What did you do to your TJ today? - Page 5750 - JeepForum.com
 394Likes
post #86236 of 112001 Old 07-14-2013, 07:22 AM
bbradUSMC
Originally Posted by Richisinyoface View Post
Ive got to get to doing mine, the parts do absolutely no good sitting in the boxes on the shelf......thanks for the link, I will check it out
It feels like such a big job until you start and realize its not so bad. Today I am going to finish that mount, get the novak shifter cable in, finish painting my bumper and maybe paint my UCF skid so I can install it.
bbradUSMC is offline
post #86237 of 112001 Old 07-14-2013, 07:27 AM
0IIIIIII0
It isn't too bad... Until you snap the bolt off and have to try and drill it out in that little cramped space. Never has a mod lead to more cursing, bleeding knuckles, and thoughts of "oh crap, now I've really gone and screwed it up!". But all in all, after I got it back together, it wasn't too big a deal.
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #86238 of 112001 Old 07-14-2013, 07:30 AM
bbradUSMC
Didn't have single problem with the bolts coming out luckily. This one nut is the problem. I think it is just because the motor has raised an inch. You always have to remember to stay calm when working on a project. You brain functions better and you will find a better solution faster.
post #86239 of 112001 Old 07-14-2013, 08:42 AM
bbradUSMC
Originally Posted by bbradUSMC View Post
Installed my 1.25" BL today with no problems. Really adds to the look of the Jeep. Got all of my Brown Dog MML lift installed except for the Pass side nut on the bottom side of the mount. Dang thing is blocked by the engine. Should I remove the through bolt and push the engine over to install it or does someone have a better idea that has done the before.
Edit: Found this http://www.jeepz.com/forum/drivetrai...-wrangler.html
Just need to take out the bolt on the block. Looks like a job for tomorrow.
Ok got the bolt out and the nut torqued down and the other bolt back in but ran into another problem. The transmission sits too low now so I can't get it into 2nd, 4th, or reverse. Gonna have to take the tranny drop out, hmm think my drive line angles will be ok? I have no DC shaft.
post #86240 of 112001 Old 07-14-2013, 09:35 AM
0IIIIIII0
I my case panic was definitely a factor. Aout halfway through, it stared pouring rain, then switched to snow. IN ATLANTA! I knew I had to get it done despite my fingertips being numb because I had a 4 hr drive the very next morning. A few beers and a few minutes in the house helped me get it completed.
- Samuel Adams
post #86241 of 112001 Old 07-14-2013, 09:56 AM
bbradUSMC
I have invested in a pop up canopy for days like that. It is not perfect but it helps a bunch. A few beers always does the trick for me as well.
post #86242 of 112001 Old 07-14-2013, 10:15 AM
Danegerous
Spent all day with Larry at Vegas 4x4 installing my new Currie/Savvy lift with 3.5" Springs and Bilsteins. In the process I found my cracked exhaust manifold. If you guys are near Vegas, get ahold of Larry. Best prices and amazing service. The did taught me how to install the lift the entire time. Very patient and incredibly knowledgeable.
"He is no fool who gives what he cannot keep to gain what he cannot lose"
Originally Posted by Jeff88 View Post
I once slipped with a rotary wire brush that burned through my jeans and left a very nice deep gouge in my leg.
If it had been up a little higher, I'd have gone from a rooster to a hen.
Danegerous is offline
post #86243 of 112001 Old 07-14-2013, 10:21 AM
GilaMtnJeep
GilaMtnJeep's Avatar
Crawled under and told her I would fix her. Looks like I'm gonna be buyin 2qts of 75W-140, pinion seal, and a pinion nut.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #86244 of 112001 Old 07-14-2013, 10:38 AM
Navydoc1
Took the doors off for the first time since owning it, bushings are shot!
Navydoc1 is offline
post #86245 of 112001 Old 07-14-2013, 10:51 AM
krughzn
krughzn's Avatar
Try these, they work great.
http://blackmagicbrakes.com/Jeep_Co-Op.php
krughzn is offline
post #86246 of 112001 Old 07-14-2013, 12:03 PM
KI2D28
Write ups
Originally Posted by Rican142 View Post
Write up!?
Check here, there are more than just mine.
http://www.jeepforum.com/forum/searc...rchid=18900565
KI2D28 is offline
post #86247 of 112001 Old 07-14-2013, 01:57 PM
bbradUSMC
Bumper painted
Sway bar cover painted and 1.25" BL lift
Radiator support
Skid tucked back up
Another BL pic
1" Brown Dog MML installed 'Merica!!!
New drive line angle. Hows it look?
Also made some quick disconnects out of a trailer harness for my fog lights
post #86248 of 112001 Old 07-14-2013, 02:43 PM
Navydoc1
Thanks that's just what I'm looking for
Navydoc1 is offline
post #86249 of 112001 Old 07-14-2013, 02:46 PM
h1driver
h1driver's Avatar
Got my Novak all dialed in-
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed."
So, Suck-It Trebek!!! MOΛΩN ΛΑΒΕ
My "Build" -
h1driver is offline
post #86250 of 112001 Old 07-14-2013, 02:47 PM
Griff1918
Originally Posted by rikkards View Post
I was going to put in a cutoff switch but realized you can't find any in the upper levels of the amps the winch is capable of. It would suck to be doing a hard winching and have the switch burnout
Get yourself a long state running solenoid and run a remote cut off switch.
Griff1918 is offline
modifications , tj
Currently Active Users Viewing This Thread: 6 (4 members and 2 guests)
AftonJeeper , Sand1235 , Solohammer , WinterJeep
