What did you do to your TJ today? - Page 5483 - JeepForum.com
 583Likes
post #82231 of 112866 Old 04-07-2013, 11:29 AM
DUBDUB468
Went to deer lease got it a little muddy
The right amount that gives it character.
Throwed a code at me P0455. Evaporative emission system leak. Anyone know where to start at to resolving this problem.
DUBDUB
DUBDUB468 is offline
post #82232 of 112866 Old 04-07-2013, 11:34 AM
YoTeach
Fuel cap or vacuum leak
YoTeach is offline
post #82233 of 112866 Old 04-07-2013, 11:40 AM
Bordr329
Originally Posted by 0IIIIIII0 View Post
Tell the truth... Did you drop the gas tank to install the last bolt in the hinge side plate? Or did you do what I did and just say "screw it" ?
Sent from my TJ
I got that top bolt by the hinge. What a pain in the ***! There is some little glob of silicone in the seam that had to be removed for me to get the nut started. Very happy with the result. I ditched stock license plate holder and mounted the paste straight on the armor and bent it partly around the corner.
Pics will come once i make a photobucket or something, stand by
Bordr329 is offline
post #82234 of 112866 Old 04-07-2013, 12:20 PM
Bordr329
i had to use my "education" to help get the corner to be at the right angle.
end result
Bordr329 is offline
post #82235 of 112866 Old 04-07-2013, 12:22 PM
0IIIIIII0
I did the same thing with the plate, of course, I had done that a long time ago. One of these days I'll put that last bolt in...
Sent from my TJ
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #82236 of 112866 Old 04-07-2013, 12:46 PM
rikkards
rikkards's Avatar
I got the UCF UCH skid and LoPro mount on and pinion angle dialed in. Nice having double adjustable Control Arms. I do have some slight vibe at idle which I think it is the cat contacting the rounded part of the lopro mount. I am usually picky about vibes so the fact that I can live with this means it isn't a big deal. Some point later on, I will probably pull off the skid and just trim the round part of the mount back.
Machete don't tweet
- Machete
rikkards is offline
post #82237 of 112866 Old 04-07-2013, 02:06 PM
festerw
festerw's Avatar
Installed some LED tails and reverse light. Might do the rear Warn bumper if I don't run out of daylight.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #82238 of 112866 Old 04-07-2013, 02:08 PM
sc00bz
It was a nice morning today, so I drove down to the lake to wet a hook for a little while. When I turned around and saw the jeep at the top of the hill, I had to snap a pic.
Sent from my GSIII using HeepForum
97 TJ with some stuff.
sc00bz is offline
post #82239 of 112866 Old 04-07-2013, 02:40 PM
HighRoller02TJ
installed the Extreme Metal Products radiator skid plate. very easy. mounts under the front body mount and on the frame ( drill one hole and it comes with a self taping bolt )
HighRoller02TJ is offline
post #82240 of 112866 Old 04-07-2013, 02:42 PM
yamaha225
Worked on the rear brake and was able to actually get a parking brake that works and get a better pedal feel
1997 TJ, 2.5 4 cyl, AX-5, Hella 700's
Black Jeep Society, Eagle Scout Jeepers
yamaha225 is offline
post #82241 of 112866 Old 04-07-2013, 03:05 PM
amiller
Took it out of winter storage. Damn happy to have it back.
2005 Jeep TJ with some upgrades
amiller is offline
post #82242 of 112866 Old 04-07-2013, 03:14 PM
CHI JPR
CHI JPR's Avatar
Installed ARB wiring harness for headlights, and also discovered I have a bad multi-function switch. (Ordered new one) Installed the soft top & a newMonroe steering stabilizer.
CHI JPR is offline
post #82243 of 112866 Old 04-07-2013, 03:42 PM
Delfire
I finally found my reflective flush mount LED tail lights to keep me legal for Texas inspection and I installed a third light on my spare tire.
Delfire is offline
post #82244 of 112866 Old 04-07-2013, 04:00 PM
SFT2
3rd brake lights aren't required in Texas, in case you get tired of the thing.
Mine- 2k TJ, RC 2.5 lift, .75 spacers, Soft 8s, 33" KM2s, winch, lights, and so on
Hers- 06 WK, bone stock until she leaves it and the credit card with me for an unsupervised weekend
You're the retarded offspring of five monkeys having butt sex with a fish-squirrel.
SFT2 is offline
post #82245 of 112866 Old 04-07-2013, 04:09 PM
JBTJ
Yep, pulled mine off 12 years ago.
JBTJ is offline
modifications , tj
churchofjt , JbthePhotoGuy
