What did you do to your TJ today? - Page 5901 - JeepForum.com
 393Likes
post #88501 of 111991 Old 09-11-2013, 09:40 AM
Ljcrawler05
Originally Posted by tyvanwie View Post
I love those wheels.
Yeah but everyone wants an arm, leg, and left nut for em...
Ljcrawler05 is offline
post #88502 of 111991 Old 09-11-2013, 10:21 AM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Originally Posted by LilyBayXJ View Post
Fabbed up a CB antenna mount. I love the look of the location, we'll wait to and see how strong it is. It seems pretty rugged. I may add a spring for running in thick brush.
I would avoid running the cable thru the door like that. Over time the door will cut the line or break the wire in the middle causing issues and possibly frying the CB
Originally Posted by Griff1918 View Post
I have the same bumper. Now when you guys hook to s trailer where are you hooking the safety chains?
I hooked them to the D rings on the side. I carried chain extensions as needed.
Sent from my phone where grammar isn't easy.
RnEmOvr is offline
post #88503 of 111991 Old 09-11-2013, 11:40 AM
TexasTJ
No Longer DD
TexasTJ's Avatar
My PSC light mount came in but the screws for the end of my light bar are just a hair to big to fit in the holes already in the mount, I guess I'll have to drill the hole out a little bit. Also got a new 3"x30' CESS recovery strap.
May TJ of the Month 2015
TexasTJ is offline
post #88504 of 111991 Old 09-11-2013, 12:25 PM
thedaringmove
Is this a bent tie rod?
thedaringmove is offline
post #88505 of 111991 Old 09-11-2013, 12:31 PM
thedaringmove
Never mind I checked my other tj. Same thing. Can figure out why the wheel looks tilted. Maybe a broken axle??? Guess ill take it for an alignment see what they say
post #88506 of 111991 Old 09-11-2013, 12:35 PM
Mud Machine
Jeep Addict
Mud Machine's Avatar
Originally Posted by BigRigoTJ View Post
Grill wrap completed.
Very cool!!
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, Rock Hard Cage, 5.13's, Revolution Axle Shafts, LS-III, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #88507 of 111991 Old 09-11-2013, 12:45 PM
SlackJaw
baby jeep
SlackJaw's Avatar
wheel looks tilted because fender is bent
You might also want to check...under the grill where it meets the frame there are some rubber bumbers...you might see if the space between the frame and the bottom of the grill is equal from side to side. Mine's not anymore
Anyway, my point being, there a number of things that could be crooked, throwing your eye off to look like something else.
SlackJaw is offline
post #88508 of 111991 Old 09-11-2013, 12:52 PM
thedaringmove
We'll see soon enough. Picking up my CCFABS hoodlines as we speak from the powdercoater. At Least that's one thing I don't have I replace...
Ordered a new windshield frame this morning. It will arrive Friday. Filled all fluids except tranny. When I get the windshield on Saturday ill get it towed for a full service. Then I pray I'll be able to drive it home. Still in search of a new passenger door.
Keeping the hood dented. Ironically I had ordered a die cut "it's a jeep thing" sticker the night before the rollover. So ill put that on the hood next to the damage ha
post #88509 of 111991 Old 09-11-2013, 12:52 PM
blubaru2002
Found some ccfabs tube fenders in front of my house today.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is online now
post #88510 of 111991 Old 09-11-2013, 12:53 PM
thedaringmove
Ill check that when I get home. I hope my having the 1" BL didn't hurt my jeep
post #88511 of 111991 Old 09-11-2013, 01:30 PM
SlackJaw
baby jeep
SlackJaw's Avatar
If you didn't have spacers under the grille, it might have tweaked it a little. Mine's out of whack by a pretty good amount, but you have to inspect very closely to notice it. You probably won't know how badly until you get the windhield on there, adjusted properly and try to put a top back on it.
Are there any puckers/wrinkles in the sheet metal on the tub, on the passenger side behind the front fender?
Check that little roll bar connecter bar between windshield and rollbar...those usually bend....you can get replacements from Daveys for like $20....if you plan to replace full soft top and/or hard top, or full steel doors, I think you'll want to make sure you have that adjusted properly.
SlackJaw is offline
post #88512 of 111991 Old 09-11-2013, 02:02 PM
thedaringmove
The bars looked pretty straight when I took them off. On my way home from the powdercoater. Ill recheck when I get home. I do have the spacers under the bumpstops with the BL. Ill check that too.
I don't know I think the jeep looks a little tilted
post #88513 of 111991 Old 09-11-2013, 03:36 PM
Renegade88
Got my half doors put back together.
2006 LJ
PanhandlePierFishing.com
Renegade88 is offline
post #88514 of 111991 Old 09-11-2013, 03:43 PM
LilyBayXJ
Thanks for the input. I intend to get a low-profile coax and run it through the windshield frame. This is just a short-term solution.
2006 LJ - 4.0L, NSG370, 31's
2001 XJ - 4.0L, AW4, 3.5" lift, 31's
1997 TJ - 2.5L, AX5, 2.5" lift, 32's - Sold
1983 CJ-5 - Stock - Sold
LilyBayXJ is offline
post #88515 of 111991 Old 09-11-2013, 04:16 PM
bhikku
Just finished putting in blue LED's in my gauge cluster, and they all worked! Gonna take some pics of it once night hits to geta feeling of how good they end up looking.
2004 Rocky Mountain Edition Wrangler
Utah Jeep Crew #152
US Navy 04-08
bhikku is offline
modifications , tj
blubaru2002
