What did you do to your TJ today? - Page 5482 - JeepForum.com
 1384Likes
post #82216 of 114282 Old 04-06-2013, 08:32 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Originally Posted by 0IIIIIII0 View Post
Finally got the windshield channel for the Mopar Bikini and the clip piece for the wind jammer. Thankfully the guy that sold me the tops still had them!
For SlackJaw,
This is the piece you've got to track down. It requires a little clearancing at the center footman loop and you also need to trim the plastic interior trim in '03+ models.
Good luck.
Sent from my TJ
Thanks man!
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #82217 of 114282 Old 04-06-2013, 09:16 PM
ScottD06X
2011 JK Wrangler
Originally Posted by stockerokie View Post
Drove it 750 miles. So happy to be out of it.
Been there, done that. Farthest i've gone in 1 stretch is 850 (14 + hours) pulling a 5x10 utility trailer.
On topic - sprayed the engine bay down with simple green scrubbed down some grimier areas with a brush and washed it off.
2011 Silver JKU
ScottD06X is offline
post #82218 of 114282 Old 04-06-2013, 09:22 PM
WeezyBlue
Went wheeling for the first time with my new-to-me '05 Rubi!
KD8UCX
05 TJ Rubicon DD
82 Wagoneer Limited WIP
06 TJ SE Sold
WeezyBlue is offline
post #82219 of 114282 Old 04-07-2013, 06:55 AM
Renegade88
Took the top and doors off this morning around 4:30 this morning before heading to work. Hopefully no spring breakers try to use it as a dumpster/toilet!
2006 LJ
PanhandlePierFishing.com
Renegade88 is offline
post #82220 of 114282 Old 04-07-2013, 07:53 AM
Bordr329
Installed my poison spyder corner armor
Bordr329 is offline
post #82221 of 114282 Old 04-07-2013, 07:56 AM
tdavid14
Pics!
Sent from my SPH-D710 using JeepForum
tdavid14 is offline
post #82222 of 114282 Old 04-07-2013, 07:59 AM
0IIIIIII0
Tell the truth... Did you drop the gas tank to install the last bolt in the hinge side plate? Or did you do what I did and just say "screw it" ?
Sent from my TJ
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #82223 of 114282 Old 04-07-2013, 08:52 AM
djflyy
Put her under for triple bypass and a few staples on Friday. UCF complete deep skid system, 1/4" aluminum, and the LoPro mount.
Comparison (don't mind my neighbor's f'd up house)
Painted and bolted up:
Before:
After:
djflyy is offline
post #82224 of 114282 Old 04-07-2013, 09:15 AM
h1driver
Before:
After:
Looks good, and what a clearance gain... pm'd
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed."
So, Suck-It Trebek!!! MOΛΩN ΛΑΒΕ
My "Build" -
h1driver is offline
post #82225 of 114282 Old 04-07-2013, 09:33 AM
Holaday
painted the rear stinger finally. I like it much better now than the raw aluminum
Holaday is offline
post #82226 of 114282 Old 04-07-2013, 10:15 AM
cwfergus
Started my electrical upgrade. PO had stripped the nut on the positive terminal.
Old:
New:
Also did the Gas filler mod last weekend, no more spills!
cwfergus is offline
post #82227 of 114282 Old 04-07-2013, 10:25 AM
rikkards
rikkards's Avatar
It's like looking at my own. Doing the same thing today. Heck I even have the same rocker guards.
Machete don't tweet
- Machete
rikkards is online now
post #82228 of 114282 Old 04-07-2013, 11:01 AM
357transam
Ordered the rest of the bearings needed for my regear. And last night took it to the drive in.
357transam is offline
post #82229 of 114282 Old 04-07-2013, 11:04 AM
ifritzwj
2005 WK
Well it been a bit but an update on the engine. Striped it completely down, new pistons new gaskets. While cleaning the heads for the valve job I found the heads to be cracked across all the valves, no idea why, but I desided to just buy new ones amd wory about why they cracked later. I have found a bellhousing for my transmission to engine. I also have the new motor mounts, exhaust manifolds and collectors. Now I all I have to do is get the heads back, figure out how to run the 3 inch exhaust and then take a week off and get this puppy in my jeep
ifritzwj is offline
post #82230 of 114282 Old 04-07-2013, 11:16 AM
Batty505a
Building a battery restraint with flat stock & COTS battery screw type hangers.
2006 Chevy Silverado (DD)
1998 Jeep TJ Wrangler Sport (DD)
1993 Jeep YJ Wrangler *Parts Vehicle*
Batty505a is offline
modifications , tj
TXduck
