What did you do to your TJ today? - Page 5983 - JeepForum.com
 575Likes
post #89731 of 112837 Old 10-20-2013, 11:39 AM
Griff1918
Originally Posted by vanillathrilla View Post
I tried to Plasti-Dip my door hinges from where they're all beat up and corroded.. I was relatively unsuccessful. It looked too sloppy, so I peeled most of it off. I'd like to replace them altogether with black hinges, but I don't have any air tools and I'm afraid I'll strip the hardware. Seems to be pretty common!
Just get a 3/8 dewalt impact, or a bit driver. The biggest tip I have is tighten before loosening them.
Griff1918 is offline
post #89732 of 112837 Old 10-20-2013, 01:48 PM
boy1212
put some new taillights in
boy1212 is offline
post #89733 of 112837 Old 10-20-2013, 02:36 PM
rikkards
rikkards's Avatar
With the help of a buddy, I got my 8.8 and HP Dana 30 from a 99 Explorer and a 91 Cherokee.
The 8.8 is sitting at his place since I have a lame excuse for a garage and no room.
Here is the 30.
In the next month I will be buying the following:
4.56 gears and Master install kit
Super 30
Arb
Currie JJ to replace the axle side.
Before that I really need to degrease it and get the track bar off. Stupid bolt sheared off
Machete don't tweet
- Machete
rikkards is offline
post #89734 of 112837 Old 10-20-2013, 02:44 PM
LA-Sahara
Same thing happened to me!
You had a much better idea to take the trackbar; we just ripped the mount from the axle.
LA-Sahara is offline
post #89735 of 112837 Old 10-20-2013, 04:23 PM
Ssvincels1
Bosch FP / TPS swap / G2 cover install
Decided to replace the fuel pump today due to 97k on the odometer and I just acquired the jeep. Jeep would take a couple cranks before starting if sitting for a couple days. Went with Bosch after some research on the forum. I did make a rookie mistake going cheap with the pump/stainer only which opened up a hole other can of worms. 3 hour job quickly turned into an 8 hour job trying to get the BS aftermarket strainer to sit inside the bottom of the fuel pump assy housing. Long story short, went a bought the Oem strainer and reinstalled all with no issues. Also threw on a G2 rear end cover while I ahead the tank down. TPS was replaced due to throwing a low/ high voltage code the previous day.
I love how easy it is to work on this jeep, nothing like my ridiculously packed engine bay on my F-250!
Ssvincels1 is offline
post #89736 of 112837 Old 10-20-2013, 05:17 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Baby Jeep is relatively happy today. Seals done, ebrake adjusted, cleaned the garage and packed tools in a new to me bag I picked up at a garage sale.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #89737 of 112837 Old 10-20-2013, 05:18 PM
OurTJ
We installed a new starter on our 97 TJ. Too easy, it is a great short project if you ever need to do it. We went ahead and changed the plugs, ignition wires, distributor cap, and rotor just for the heck of it though they almost certainly were way overdue. I wanted to show my kids how all that stuff works.
OurTJ is offline
post #89738 of 112837 Old 10-20-2013, 05:36 PM
Davetha
Davetha's Avatar
Finished the set of beadlocks
Davetha is offline
post #89739 of 112837 Old 10-20-2013, 05:56 PM
LA-Sahara
Just ordered a whole lotta Savvy!
post #89740 of 112837 Old 10-20-2013, 06:00 PM
Tonellin
Funny lookin wheel weight...is that the 10 oz model?
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #89741 of 112837 Old 10-20-2013, 06:10 PM
Richisinyoface
Richisinyoface's Avatar
Excellent way to go! Congrats!
Just Empty Every Pocket.......yup they are empty all right.................
NRA Life member
Sienna Jeep club member #65
Richisinyoface is offline
post #89742 of 112837 Old 10-20-2013, 06:42 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Used it to do some body work. My boy ran the missus' car off the road, tore the splash guard loose, and bent the radiator support. Took it all apart and straightened the support but when it went back on the pass side was about 2" too far back. So, I parked it in front of the heep, stretched out the winch line, and pulled it forward. Everything lined up perfectly afterwards.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #89743 of 112837 Old 10-20-2013, 06:48 PM
TurboGoKart
Omg. What are those??? Those look NASTY!!
Today I aligned the Jeep, minus fixing the steering wheel, because I couldn't break the nuts loose on the drag bar. Put my extended brake lines on and bled the brakes. As well as fixed the driveshaft rub on the stock trans skid. Good day!
Fully Cloak'd!! :)
35" KM2's
Bumpers, winch
TurboGoKart is offline
post #89744 of 112837 Old 10-20-2013, 06:48 PM
sjones26573
The name threw me for a minute. I guess FernBch doesn't make much sense anymore
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #89745 of 112837 Old 10-20-2013, 06:48 PM
stockerokie
Replaced one of the front upper control arms. Hopefully the other one gets done Friday.
stockerokie is offline
modifications , tj
bkicinski , moemuledeer
