What did you do to your TJ today? - Page 5883 - JeepForum.com
 926Likes
post #88231 of 113606 Old 09-03-2013, 03:46 PM
mesa-jeeper
Installed washers on my steering stops so my tires no longer rub on lower control arms. Also installed rubber heater tubing on the a/c condensate nipple poking thru the firewall and routed it down the the fenderwell. No more wet carpet on the passenger side.
Side note: it sucks working on the jeep in the garage during Arizona summer time. 108 degree's.
mesa-jeeper is offline
post #88232 of 113606 Old 09-03-2013, 03:53 PM
Oman Jeep
Oman Jeep's Avatar
Rolled it in to where we start disassembly After all the misc. trim is removed, the back will be cut off and the tub will be moved to this frame we prepared earlier
Oman Jeep is offline
post #88233 of 113606 Old 09-03-2013, 04:52 PM
Cirrusman
I sat in the Chic Fila parking lot trying to figure out why my Jeep wouldn't even crank. I wrote a kind of wtf post, but then googled "jeepforum tj wont start clutch" to find the quickest solution or the fuse number (I don't have an owners manual in my jeep since the time it was broken into and ransacked in the rain)
Bam, one of the first results of jeepforum posts had the fuse number for the "clutch interlock", moved the spare fuse to #20. Back in business before anyone even replied. I should have searched first but I panicked because I was late.
Now I have to figure out what is wrong with the interlock or the POS alarm job the PO had done.
Cirrusman is offline
post #88234 of 113606 Old 09-03-2013, 05:39 PM
dan121
mgd, how is your hood held down? I assume hood pins, but couldn't see them in your pics. Sick flex, by the way.
dan121 is offline
post #88235 of 113606 Old 09-03-2013, 06:49 PM
jjvw
jjvw's Avatar
Just finished rebuilding the front drive shaft for the first time ever. So far no vibrations!
2003 Rubicon
jjvw is online now
post #88236 of 113606 Old 09-03-2013, 07:02 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Poked around underneath looking for noises. Making a short hopefully cheap list for the week...
1" socket and some allthread to get that bad JJ replaced. Rear swaybar booshings. And a set of bearing units...probably ought to bite the bullet and do the ball joints as well....we'll see...I'll probably procrasternate for double the work later
On the longer, more expensive list, my discos are shot, so antirock is in order, MC front track bar to center the axle, and she's WAY past being overdue for rear control arms.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #88237 of 113606 Old 09-03-2013, 07:21 PM
218017765
Had to take the 33's off and replace with 30 inch tires to keep the Po Po off my back. Silly PA vehicle code.
Still trying to figure out what I want to do about flares, but I know I don't need a $100 fine while I make up my mind.
Convinced my wife I was leaving the 33's on the back and 30's up front. I thought it looked like a matchbox car. After she threatened to sell the Jeep, I told her I was joking.
218017765 is offline
post #88238 of 113606 Old 09-03-2013, 07:22 PM
LA-Sahara
SlackJaw, you ever get around to that Windstar box? I will finally be picking up the stick intake tune this weekend hopefully to finish mine up.
More pics as promised. "So much room for activities!"-Stepbrothers
LA-Sahara is offline
post #88239 of 113606 Old 09-03-2013, 07:23 PM
thedaringmove
Have the viper system? Mine did that to me too
thedaringmove is offline
post #88240 of 113606 Old 09-03-2013, 07:33 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Rofl .
Not yet, but I been eyeballing it pretty intently . If I can get the short list done during the weeknights this week, that'll be a shoe-in project for this weekend.
SlackJaw is offline
post #88241 of 113606 Old 09-03-2013, 08:50 PM
redjeepguy1
Ordered some new LED Tail lights. It's time to replace the LiteDots, which don't pass inspection because they don't meet safety standards.
They are a new style, the outer ring lights up in tail light mode, kind of a "glow" effect, rather than having each LED distinctly visible like your typical 4 round LED.
The middle lights up for brake and turn signal mode.
http://www.ledtrailerlights.com/stt/stt_o-stl101r.htm
Bill
member 141,234,541 of the red jeep club
redjeepguy1 is offline
post #88242 of 113606 Old 09-03-2013, 10:45 PM
joeyk803c
Put in a new stereo. A kenwood blue-tooth model. Very nice. Can control my phone's music through the radio. It'll make my life easier.
joeyk803c is offline
post #88243 of 113606 Old 09-03-2013, 11:08 PM
wtfcrunch
Flipped my rear view mirror over. Sooo much more field of view.
-_________________-
Tyler Laros
San Diego, CA
wtfcrunch is offline
post #88244 of 113606 Old 09-03-2013, 11:49 PM
rbkelley89
Alum radiator Is leaking out of lower radiator hose and the drain plunger thing. Whats a good way without draining all the fluid to stop the leak because I jist replaced all the fluid
2001 orange tj 2.5L (113,000) 35" Km2 Black rims D lp 30 Front and d 44 rear with ARB 1"BD MML, 1.25" BL, 4" RC Lift, Flat tc Skid, Adj rear ca's (front soon) TW rear DS, Novak shifter cable, JB ss SYE, RE angled rear trackbar, 8,000Lb Mile marker, Custom front and rear (w/swing) bumpers. Homemade CAI. Lots more to come.
rbkelley89 is offline
post #88245 of 113606 Old 09-03-2013, 11:50 PM
DezertTJ
Put it on Craigslist to trade for a 6cyl TJ. I am very tired of this 4 cyl and its worth a shot to see whats out there
DezertTJ is offline
modifications , tj
Mousejockey
