What did you do to your TJ today? - Page 5661 - JeepForum.com
 1210Likes
post #84901 of 114024 Old 06-10-2013, 09:41 AM
wwch99tj
Wife called and said that the airbag light is on and radio, blower and signals aren't working... looks like I've got to do some searching on the culprit.
Sent from my Galaxy Tab
wwch99tj is offline
post #84902 of 114024 Old 06-10-2013, 10:11 AM
matt93
Originally Posted by jeepinhokie
dont hang your TJ doors by the top of the window. where the window meets the door tends to crack...
you could have just cut the rubber snubbers down by that same amount and not had to fab anything...
Well. I've never heard that. Guess ill be finding a different way to mount them. Thank you.
"don't wash it. it looks better dirty"
Siena Pearl Owners Member 57
matt93 is offline
post #84903 of 114024 Old 06-10-2013, 10:35 AM
Griff1918
Just put 2 rubber coated hooks under the doors to hold most of the weight
Griff1918 is offline
post #84904 of 114024 Old 06-10-2013, 10:38 AM
matt93
That's exactly what I did. I moved the two hooks down so that they support the doors from the bottom. Thanks guys
matt93 is offline
post #84905 of 114024 Old 06-10-2013, 10:44 AM
mrott
My renegade frameless sailcloth top arrived over the weekend. I've gotten it on and off twice now. Definitely a little something different to get used to but it's pretty cool...not many complaints at all. The storage bag built into the top is pretty nice too. It sags just enough when the windows are in the storage bag that it is at the top of my view in the rear view mirror. In other words, not enough for it to bother me. Hopefully over the summer it will stretch out just a bit and be a tad easier to zip up.
Now with the frame from the top gone, I can finally finish building my trunk...now if only the weather was willing to cooperate.
I also sold an older drum set on craigslist over the weekend which will be funding my 4.25 zone lift kit...so I guess I need to venture over there to order it. The new 33" duratrac's will be soon after that...
I'm thinking it's going to be a good month for my jeep and a fun summer!
mrott is offline
post #84906 of 114024 Old 06-10-2013, 10:50 AM
sjones26573
I don't suppose you mean Rampage?
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #84907 of 114024 Old 06-10-2013, 11:46 AM
mrott
heh, you suppose correctly... whoops. All those silly words starting with R.
mrott is offline
post #84908 of 114024 Old 06-10-2013, 04:05 PM
IslandHopper
What did I do ?... I removed the front springs, shocks, track bar, steering stabilizer and control arms.
Then cleaned everything up... still waiting for the bump-stops and shock boots to arrive from a different supplier, then everything goes back together with a 2.5" lift!
(Will do the rear tomorrow... the remainder of the new parts should be here tomorrow afternoon to start re-assembly.)
It was all the result of needing new bushings all around (and tires), so I figured I might as well "improve" things if I'm going to be doing that much dis-assembly anyway.
IslandHopper is offline
post #84909 of 114024 Old 06-10-2013, 05:54 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Good plan. Catch it all while it's apart.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #84910 of 114024 Old 06-10-2013, 07:57 PM
chrisejandaddi
Originally Posted by 984bangerTJ
What did you do to it to fix the problem? My seat is a pain to slide since I installed the lock box.
I had to bend the front tabs. I bent them so it pushed the back of the box down when I tightened the front bolts. Works good now.
2002 Wrangler Sport
2011 Grand Cherokee Laredo
chrisejandaddi is offline
post #84911 of 114024 Old 06-10-2013, 08:51 PM
joeyk803c
Picked up some new wheels for it. Need to get money put away for hawaii next month, then time to start saving for some 33s.
joeyk803c is offline
post #84912 of 114024 Old 06-10-2013, 08:57 PM
AddictedToJeeps
Originally Posted by ih8pepl73 View Post
Where did you get this??????
I got it on ebay. Tons of stickers
White Jeep Club #219
AddictedToJeeps is offline
post #84913 of 114024 Old 06-10-2013, 08:57 PM
DezertTJ
Had a little scare when my oil dropped to 0 and varied up to 5psi. I had put a new sender in about a year ago so I figured it wasn't that. Turns out it was. Replaced it with a high quality oil sensor instead of the cheap crap I originally put in there. Now it has 40psi at idle instead of the 10-20 it was showing for a long time
DezertTJ is offline
post #84914 of 114024 Old 06-10-2013, 11:12 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Lol. I mall crawled the piss out of it tonight.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #84915 of 114024 Old 06-11-2013, 07:39 AM
jfdrum02
i was thinking of that but i like those round rubber thing ........:-)
jfdrum02 is offline
modifications , tj
Currently Active Users Viewing This Thread: 9 (2 members and 7 guests)
pmcjeep , TJR238
