What did you do to your TJ today? - Page 547 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What did you do to your TJ today?
8500 Lb. Rugged Ridge Winch $239.95 Delivered after $20 MaXJ guys, clock your transfer case!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-29-2007, 01:35 AM   #8191
Blaster
got my pro comp bumpers in and put them on the other day no mods required. The add said there would be drilling required for the 97 TJ I didnt find anything that needed drilling. The rear came with 8 bolts with lock washers and backing plates 4 on each side and there are tabs also that tie it into the frame on each side. The weld on the receiver hitch goes through both sides and looks good the d-ring attachments look to be welded good I have pics just don't know how to post them.The cost for both front and rear with d-rings on both and receiver on the rear came up to $298.92 that was with shipping UPS ground. For the money I think you would be hard pressed to beat the quality. if you need the link here it is.
#66162 and #66168
http://www.4wd.com/subcategories.aspx?jeep-sid=237
Blaster is offline   Reply With Quote
Unread 10-29-2007, 06:20 AM   #8192
tokyonavy
Yesterday: Took the doors off. Removed the side steps. Took the back seat out. Ripped out all the carpet.
Soon: Bedliner and nerf bar.
tokyonavy is offline   Reply With Quote
Unread 10-29-2007, 06:52 AM   #8193
Rob in Arabia
Took the ends off the bumpers and relocated the GPS mounting, in readiness for a trip to the desert on Friday. If I get time tonight, the hardtop is coming off and the safari top is going on - it's 35 degrees celcius in the day, with 60 per cent humidity, and close to perfect wheelin' weather for me.
Rob in Arabia is offline   Reply With Quote
Unread 10-29-2007, 07:21 AM   #8194
Okiiashi
Rotated tires and tightened the rear shoes for a snugger brake pedal
|¯¯l,[___],
l---L--OlllllllO¬
()_) ()_)---)_)RED JEEP #446
“Even if you’re on the right track, you’ll get run over if you just sit there” - Will Rogers
Okiiashi is offline   Reply With Quote
Unread 10-29-2007, 07:39 AM   #8195
omgsideburns
greased all the joints and put my windows and doors on.. its getting too cold for me.. 50s at night. lol.
omgsideburns is offline   Reply With Quote
Unread 10-29-2007, 10:43 AM   #8196
98 Sahara
1" body lift done (though I need to go back and notch the transfer case bracket) and am getting the full size spare tire on now.
_ONLY IN A_
|_Jeep_|
(OlllllllO)
White Jeep Club Member #5448
98 Wrangler TJ Sahara
98 Sahara is offline   Reply With Quote
Unread 10-29-2007, 01:51 PM   #8197
ian0341fo
Not so much today as over the weekend... Had gotten my jeep stuck in water, and filled the tranny with water. Since it was acting up anyway, I pulled it out and had it rebuilt, as well is the t-case. Also installed a JB Converstions Super Short SYE.
I put it back in Saturday, which was a good time, especially when I screwed up the threads on the front transmission cooler line. Took a file and a pick to it and straightened them out. Went to start it up, and heard a great commotion in the bell housing area. As soon as I noticed that, I noticed that it was spitting fluid out of the front pump/converter area. Oh boy! Pulled it back out Sunday and took it down the guy who rebuilt my transmission. He replaced the front seal, and gave me a nifty little tool to align the pump and the splines to aid in putting the converter in. I put it back in Sunday afternoon, started it up and booyah! She ran like a charm!
Now all I have to do is wait on my Tom Woods driveshaft which is arriving tomorrow, and I can put my Mach 1 up for the winter. THANK GOD!!
Side note: On the SYE, JB Conversions say that you need to buy a Chrysler connector kit, but that damn thing is $30!! Being the cheap bastard that I am, I just made up quick disconnects for it and returned the wiring kit. Seems to work just fine. I filled the connectors with dielectric grease, and put some heatshrink around them.
2006 LJ Rubicon
ian0341fo is offline   Reply With Quote
Unread 10-29-2007, 02:11 PM   #8198
rgingerelli99tj
Washed it after a long day of wheeling at Hollister.
Before:
http://i239.photobucket.com/albums/f...j/P1010087.jpg
After:
http://i239.photobucket.com/albums/f...j/P1010088.jpg
1999 Jeep Wrangler TJ
3.5" Rubicon Express Super-Flex Lift, 285x75x16 BF Goodrich A/T TA KO's, Black Jeep Moab's, Or-Fab Tire/Can Carrier, Hi-lift, MAX AXE, Warn Front Bumper w/ Warn 8274, Custom Sliders & Rear Bumper, CB, Warn Diff. Guards & Gas Tank Skid & Steering Box Skid, Dana 30/44, 3.73's, Magnaflow, And lots more on the way...
rgingerelli99tj is offline   Reply With Quote
Unread 10-29-2007, 05:53 PM   #8199
RnEmOvr
Will tow
RnEmOvr's Avatar
put back seat in, and added new interior light
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
FBI data shows that 323 murders were committed with rifles of any kind in 2011. In comparison, 496 murders were committed with hammers and clubs, and 1,694 murders were perpetrated with knives.
RnEmOvr is offline   Reply With Quote
Unread 10-29-2007, 06:48 PM   #8200
bigj1974
removed the factory mudflaps that I had just stoopidly kept forgetting to take off for a VERY long time. looks better. but now I have to remove the bumper milkjugs as soon as I find the Mopar endcaps.
bigj1974 is offline   Reply With Quote
Unread 10-29-2007, 06:55 PM   #8201
abnormal
Platinum Member
abnormal's Avatar
We dont need no stinkin' endcaps!
DURTYROK CAROLINA OFFROAD
abnormal is offline   Reply With Quote
Unread 10-29-2007, 07:54 PM   #8202
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
took my front drive shaft out vibes are gone and also shifts a lot better. need to re build front carrier.
Also cut a bit out of my tummy tuck to make room for my Tcase which was hitting just a bit.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
My TJ Build Thread.
www.kifourwheelers.com
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline   Reply With Quote
Unread 10-29-2007, 08:09 PM   #8203
cincytj
got the 4000RPM bug out of the TJ
sounds like this now....
[COLOR=Navy][SIZE=2]03 Patriot Blue Sport[/SIZE][/COLOR]
Rubi d44 both ends, Crane Diff Covers, Rock trac t-case
Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers
knoblock rear bumper, OBA in process,
bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax
Currie HD steering
Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt
HEMI & 5spd Auto
cincytj is offline   Reply With Quote
Unread 10-29-2007, 08:13 PM   #8204
03Wrangler
gotta love the gas light...
the speedometer rises as the gas gauge falls....
sounds nice, with a 0-60 of around 7
to contribute to the thread..
I did a oil change and rotated the tires... cleaned it up and now it's ready for winter..
FOR SALE
Olympic Trunk for 03 TJ
03Wrangler is offline   Reply With Quote
Unread 10-29-2007, 08:34 PM   #8205
UPSucks
GO BIG RED!
UPSucks's Avatar
This was all done while watching the Redskins get their butts handed to them yesterday.
Installed my third brake light on my atozfabrication rear bumper/tire carrier. Wrapped the wire with some conduit. Blew some fuses,,,fixed the problem....drank beer,,,,threw up. Ain't done that for a long time.
Removed the softop and put the hardtop back on.....I forgot how quiet it is with the hardtop on. I can actually hear my stereo without turning it up.
UPSucks is offline   Reply With Quote
modifications , tj
