.
on a good note- sitting in discount tire getting new 31's put on!
SSpig is offline
post #89797 of 113110 Old 10-23-2013, 09:56 AM
JahnPaters
spares are overrated.
JahnPaters is offline
post #89798 of 113110 Old 10-23-2013, 01:39 PM
Rubes
Skidded 50 feet when my wheel came off unexpectedly. Yup...that's my jeep with one wheel off. On my way to work this morning, the left rear started wobbling, so as I turned on the shoulder at 45mph, the rear end fell to the ground and I started skidding. As I came to a complete stop, I saw my tire rolling past me. It was funny, but butt-perking at the same time. I rotated my tires on Sunday and I KNOW (I KNOW) I tightened all the lug nuts. Each wheel also has a locking nut as well. How could I lose all 5 lug nuts? I could see 1 falling off if it wasn't tight enough...but 5? I don't know. It was sabotage, I say!
You're in Good Hands with Mayhem
Rubes is offline
post #89799 of 113110 Old 10-23-2013, 01:45 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Doh!
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #89800 of 113110 Old 10-23-2013, 02:41 PM
ivester1992
ordered 4 johnny joints with jam nuts, some ruff stuff square tube inserts, and 4 ruff stuff poly bushings with sleeves
post #89801 of 113110 Old 10-23-2013, 02:48 PM
sjones26573
I just want to point this out:
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #89802 of 113110 Old 10-23-2013, 02:55 PM
rikkards
rikkards's Avatar
So originally I was thinking of getting the Super 30kit for the HP Dana 30 I got this weekend but:
1. hard to source
- only places I found less than 2K for it is 4x4groupbuy (who just emailed me and said they don't carry but would substitute Arb and G2 shafts for ~1300) and Quadratec. The price is attractive for the G2 axles but I have heard mixed opinions on them.
2. 27 spline vs 30
- Still on the fence on this one. Sure with a 27 spline I could swap in a stock shaft if it broke but with 30 I may not have to at all as it might not break and if it does you just pull the shaft, remove the inner shaft and run home with the outer still attached.
- but also with the 30 spline it moves the fuse from the u-joint/axleshaft ears into the ring and pinion and I would rather change 10 shafts than 1 R&P.
So I started looking into others and Ten Factory is starting to appeal to me.
Further decisions. Sigh
When I got home and decided to get into it. Got the following done:
Progress:
- removed the bolts that had the shocks mounted to them (I cut off the shocks at the junkyard to save time)
- removed the coil retainer bolts
- loosened up the hub unit bolts. At 220ftlbs my impact hammer couldn't take them off so I had to use a 22" breaker bar.
- removed axle shaft nuts on both sides
- sheared the passenger side steering stop (BOO!). Noticed the driver side is already removed. Will have to look at that and replace.
So not bad for the first 40 minutes
Machete don't tweet
- Machete
rikkards is online now
post #89803 of 113110 Old 10-23-2013, 03:14 PM
wwch99tj
Could have been worse, glad no one was hurt
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #89804 of 113110 Old 10-23-2013, 04:07 PM
SlackJaw
baby jeep
SlackJaw's Avatar
horsepower gains were applied.
SlackJaw is offline
post #89805 of 113110 Old 10-23-2013, 04:12 PM
Navydoc1
Originally Posted by Eckoh
mine win :P
i had to replace 4 of them after one weekend
good thing for me a friend upgraded to a long arm kit the week before freebies rule
Yeah you win the prize!! Lol
Navydoc1 is offline
modifications , tj
